File causes library building process to fail
Saurdo
Post Wed Jul 18, 2012 8:59 pm
So, I noticed while updating a huge folder full of video files that one of them caused the library building process to freeze. I renamed that file "b.mkv", put that file in its own separate folder, and added some files that are known to work to that folder as well ("a.mkv" and "c.mkv"). I then pointed the program to that folder and confirmed that it was that one file, independent of file path and filename, that caused the process to fail. I left the process alone for several hours to confirm that it wasn't just taking an extraordinarily long time. I also updated ffmpeg. This file is confirmed to work in VLC, MPC, and ffplay.
Anyway, here's the details on the file:
Some ffmpeg info
C:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\mkv\b.mkv"
ffmpeg version N-42547-g7543fd8 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jul 15 2012 21:40:06 with gcc 4.7.1
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass
 --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e
nable-zlib
  libavutil      51. 65.100 / 51. 65.100
  libavcodec     54. 40.100 / 54. 40.100
  libavformat    54. 16.104 / 54. 16.104
  libavfilter     3.  2.100 /  3.  2.100
Input #0, matroska,webm, from 'D:\mkv\b.mkv':
    creation_time   : 2012-04-04 04:46:46
  Duration: 00:11:11.59, start: 0.000000, bitrate: 2199 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 29.97
 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default)
    Stream #0:1: Audio: aac, 48000 Hz, 5.1, s16 (default)
The mediainfo info:
Unique ID                                : 235839725617131727413953996012024882388 (0xB16D1436FF9CFEBCBA1A9D539595E4D4)
Complete name                            : D:\mkv\b.mkv
File size                                : 176 MiB
Duration                                 : 11mn 11s
Overall bit rate                         : 2 200 Kbps
Encoded date                             : UTC 2012-04-04 04:46:46
Writing application                      : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library                          : libebml v1.2.0 + libmatroska v1.1.0
Format profile                           : High@L5.1
Format settings, ReFrames                : 2 frames
Muxing mode                              : Header stripping
Duration                                 : 11mn 11s
Frame rate                               : 29.970 fps
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=2 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=1 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Codec ID                                 : A_AAC
Duration                                 : 11mn 11s
Finally the debug log from that process:
2012-07-18 13:48:01,112 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-18 13:48:01,113 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = search_hidden_files)
2012-07-18 13:48:01,114 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = search_hidden_files, value = false)
2012-07-18 13:48:01,115 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-18 13:48:01,115 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-18 13:48:01,115 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = search_updated_files)
2012-07-18 13:48:01,115 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = search_updated_files, value = true)
2012-07-18 13:48:01,116 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = repository_automatic_check)
2012-07-18 13:48:01,117 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = repository_automatic_check, value = true)
2012-07-18 13:48:01,117 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = repository_automatic_check_interval)
2012-07-18 13:48:01,118 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = repository_automatic_check_interval, value = 5)
2012-07-18 13:48:01,119 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = online_feed_max_num_items)
2012-07-18 13:48:01,119 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = online_feed_max_num_items, value = 20)
2012-07-18 13:48:01,120 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = online_feed_expiry_interval)
2012-07-18 13:48:01,120 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = online_feed_expiry_interval, value = 24)
2012-07-18 13:48:01,124 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-18 13:48:01,221 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-18 13:48:01,322 DEBUG [RepositoryServerResource] Updating repository with values: Repository [id=null, folder=D:\mkv, keepScanningForUpdates=true, lastScanned=null, supportedFileTypes=[VIDEO], supportsOnlineMetadata=false]
2012-07-18 13:48:01,322 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-18 13:48:01,323 DEBUG [RepositoryService] Found 0 repositories to be removed
2012-07-18 13:48:01,323 DEBUG [RepositoryDAOImpl] Creating a new Repository (folder = D:\mkv)
2012-07-18 13:48:01,324 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-18 13:48:01,324 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-18 13:48:01,326 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\mkv
2012-07-18 13:48:01,326 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-18 13:48:01,326 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-18 13:48:01,327 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\mkv
2012-07-18 13:48:01,327 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 24)
2012-07-18 13:48:01,327 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 24)
2012-07-18 13:48:01,328 DEBUG [RepositoryDAOImpl] Marking Repository 24 as scanned with current timestamp
2012-07-18 13:48:01,346 DEBUG [LibraryAdditionsCheckerThread] Found file 'a.mkv', checking if it's already in the Library
2012-07-18 13:48:01,346 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item a.mkv
