Serviio 1.0 and IE 9
heuby
Post Tue Jul 24, 2012 7:30 pm
Serviio 1.0 is a great product. I love it since version 0.6.x.
The mediabrowser in 1.0 is near perfect. With FF it works perfect, but on IE9 it seems the login-dialog will not close after correct entry the password. You can access the ressources, but the dialog will stay on top.
Is this a known issue or have change some settings in the internet options?
best regards
heuby
Switzerland
Post Tue Jul 24, 2012 8:35 pm
Re: Serviio 1.0 and IE 9
Thats the same problem I have with IE8. Are you sure you are using IE9?
Click Help then About IE and report the full version number there displayed.
patters
Post Tue Jul 24, 2012 10:30 pm
Check IE9 isn't in Compatibility mode.
heuby
Post Wed Jul 25, 2012 4:53 am
Yes it's IE9.
Thank you for the hint about compatiblity-mode.
I accessed the page using the local address. By default, IE9 displays intranet sites in compatiblity-mode.
Uncheck the option and works perfect :-)
Thank you
best regards
heuby
Switzerland
Users browsing this forum: Google [Bot] and 22 guests
