Serviio 1.0 will not Show all files?
Scoty
Post Thu Jul 26, 2012 12:26 pm
I have Update from 0.6.2 to 1.0 and i have the problem Serviio show me not all Video. I have add to my folder 2 new 1080 mkv Video but i can not see this on my TV. I have push Force Refresh but not help. What can i do?
Edit: I have see in the log and the both Video i can not see. Here the Media Info:
Mediainfo:
Format : Matroska
Format version : Version 2
File size : 9.19 GiB
Duration : 1h 31mn
Overall bit rate : 14.4 Mbps
Encoded date : UTC 2012-07-22 23:27:35
Writing application : mkvmerge v4.8.0 ('I Got The...') gebaut am May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 31mn
Bit rate : 11.9 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.324
Stream size : 7.63 GiB (83%)
Writing library : x264 core 125 r2200 999b753
Default : Yes
Forced : No
Color primaries : Generic film
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 31mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 419 MiB (4%)
Language : German
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 1h 31mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Delay relative to video : 11ms
Stream size : 988 MiB (11%)
Language : English
Default : No
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : German
Default : No
Forced : No
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : German
Default : Yes
Forced : Yes
Post Thu Jul 26, 2012 1:10 pm
Re: Serviio 1.0 will not Show all files?
what do you see in the log?
Scoty
Post Thu Jul 26, 2012 2:47 pm
Nothing, only this:
2012-07-26 14:44:53,416 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 14:44:53,516 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 14:44:53,616 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 14:44:53,616 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 14:46:50,714 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 14:46:50,814 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 14:46:50,914 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 14:46:50,914 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 14:47:01,815 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
I have rename the video and the folder name but not help.
Edit: I have download a other 1080 Video and the same problem. Serviio will not Index this or can not see this File. Here the Media Info:
Unique ID                      : 234654386068250739289436497284564435218 (0xB088CA7686AE4A31AEA88696B1A6C112)
Format                         : Matroska
File size                      : 6.56 GiB
Duration                       : 1h 31mn
Overall bit rate               : 10.3 Mbps
Movie name                     : moep-ntw720p
Encoded date                   : UTC 2012-07-21 23:15:17
Writing application            : mkvmerge v5.7.0 ('The Whirlwind') built on Jul  8 2012 20:08:51
Writing library                : libebml v1.2.3 + libmatroska v1.3.0
Format                         : AVC
Format/Info                    : Advanced Video Codec
Muxing mode                    : Header stripping
Duration                       : 1h 31mn
Bit rate                       : 8 107 Kbps
Height                         : 800 pixels
Color space                    : YUV
Bit depth                      : 8 bits
Bits/(Pixel*Frame)             : 0.220
Stream size                    : 5.05 GiB (77%)
Encoding settings              : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8107 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                       : English
Default                        : Yes
Forced                         : No
Audio #1
Format                         : AC-3
Mode extension                 : CM (complete main)
Codec ID                       : A_AC3
Duration                       : 1h 31mn
Bit rate                       : 640 Kbps
Channel positions              : Front: L C R, Side: L R, LFE
Bit depth                      : 16 bits
Stream size                    : 419 MiB (6%)
Language                       : German
Default                        : Yes
Forced                         : No
Audio #2
Format                         : DTS
Codec ID                       : A_DTS
Duration                       : 1h 31mn
Bit depth                      : 24 bits
Stream size                    : 988 MiB (15%)
Title                          : English DTS 1509kbps
Language                       : English
Default                        : No
Forced                         : No
Text #1
Format                         : UTF-8
Codec ID                       : S_TEXT/UTF8
Codec ID/Info                  : UTF-8 Plain Text
Title                          : French_forced
Language                       : French
Default                        : Yes
Forced                         : Yes
Text #2
Format                         : UTF-8
Title                          : French
Language                       : French
Default                        : No
Forced                         : No
Text #3
Format                         : UTF-8
Title                          : English
Language                       : English
Default                        : No
Forced                         : No
Text #4
Format                         : VobSub
Muxing mode                    : zlib
Codec ID                       : S_VOBSUB
Language                       : English
Default                        : No
Forced                         : No
Text #5
Format                         : VobSub
Muxing mode                    : zlib
Codec ID                       : S_VOBSUB
Language                       : German
Default                        : No
Forced                         : No
Text #6
Format                         : VobSub
Muxing mode                    : zlib
Codec ID                       : S_VOBSUB
Language                       : Turkish
Default                        : No
Forced                         : No
Text #7
Format                         : UTF-8
Language                       : German
Default                        : No
Forced                         : No
I have add the Video for 3 Minutes but you can see Serviio see nothing:
2012-07-26 16:50:59,996 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:51:00,096 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:51:00,196 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:51:00,196 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 16:51:10,377 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:51:10,477 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:51:10,577 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:51:10,577 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 16:51:37,516 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:51:37,616 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:51:37,716 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:51:37,716 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 16:52:30,183 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:52:30,283 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:52:30,383 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:52:30,383 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 16:53:50,564 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:53:50,664 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:53:50,764 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:53:50,764 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 16:54:23,157 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 16:54:23,257 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 16:54:23,357 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 16:54:23,357 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
I will back to 0.6.2. This works perfect.