2012-07-18 13:48:01,346 DEBUG [MediaItemDAOImpl] Media item a.mkv doesn't exist in DB yet
2012-07-18 13:48:01,347 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-07-18 13:48:01,347 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\mkv\a.mkv
2012-07-18 13:48:01,347 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\mkv\a.mkv
2012-07-18 13:48:01,347 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\mkv\a.mkv
2012-07-18 13:48:01,382 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'D:\mkv\a.mkv'
2012-07-18 13:48:01,382 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: D:\mkv\a.mkv
2012-07-18 13:48:01,382 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\mkv\a.mkv -vframes 1 -vcodec copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-07-18 13:48:01,398 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-18 13:48:01,399 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-18 13:48:01,421 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (4.1) is different than one based on ref_frames value (4), the higher will be stored
2012-07-18 13:48:01,421 DEBUG [FFmpegMetadataRetriever] File 'D:\mkv\a.mkv' has H264 profile HIGH, level 4.1 and 8 ref frames
2012-07-18 13:48:01,421 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: D:\mkv\a.mkv
2012-07-18 13:48:01,421 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i D:\mkv\a.mkv -an -vframes 1 -f image2 pipe:
2012-07-18 13:48:01,505 DEBUG [RepositoryDAOImpl] Reading all Repositories
2012-07-18 13:48:01,506 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-07-18 13:48:01,590 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=a, filePath=D:\mkv\a.mkv, fileSize=664511805, audioBitrate=384, audioCodec=AC3, audioStreamIndex=1, bitrate=4135, channels=6, container=MATROSKA, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@71e39149, duration=1285, episodeNumber=null, fps=23.976, frequency=48000, h264Level=4.1, h264Profile=HIGH, ftyp=null, height=720, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1280]
2012-07-18 13:48:01,590 DEBUG [VideoService] Adding video into database: a
2012-07-18 13:48:01,594 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2012-07-18 13:48:01,594 DEBUG [GenreService] Genre Unknown not found, creating a new one
2012-07-18 13:48:01,594 DEBUG [GenreDAOImpl] Creating a new Genre (name = Unknown)
2012-07-18 13:48:01,596 DEBUG [CoverImageService] Resizing and storing cover art image
2012-07-18 13:48:01,596 DEBUG [ImageUtils] Starting image resize, size = 62647 bytes
2012-07-18 13:48:01,635 DEBUG [ImageUtils] Returning resized image, size = 4759 bytes
2012-07-18 13:48:01,635 DEBUG [CoverImageService] Image successfully resized
2012-07-18 13:48:01,635 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 4759)
2012-07-18 13:48:01,637 DEBUG [VideoDAOImpl] Creating a new Video (title = a)
2012-07-18 13:48:01,640 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 847 as DIRECTOR
2012-07-18 13:48:01,640 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-07-18 13:48:01,641 DEBUG [PersonDAOImpl] Creating a new Person (name = Unknown)
2012-07-18 13:48:01,642 DEBUG [PersonDAOImpl] Checking if person 255 has a role DIRECTOR for media item 847
2012-07-18 13:48:01,646 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 847 as PRODUCER
2012-07-18 13:48:01,646 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-07-18 13:48:01,646 DEBUG [PersonDAOImpl] Checking if person 255 has a role PRODUCER for media item 847
2012-07-18 13:48:01,649 DEBUG [PersonDAOImpl] Adding a Person Unknown to media item 847 as ACTOR
2012-07-18 13:48:01,649 DEBUG [PersonDAOImpl] Reading a Person (name = Unknown)
2012-07-18 13:48:01,650 DEBUG [PersonDAOImpl] Checking if person 255 has a role ACTOR for media item 847
2012-07-18 13:48:01,653 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 847)
2012-07-18 13:48:01,655 INFO  [LibraryAdditionsCheckerThread] Added file 'a.mkv' (title: a) to Library
2012-07-18 13:48:01,675 DEBUG [LibraryAdditionsCheckerThread] Found file 'b.mkv', checking if it's already in the Library
2012-07-18 13:48:01,675 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item b.mkv
2012-07-18 13:48:01,675 DEBUG [MediaItemDAOImpl] Media item b.mkv doesn't exist in DB yet
2012-07-18 13:48:01,675 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-07-18 13:48:01,676 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\mkv\b.mkv
2012-07-18 13:48:01,676 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\mkv\b.mkv
2012-07-18 13:48:01,676 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\mkv\b.mkv
2012-07-18 13:48:01,716 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'D:\mkv\b.mkv'
2012-07-18 13:48:01,716 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: D:\mkv\b.mkv
2012-07-18 13:48:01,716 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\mkv\b.mkv -vframes 1 -vcodec copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-07-18 13:48:03,412 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-07-18 13:48:03,412 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-07-18 13:48:03,412 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
Now, even though the log says "library updated" the console still has the green dot and displays "1 (a.mkv)". I have other files that do this as well, all mkv, probably encoded the same way.
Post Thu Jul 19, 2012 5:21 pm
Re: File causes library building process to fail
Any chance you can strip this file for a few seconds and send it to me for testing?
Saurdo
Post Thu Jul 19, 2012 6:17 pm
Sure thing. PM sent with link to the file.
Post Sat Jul 21, 2012 1:35 pm
Thanks, it looks like the file has a damaged H264 header which was causing Serviio to run out of memory. I've now guarded against this case, but whether the file will be playable on your renderer, it's to be seen.
Fixed for 1.0
