Sony KDLZ5100 Problems
amedina
Post Sat Jul 21, 2012 6:40 pm
I searched and searched and though I have found some similar problems noted on the forum I haven't been able to fix my issue. I'm a new Servio user. Its installed on a Windows 7 machine and I'm trying to serve my Sony KDL-Z5100 which is connected to the network via Wireless Bridge. The TV can see the server, folders and files just fine including thumbnails of the videos. When I attempt to play a video the TV looks as if its about to start play and then it crashes and Reboots. I have been using the Sony Bravia 2009 Profile which I believe is the model year for my set. I have also tried a sample file from the Sony website they say is to test DLNA and that file at least begins to play but then also crashes and reboots the TV. I've attached the detailed log here if anybody can help.
Angel
(260.72 KiB) Downloaded 448 times
amedina
Post Mon Jul 23, 2012 10:23 pm
Re: Sony KDLZ5100 Problems
Anybody? I really want to use Servio but have hit a wall.
thanks.
Post Wed Jul 25, 2012 10:39 pm
log looks ok, it doesn't even transcode the file. What is your network connection? wifi or wired? What is your router?
amedina
Post Sun Jul 29, 2012 5:38 am
My router is a Netgear N600 and the TV is attached by a Cisco Wet610N wireless bridge so through WiFi.
Post Sun Jul 29, 2012 7:42 am
Could you provide the sample file link ?