Post Thu Jul 26, 2012 3:01 pm
You need to turn on detailed logging first (see sig)
Post Thu Jul 26, 2012 3:11 pm
What OS are you on? If Linux, make sure to get the latest FFmpeg.
Scoty
Post Thu Jul 26, 2012 3:19 pm
I use Windows 7 SP1 x64. I have comlete delete Serviio and have make a new install from 1.0 but the same. It show not the 1080 mkv Video.
Here the log:
2012-07-26 17:00:32,644 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-26 17:00:32,644 INFO [MediaServer] Serviio DLNA media streaming server v 1.0 (rev. 34c915f37185+)
2012-07-26 17:00:32,644 INFO [MediaServer] Petr Nejedly 2009-2012
2012-07-26 17:00:32,644 INFO [MediaServer] http://www.serviio.org
2012-07-26 17:00:32,644 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-07-26 17:00:32,644 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-07-26 17:00:32,644 INFO [MediaServer] File encoding: windows-1252
2012-07-26 17:00:32,644 INFO [MediaServer] Headless mode enabled: true
2012-07-26 17:00:32,644 INFO [MediaServer] User home dir: C:\
2012-07-26 17:00:32,644 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-07-26 17:00:32,722 INFO [WebServer] Socket buffer set to 65535 bytes
2012-07-26 17:00:32,722 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-07-26 17:00:32,753 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-07-26 17:00:32,753 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-07-26 17:00:32,753 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-07-26 17:00:33,533 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-07-26 17:00:35,093 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-26 17:00:35,093 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-07-26 17:00:35,280 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-07-26 17:00:35,592 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-07-26 17:00:35,795 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-07-26 17:00:35,904 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-07-26 17:00:36,107 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-07-26 17:00:36,200 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-07-26 17:00:36,263 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-07-26 17:00:36,512 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-07-26 17:00:36,528 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-07-26 17:00:36,856 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-07-26 17:00:37,261 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-07-26 17:00:37,433 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-07-26 17:00:37,558 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-07-26 17:00:37,573 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-07-26 17:00:37,667 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-07-26 17:00:37,698 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-07-26 17:00:37,823 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-07-26 17:00:37,838 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-07-26 17:00:37,963 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-07-26 17:00:38,104 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-07-26 17:00:38,166 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-07-26 17:00:38,197 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-07-26 17:00:38,462 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/G/GT/DT/UT (2011/2012)' (id=viera2011a)
2012-07-26 17:00:38,494 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera S/ST/VT (2011)' (id=viera2011)
2012-07-26 17:00:38,540 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-07-26 17:00:38,556 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-07-26 17:00:38,681 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-07-26 17:00:38,759 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-07-26 17:00:41,177 INFO [Device] Created UPnP Device with UUID: a1ffebb8-abb6-3690-abdd-9b64ddd6336c, bound address: 192.168.1.211
2012-07-26 17:00:41,192 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-07-26 17:00:41,192 INFO [PluginCompilerThread] Started looking for plugins
2012-07-26 17:00:41,192 INFO [UpdateChecker] Checking if a new version is available
2012-07-26 17:00:41,426 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-07-26 17:00:41,442 INFO [WebServer] WebServer starting on port 8895
2012-07-26 17:00:41,458 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-07-26 17:00:41,458 INFO [EventDispatcher] Starting EventDispatcher
2012-07-26 17:00:41,458 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-07-26 17:00:41,458 INFO [RendererSearchSender] Searching for Renderer devices
2012-07-26 17:00:41,458 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-07-26 17:00:41,525 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.211, timeout = 0
