Stutters badly in certain scenes, can't pause or ffwd
night7
Post Mon Jul 23, 2012 2:35 pm
I'm having a really annoying issue with HD 1080p video stuttering really badly during some scenes with intense detail. I would like to know if there's a way to prefer super poor quality video over freezing and stuttering for 20 seconds.
My TV is this Sony Bravia: http://www.jbhifi.co.nz/tv-lcd-led-plas ... sku-22682/
Both the TV and laptop have wired connections to my router. Network is 100 Mbit/s, CPU is a quad core Intel Core i7-2620M at 2.70 GHz.
I'm trying to watch the BBC's Planet Earth series, from a ripped Blu Ray. 99% of the video is playing fine, but it stutters horribly when it plays certain scenes with super-high levels of detail, such as thousands of flying birds filling the screen. It stutters and pauses, and takes about 20 seconds to play 5 seconds of footage like this. To be fair, this is probably some of the most uncompressable video you will ever find:
My guess is that encoding algorithm collapses under these conditions, and my CPU hits the roof. The real reason it's a pain in the ass is because I can't pause or fast forward the video without the receiving the error 'Playback not available', with these lines in the serviio logs:
2012-07-24 02:24:52,127 DEBUG [ResourceTransportRequestHandler] Unsupported time range request because bitrate is not available, sending back 406
2012-07-24 02:24:52,127 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 406 Not Acceptable, headers = [[Content-Type: video/mpeg]]
PS3 media server (http://www.ps3mediaserver.org/) can fast forward and pause these videos just fine...
So, would it be possible to alter the rendering profile to prefer crap quality for these rare scenes, instead of overloading my CPU?
And is it possible to fix fast forwarding or pause/play for these videos?
Cheers!
night7
Post Mon Jul 23, 2012 2:50 pm
Re: Stutters badly in certain scenes, can't pause or ffwd
Just checked PS3 Media Server again, and it plays this scene fine, with tsMuxer video engine as top priority. It also supports fast-forward and pause/play, although sometimes the sound does get out of sync.
I'm going to have to switch to PS3MS for now, but I'm sad it doesn't have serviio's awesome content organization.
patters
Post Tue Jul 24, 2012 8:26 pm
Can you run FFmpeg -i on the clip and posting the output here.
Post Wed Jul 25, 2012 10:35 pm
what is your OS? It looks like it cannot retrieve the transcoded bitrate from FFmpeg that is used for ffwd operation
night7
Post Wed Jul 25, 2012 10:39 pm
My OS is Ubuntu Linux 12.04.
Here's the output of
ffmpeg -i Planet.Earth.1080p.BluRay.x264.Ep3.mkv
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Jun 12 2012 16:52:09 with gcc 4.6.3
[matroska,webm @ 0x259a9a0] max_analyze_duration reached
[matroska,webm @ 0x259a9a0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'Planet.Earth.1080p.BluRay.x264.Ep3.mkv':
Duration: 00:51:25.53, start: 0.000000, bitrate: 448 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s (default)
Stream #0.2(swe): Subtitle: [0][0][0][0] / 0x0000 (default)
Stream #0.3(nor): Subtitle: [0][0][0][0] / 0x0000
Stream #0.4(fin): Subtitle: [0][0][0][0] / 0x0000
Post Thu Jul 26, 2012 4:18 pm
your FFMpeg is quite old, try to compile from the sources provided on the Download page.
Indi
Post Wed Aug 08, 2012 4:01 pm
Similar problems with possibly similar file. Any solution appreciated. FFMPEG output posted here:
ffmpeg version N-38148-gb6ff81d Copyright (c) 2000-2012 the FFmpeg developers
built on Feb 23 2012 12:26:05 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 40.100 / 51. 40.100
libavcodec 54. 4.100 / 54. 4.100
libavformat 54. 1.100 / 54. 1.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 62.101 / 2. 62.101
libswresample 0. 7.100 / 0. 7.100
Input #0, matroska,webm, from 'PlanetEarth1.mkv':
Duration: 00:53:20.65, start: 0.000000, bitrate: 11735 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s (default)
title : English (AC3)
Stream #0:2(eng): Subtitle: ssa (default)
Stream #0:3: Attachment: ttf
filename : exprswy_free.ttf
mimetype : application/x-truetype-font
Stream #0:4: Attachment: ttf
filename : Framd.TTF
Post Wed Aug 08, 2012 4:28 pm
If h264 profile level is <4.1, then video is only remuxed, otherwise it will be transcode.
Could you provide MediaInfo tool result in text format ?
