Is it possible to create playlists / specific content stream
GamePat
Post Thu Jul 26, 2012 4:47 am
Re: Is it possible to create playlists / specific content st
zip wrote:can you post the bit of the playlist file around the item that is last shown and a few after that?
Here it is (Frida - Come To Me (I Am Woman) is last shown):
#EXTINF:307,Frida - Come to Me (I Am Woman) - Shine
D:\Documents and Settings\PR\Desktop\My Music\NJB22\Shine\07 - Come to Me (I Am Woman).wma
#EXTINF:221,Tina Turner - Come Together - The Platinum Collection (CD 1)
D:\Documents and Settings\PR\Desktop\My Music\NJB22\NJB2\Come Together.mp3
#EXTINF:288,Duran Duran - Come Undone - Strange Behaviour, Disc 2
D:\Documents and Settings\PR\Desktop\My Music\NJB22\Strange Behaviour, Disc 2\Come Undone.wma
#EXTINF:280,Duran Duran - Come Undone (LP Version) - Come Undone
D:\Documents and Settings\PR\Desktop\My Music\NJB22\Come Undone\01 - Come Undone (LP Version).wma
#EXTINF:267,Frida - Comfort Me - Shine
D:\Documents and Settings\PR\Desktop\My Music\NJB22\Shine\10 - Comfort Me.wma
#EXTINF:240,Vanessa Williams - Comfort Zone - The Comfort Zone
D:\Documents and Settings\PR\Desktop\My Music\NJB22\The Comfort Zone\01. Comfort Zone.wma
GamePat
Post Thu Jul 26, 2012 6:32 am
I'm 100 % sure that if I change the order of the tracks it will just only show the first 592 or whatever tracks. As if it's got a limit or cutoff point.
EDIT: just did that and what do you know... only the first 592 files are shown.
EDIT 2: Checked with other streaming software and there is also a limit, but not as bad as with Serviio. I can see 1020 tracks. Still a limit is a limit...
Post Thu Jul 26, 2012 9:21 am
I think 1020 is the Samsung's limit.
I'll try to figure out what could be wrong. Any chance to post a detailed log of when it parses the playlist? (ie try to remove the playlist file, force refresh, wait for it to be removed from the library and then add again.)
GamePat
Post Thu Jul 26, 2012 9:39 am
zip wrote:I think 1020 is the Samsung's limit.
2012-07-26 11:32:20,814 DEBUG [LibraryAdditionsCheckerThread] Found playlist file 'My music.m3u', checking if it's already in the Library
2012-07-26 11:32:20,816 DEBUG [LibraryAdditionsCheckerThread] Playlist file not in Library, will add it
2012-07-26 11:32:20,850 DEBUG [PlaylistService] Adding playlist into database: My music
2012-07-26 11:32:25,558 INFO  [LibraryAdditionsCheckerThread] Added playlist 'My music.m3u' (title: My music) to Library
2012-07-26 11:37:24,242 DEBUG [PlaylistMaintainerThread] Playlist My music has changed, updating the library
2012-07-26 11:42:35,276 DEBUG [PlaylistMaintainerThread] Playlist My music has unresolved items, checking if they are in the library now
Post Thu Jul 26, 2012 1:10 pm
what is your OS? I will send you a build with more logging.
GamePat
Post Thu Jul 26, 2012 1:17 pm
zip wrote:what is your OS? I will send you a build with more logging.
Windows 7
GamePat
Post Thu Jul 26, 2012 8:04 pm
This issue is now been solved. I've chatted back an forth with zip and it turns out that Serviio is not exepting playlist larger than 100 kb. This will be fixed for next release 1.0.1
aSystemOverload
Post Mon Aug 27, 2012 8:46 am
Ok, I've downloaded and installed 1.0.1, I was expecting to be able to create playlists from the serviio console, can I presume this is not the case and I can only place playlists somewhere in the library?
Post Mon Aug 27, 2012 11:00 pm
aSystemOverload wrote:Ok, I've downloaded and installed 1.0.1, I was expecting to be able to create playlists from the serviio console, can I presume this is not the case and I can only place playlists somewhere in the library?
yes. just place a .pls, .wpl, .m3u file in a shared folder.
Previous
Users browsing this forum: No registered users and 72 guests