2012-07-26 17:00:55,799 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-07-26 17:00:55,799 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-07-26 17:00:55,799 INFO [PluginCompilerThread] Finished looking for plugins
2012-07-26 17:00:55,908 INFO [WebServer] WebServer shutting down
2012-07-26 17:00:55,908 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-07-26 17:00:55,908 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-07-26 17:00:55,908 INFO [EventDispatcher] Leaving EventDispatcher
2012-07-26 17:00:55,908 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-07-26 17:00:56,485 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-07-26 17:00:58,170 INFO [DatabaseManager] Shutting down database
2012-07-26 17:00:58,217 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-07-26 17:01:28,560 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-26 17:01:28,560 INFO [MediaServer] Serviio DLNA media streaming server v 1.0 (rev. 34c915f37185+)
2012-07-26 17:01:28,560 INFO [MediaServer] Petr Nejedly 2009-2012
2012-07-26 17:01:28,560 INFO [MediaServer] http://www.serviio.org
2012-07-26 17:01:28,560 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-07-26 17:01:28,560 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-07-26 17:01:28,560 INFO [MediaServer] File encoding: windows-1252
2012-07-26 17:01:28,560 INFO [MediaServer] Headless mode enabled: true
2012-07-26 17:01:28,560 INFO [MediaServer] User home dir: C:\
2012-07-26 17:01:28,560 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-07-26 17:01:28,669 INFO [WebServer] Socket buffer set to 65535 bytes
2012-07-26 17:01:28,669 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-07-26 17:01:28,700 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-07-26 17:01:28,700 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-07-26 17:01:28,716 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-07-26 17:01:30,089 INFO [MediaServer] ------------------------------------------------------------------------
2012-07-26 17:01:30,089 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-07-26 17:01:30,292 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-07-26 17:01:30,619 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-07-26 17:01:30,806 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-07-26 17:01:30,916 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-07-26 17:01:31,103 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-07-26 17:01:31,196 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-07-26 17:01:31,259 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-07-26 17:01:31,508 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-07-26 17:01:31,524 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-07-26 17:01:31,836 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-07-26 17:01:32,179 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-07-26 17:01:32,320 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-07-26 17:01:32,398 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-07-26 17:01:32,413 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-07-26 17:01:32,491 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-07-26 17:01:32,522 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-07-26 17:01:32,647 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-07-26 17:01:32,663 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-07-26 17:01:32,788 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-07-26 17:01:32,912 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-07-26 17:01:32,975 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-07-26 17:01:33,006 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-07-26 17:01:33,287 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/G/GT/DT/UT (2011/2012)' (id=viera2011a)
2012-07-26 17:01:33,318 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera S/ST/VT (2011)' (id=viera2011)
2012-07-26 17:01:33,365 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-07-26 17:01:33,380 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-07-26 17:01:33,505 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-07-26 17:01:33,599 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-07-26 17:01:36,329 INFO [Device] Created UPnP Device with UUID: a1ffebb8-abb6-3690-abdd-9b64ddd6336c, bound address: 192.168.1.211
2012-07-26 17:01:36,422 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-07-26 17:01:36,438 INFO [UpdateChecker] Checking if a new version is available
2012-07-26 17:01:36,438 INFO [PluginCompilerThread] Started looking for plugins
2012-07-26 17:01:36,641 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-07-26 17:01:36,688 INFO [WebServer] WebServer starting on port 8895
2012-07-26 17:01:36,688 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-07-26 17:01:36,688 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-07-26 17:01:36,688 INFO [EventDispatcher] Starting EventDispatcher
2012-07-26 17:01:36,703 INFO [RendererSearchSender] Searching for Renderer devices
