Media Browser strange behaviour
krudoy
Post Thu Jul 26, 2012 12:46 am
Media browser behaves very strange:
Open http://localhost:23424/mediabrowser/
Enter password
Select 'Videos' -> 'By Folder' -> 'Videos' Folder
as result - media browser shows list of folders for just a second and kicks me back to login screen
But Images and Audio work fine
Post Thu Jul 26, 2012 1:57 am
Re: Media Browser strange behaviour
What browser are you using?
krudoy
Post Thu Jul 26, 2012 2:28 am
I tried IE9, Chrome, Firefox 14 with the same results
Post Thu Jul 26, 2012 9:22 am
is there anything in the logs?
krudoy
Post Thu Jul 26, 2012 11:00 am
2012-07-25 21:20:01,209 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 2929 (from=0, count=27) [Any]
2012-07-25 21:20:01,214 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: Cannot read list of videos for folder 2929
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: Cannot read list of videos for folder 2929
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:135)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:237)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.java:131)
at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.browse(CDSBrowseServerResource.java:108)
at sun.reflect.GeneratedMethodAccessor103.invoke(Unknown Source)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
at org.restlet.resource.ServerResource.get(ServerResource.java:645)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:50)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:53)
at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
at org.restlet.resource.Finder.handle(Finder.java:510)
at org.restlet.routing.Filter.doHandle(Filter.java:156)
at org.restlet.routing.Filter.handle(Filter.java:203)
at org.restlet.routing.Router.doHandle(Router.java:497)
at org.restlet.routing.Router.handle(Router.java:737)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
at org.restlet.Application.handle(Application.java:388)
at org.restlet.Component.handle(Component.java:388)
at org.restlet.Server.handle(Server.java:488)
at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.serviio.db.dao.PersistenceException: Cannot read list of videos for folder 2929
at org.serviio.library.dao.VideoDAOImpl.retrieveVideosForFolder(VideoDAOImpl.java:333)
at org.serviio.library.local.service.VideoService.getListOfVideosForFolder(VideoService.java:329)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.getItemsForMediaType(AbstractListObjectsByFSHierarchyCommand.java:284)
at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveList(AbstractListObjectsByFSHierarchyCommand.java:138)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:129)
... 55 more
Caused by: java.sql.SQLSyntaxErrorException: Column 'MKV_HEADER_COMPRESSION' is either not in any table in the FROM list or appears within a join specification and is outside the scope of the join specification or appears in a HAVING clause and is not in the GROUP BY list. If this is a CREATE or ALTER TABLE statement then 'MKV_HEADER_COMPRESSION' is not a column in the target table.
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement20.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.newEmbedPreparedStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement(Unknown Source)
at org.serviio.library.dao.VideoDAOImpl.retrieveVideosForFolder(VideoDAOImpl.java:317)
... 59 more
Caused by: java.sql.SQLException: Column 'MKV_HEADER_COMPRESSION' is either not in any table in the FROM list or appears within a join specification and is outside the scope of the join specification or appears in a HAVING clause and is not in the GROUP BY list. If this is a CREATE or ALTER TABLE statement then 'MKV_HEADER_COMPRESSION' is not a column in the target table.
... 73 more
Caused by: ERROR 42X04: Column 'MKV_HEADER_COMPRESSION' is either not in any table in the FROM list or appears within a join specification and is outside the scope of the join specification or appears in a HAVING clause and is not in the GROUP BY list. If this is a CREATE or ALTER TABLE statement then 'MKV_HEADER_COMPRESSION' is not a column in the target table.
at org.apache.derby.impl.sql.compile.ColumnReference.bindExpression(Unknown Source)
at org.apache.derby.impl.sql.compile.ResultColumn.bindExpression(Unknown Source)
at org.apache.derby.impl.sql.compile.ResultColumnList.bindExpressions(Unknown Source)
at org.apache.derby.impl.sql.compile.SelectNode.bindExpressions(Unknown Source)
at org.apache.derby.impl.sql.compile.DMLStatementNode.bindExpressions(Unknown Source)
at org.apache.derby.impl.sql.compile.DMLStatementNode.bind(Unknown Source)
at org.apache.derby.impl.sql.compile.CursorNode.bindStatement(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepMinion(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepare(Unknown Source)
at org.apache.derby.impl.sql.conn.GenericLanguageConnectionContext.prepareInternalStatement(Unknown Source)
... 67 more
2012-07-25 21:20:01,215 WARN [LocalContentCacheDecorator] Could not store object to local cache(local_default): Value must not be null
2012-07-25 21:20:01,215 WARN [CDSBrowseServerResource] Browse for object id V_F^FOL_R1 failed with exception: null
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.buildResult(CDSBrowseServerResource.java:149)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.browse(CDSBrowseServerResource.java:110)
2012-07-25 21:20:01,216 WARN [ServiioStatusService] RuntimeException occured. Returning error code 500 to the REST layer. Message: java.lang.NullPointerException
2012-07-25 21:20:01,216 DEBUG [ServiioStatusService] Detailed exception:
java.lang.RuntimeException: java.lang.NullPointerException
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.browse(CDSBrowseServerResource.java:119)
Caused by: java.lang.NullPointerException
... 51 more
Post Thu Jul 26, 2012 1:08 pm
Ok, it doesn't look like you upgraded correctly. Try to reinstall Serviio.
krudoy
Post Fri Jul 27, 2012 5:22 pm
zip wrote:Ok, it doesn't look like you upgraded correctly. Try to reinstall Serviio.
Complete remove/Install helped
Users browsing this forum: No registered users and 52 guests
