cant get live feeds on tv
siriusblack
Post Thu Jul 19, 2012 9:32 am
appreciate any help
i got a problem my laptop crashed and i have to deleate serviio
iv installed it again i put the new plugins and the live feed in C/program folder/serviio/plugins (windows 7)
however the live feeds i coped + put in serviio console 0.6.2 (rtmp://s7.webport.tv/live playpath=z050237.stream pageUrl=http://www.tvsector.com live=1)
there not showing up on my tv (ue46c8000) like they use to, The rss folders is showing up
can you please tell me were i have gone wrong
Thanks for your help
Beta Tester
siriusblack
Post Thu Jul 19, 2012 9:49 am
Re: cant get live feeds on tv
sorry forgot to send log
log4j.xml
(1.64 KiB) Downloaded 580 times
Beta Tester
siriusblack
Post Thu Jul 19, 2012 10:47 am
sorry im new to this
this is the debuged log
ive just tried to cut down the log cause it would not fit all of it
hopes this helps
thanks
debuged.txt
hope this is the right part
(2.72 KiB) Downloaded 508 times
Beta Tester
Post Thu Jul 19, 2012 11:03 am
It looks like the stream is not live (anymore?).
You can confirm this by running
ffmpeg -i "rtmp://s7.webport.tv/live playpath=050234.stream pageUrl=http://www.tvsector.com live=1"
siriusblack
Post Thu Jul 19, 2012 11:16 am
were do i test it to
serviio console ?
vlc ?
thanks
Beta Tester
Post Thu Jul 19, 2012 11:49 am
if you run the above command, you will see it outputs errors - which means the live stream is either not live anymore or the URL is wrong. The streams keep changing ofter or go online/offline for periods of time.
siriusblack
Post Thu Jul 19, 2012 12:27 pm
Can some one please
Send me a live stream link which works now to test
Thanks a lot.
Beta Tester
Post Thu Jul 19, 2012 1:08 pm
siriusblack
Post Thu Jul 19, 2012 5:45 pm
if the live feed is not active and you try to use vlc to check it
would vlc say Your input can't be opened: VLC is unable to open the MRL
if not can you tell me why this is happening
i had no problem until i uninstalled it and then installed it again
thanks
also iv checked my firewall and its not that cause its allowing it not blocking it
Beta Tester
Post Thu Jul 19, 2012 5:48 pm
the stream is dead, easy. Find an alternative or fixed URL. I can't open the stream either so it has nothing to do with your setup.
siriusblack
Post Thu Jul 19, 2012 5:55 pm
thanks
really appreciated
Beta Tester
Return to General discussion
Users browsing this forum: Baidu [Spider] and 15 guests