2012-07-26 17:01:36,703 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-07-26 17:01:36,778 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.211, timeout = 0
2012-07-26 17:01:37,308 INFO [ServiioConsole] Starting Serviio Console
2012-07-26 17:01:37,527 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-07-26 17:01:46,793 INFO [Messages] Loaded console message bundle for locale: en
2012-07-26 17:01:48,977 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-07-26 17:01:49,258 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-07-26 17:02:06,527 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-07-26 17:02:06,527 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 17:02:06,527 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 17:02:06,527 INFO [PlaylistMaintainerThread] Started looking playlist changes
2012-07-26 17:02:22,253 WARN [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2012-07-26 17:05:47,814 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-07-26 17:06:19,422 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-07-26 17:06:19,522 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-07-26 17:06:19,622 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2012-07-26 17:06:19,763 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-07-26 17:06:19,763 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 17:06:19,763 INFO [PlaylistMaintainerThread] Started looking playlist changes
2012-07-26 17:06:20,336 INFO [LibraryAdditionsCheckerThread] Added file 'epd-abraham.720p.mkv' (title: epd-abraham.720p) to Library
2012-07-26 17:06:20,661 INFO [LibraryAdditionsCheckerThread] Added file 'sov-mars.needs.moms.720p.mkv' (title: sov-mars.needs.moms.720p) to Library
2012-07-26 17:06:21,005 INFO [LibraryAdditionsCheckerThread] Added file 'obl-kesselschlacht-720p.mkv' (title: obl-kesselschlacht-720p) to Library
2012-07-26 17:06:21,321 INFO [LibraryAdditionsCheckerThread] Added file 'naziinvasion.avi' (title: naziinvasion) to Library
2012-07-26 17:06:21,575 INFO [LibraryAdditionsCheckerThread] Added file 'Panic.Button.2011.German.AC3.5.1.Dubbed.DL.720p.BluRay.x264-RCP.mkv' (title: Panic.Button.2011.German.AC3.5.1.Dubbed.DL.720p.BluRay.x264-RCP) to Library
2012-07-26 17:06:21,910 INFO [LibraryAdditionsCheckerThread] Added file 'roor-casino-jack-720p.mkv' (title: roor-casino-jack-720p) to Library
2012-07-26 17:06:22,304 INFO [LibraryAdditionsCheckerThread] Added file 'omp-sand.sharks-xvid.avi' (title: omp-sand.sharks-xvid) to Library
2012-07-26 17:06:22,725 INFO [LibraryAdditionsCheckerThread] Added file 'xf-brunablni.avi' (title: xf-brunablni) to Library
2012-07-26 17:06:27,419 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
You can see no 1080 mkv Video. In the same folder i have this Video noch.tausend.worte.2012.german.dl.1080p but Serviio can not see this. And now i have a new problem. My Samsung D Serie can not see the Folder from Serviio. Whene i push Serviio on my TV i see only a Load Screen but nothing more.
Edit: Now i have install Serviio 0.6.2 and all working fine with 1080 Video indexing:
2012-07-26 17:32:58,745 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-07-26 17:32:59,816 INFO [LibraryAdditionsCheckerThread] Added file 'epd-abraham.720p.mkv' (title: epd-abraham.720p) to Library
2012-07-26 17:33:01,664 INFO [LibraryAdditionsCheckerThread] Added file 'sov-mars.needs.moms.720p.mkv' (title: sov-mars.needs.moms.720p) to Library
2012-07-26 17:33:02,921 INFO [LibraryAdditionsCheckerThread] Added file 'Noch.Tausend.Worte.2012.German.DL.1080p.BluRay.x264-AJSMAN.mkv' (title: Noch.Tausend.Worte.2012.German.DL.1080p.BluRay.x264-AJSMAN) to Library
2012-07-26 17:33:03,332 INFO [LibraryAdditionsCheckerThread] Added file 'obl-kesselschlacht-720p.mkv' (title: obl-kesselschlacht-720p) to Library
2012-07-26 17:33:03,555 INFO [LibraryAdditionsCheckerThread] Added file 'naziinvasion.avi' (title: naziinvasion) to Library
2012-07-26 17:33:04,169 INFO [LibraryAdditionsCheckerThread] Added file 'Panic.Button.2011.German.AC3.5.1.Dubbed.DL.720p.BluRay.x264-RCP.mkv' (title: Panic.Button.2011.German.AC3.5.1.Dubbed.DL.720p.BluRay.x264-RCP) to Library
2012-07-26 17:33:05,128 INFO [LibraryAdditionsCheckerThread] Added file 'roor-casino-jack-720p.mkv' (title: roor-casino-jack-720p) to Library
2012-07-26 17:33:05,465 INFO [LibraryAdditionsCheckerThread] Added file 'omp-sand.sharks-xvid.avi' (title: omp-sand.sharks-xvid) to Library
2012-07-26 17:33:05,836 INFO [LibraryAdditionsCheckerThread] Added file 'xf-brunablni.avi' (title: xf-brunablni) to Library
You can see the 1080 Video can see Serviio 0.6.2. Serviio 1.0 can not see this. The problem is Serviio 1.0 and not my PC or TV.
erteerte1
Post Thu Jul 26, 2012 4:11 pm
I have exactly the same issue. Serviio doesn't see some avi files which I downloaded after the installation of Serviio 1.0. And the CPU usage is extremely high.
Post Thu Jul 26, 2012 4:14 pm
can you post ffmpeg -i of the files you cannot see?
Scoty
Post Thu Jul 26, 2012 4:46 pm
Sorry i use now 0.6.2 and i will not back to 1.0. I have use the half day for finding the issus but i can not see the problem. I hope the next Version will work better.
Post Thu Jul 26, 2012 5:53 pm
Scoty wrote: I hope the next Version will work better.
Not if I don't get information of what is wrong with it ;-)
jgasparine
Post Fri Jul 27, 2012 6:15 pm
I am having the same issue as Scoty. Since upgrading to 1.0, I have attempted to add a new 1080p MKV to my Library, but Serviio won't index it. It plays fine in VLC. I will probably downgrade to 0.6.2 next to see if it indexes there...
ffmpeg -i for the file is below
C:\Program Files\Serviio\lib>ffmpeg.exe -i f:\Batman_Begins.mkv
g-config
[matroska,webm @ 0189CC40] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeUnsupported encoding typeUnsupported encoding typeUnsuppor
ted encoding typeUnsupported encoding typeInput #0, matroska,webm, from 'f:\Batm
an_Begins.mkv':
    creation_time   : 2012-01-28 03:20:10
  Duration: 02:20:02.89, start: 0.000000, bitrate: 12438 kb/s
    Chapter #0.0: start 0.000000, end 219.000000
      title           : Embrace Your Fear
    Chapter #0.1: start 219.000000, end 451.000000
      title           : Carmine Falcone
    Chapter #0.2: start 451.000000, end 694.000000
      title           : More Than Just a Man
    Chapter #0.3: start 694.000000, end 975.000000
      title           : Not One of Your Good People
    Chapter #0.4: start 975.000000, end 1184.000000
      title           : This House
    Chapter #0.5: start 1184.000000, end 1459.000000
      title           : The Will to Act
    Chapter #0.6: start 1459.000000, end 1704.000000
      title           : Tragedy
    Chapter #0.7: start 1704.000000, end 1885.000000
      title           : You're Practice
    Chapter #0.8: start 1885.000000, end 2153.000000
      title           : What Do You Fear?
    Chapter #0.9: start 2153.000000, end 2304.000000
      title           : Crane's Mask
    Chapter #0.10: start 2304.000000, end 2474.000000
      title           : Lighten Up
    Chapter #0.11: start 2474.000000, end 2588.000000
      title           : Gotham Must Be Destroyed
    Chapter #0.12: start 2588.000000, end 2817.000000
      title           : Monastery Mayhem
    Chapter #0.13: start 2817.000000, end 2983.000000
      title           : Incorruptible Symbol
    Chapter #0.14: start 2983.000000, end 3206.000000
      title           : Nest of Bats
    Chapter #0.15: start 3206.000000, end 3355.000000
      title           : Welcome Home
    Chapter #0.16: start 3355.000000, end 3482.000000
      title           : Applied Sciences
    Chapter #0.17: start 3482.000000, end 3811.000000
      title           : Gordon's Visitor
    Chapter #0.18: start 3811.000000, end 3953.000000
      title           : Does It Come in Black?
    Chapter #0.19: start 3953.000000, end 4118.000000
      title           : Secrets of Scary People
    Chapter #0.20: start 4118.000000, end 4285.000000
      title           : Rattle the Cages
    Chapter #0.21: start 4285.000000, end 4399.000000
      title           : Missing Weapon
    Chapter #0.22: start 4399.000000, end 4576.000000
      title           : More Inside
    Chapter #0.23: start 4576.000000, end 4790.000000
      title           : Do I Look Like a Cop?
    Chapter #0.24: start 4790.000000, end 5034.000000
      title           : Work to Do
    Chapter #0.25: start 5034.000000, end 5342.000000
      title           : Arkham's Basement Secrets
    Chapter #0.26: start 5342.000000, end 5556.000000
      title           : Winged Backup
    Chapter #0.27: start 5556.000000, end 5869.000000
      title           : Tumbler on the Roof
    Chapter #0.28: start 5869.000000, end 6033.000000
      title           : The Monster of Yours
    Chapter #0.29: start 6033.000000, end 6308.000000
      title           : Dual Identities
    Chapter #0.30: start 6308.000000, end 6572.000000
      title           : Purging Fire
    Chapter #0.31: start 6572.000000, end 6689.000000
      title           : Inferno Rescue
    Chapter #0.32: start 6689.000000, end 6889.000000
      title           : Spread the Word: Panic
    Chapter #0.33: start 6889.000000, end 7091.000000
      title           : What Defines Me
    Chapter #0.34: start 7091.000000, end 7314.000000
      title           : Catching a Train
    Chapter #0.35: start 7314.000000, end 7501.000000
      title           : Not Kill But Not Save
    Chapter #0.36: start 7501.000000, end 7566.000000
      title           : New Owner
    Chapter #0.37: start 7566.000000, end 7758.000000
      title           : This Is Your Mask
    Chapter #0.38: start 7758.000000, end 7857.000000
      title           : Calling Card
    Chapter #0.39: start 7857.000000, end 8402.895000
      title           : End Credits
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: truehd, 48000 Hz, 5.1(side), s32 (default)
      title           : FraMeSToR TrueHD 5.1
    Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle (default)
      title           : ENG SDH
    Stream #0:3(chi): Subtitle: hdmv_pgs_subtitle
      title           : CHI
    Stream #0:4(fre): Subtitle: hdmv_pgs_subtitle
      title           : FRA
    Stream #0:5(jpn): Subtitle: hdmv_pgs_subtitle
      title           : JPN
    Stream #0:6(kor): Subtitle: hdmv_pgs_subtitle
      title           : KOR
    Stream #0:7(por): Subtitle: hdmv_pgs_subtitle
      title           : POR
    Stream #0:8(spa): Subtitle: hdmv_pgs_subtitle
      title           : SPA
Post Fri Jul 27, 2012 6:40 pm
I've now fixed this for 1.0.1... looks like FFmpeg bug
barlet
Post Sat Jul 28, 2012 3:44 pm
I had the issue of cpu running at 100% when I installed version 1 of Serviio. Has this been fixed as well in version 1.0.1? I do not feel like putting in all the online links again as I had to do when I reverted to version 0.62. I had in mind of paying for it as up till 0.62 it was the best programm of the sort around.
Post Sat Jul 28, 2012 5:03 pm
I do not see 100% CPU on my system. 1.0 had to re-add everything to your library, that's probably why the initial CPU usage. To try to fix it, if it is a bug, I'll need a detailed log of what is going on during the high CPU usage.
Romfrosk
Post Sat Jul 28, 2012 6:44 pm
I'm experiencing the same issue.
I've uninstalled, removed any traces/libraries and such.
I'm rebuilding the library now, but it will take some time (6 TB of media to go through)
I will update my status as soon as it's done
Could not find any errors in the log. but the console locked itself up now and then.
Romfrosk
Post Mon Jul 30, 2012 5:45 pm
After reinstalling a fresh 1.0 install, the same issue appeared.
it stops updating the library on the same episode of Rome.
Tried to remove Rome from the library and all the other files were added.
Added Rome to the library again and once more it stops on the same file.
Here is the MediaInfo of that episode.
Unique ID                                : 202640924582993407834869945308017476676 (0x987338F338C85F09A20F6AD6378E4444)
Complete name                            : E:\Serier\Rome\Season 2\Rome.S02E04.The.Tortoise.and.the.Hare.720p.HDTV.x264-YYeTs.mkv
Format version                           : Version 1
File size                                : 1.08 GiB
Duration                                 : 55mn 29s
Overall bit rate                         : 2 782 Kbps
Encoded date                             : UTC 2007-02-08 07:03:12
Writing application                      : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library                          : libebml v0.7.7 + libmatroska v0.8.0
Attachment                               : Yes
Format profile                           : Main@L5.1
Format settings, ReFrames                : 1 frame
Duration                                 : 55mn 29s
Bit rate                                 : 2 342 Kbps
Nominal bit rate                         : 2 691 Kbps
Bits/(Pixel*Frame)                       : 0.106
Stream size                              : 930 MiB (84%)
Writing library                          : x264 core 54 svn-620M
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=290 / keyint_min=23 / scenecut=40(pre) / rc=2pass / bitrate=2691 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40
Duration                                 : 55mn 29s
Bit rate                                 : 384 Kbps
Stream size                              : 152 MiB (14%)
Text
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Language                                 : Chinese
I've added the Logfile.
It seems it has added the file after what i can read in the log, but "library status" still says "Checking new files 4 (Rome.S02E04+++)
Serviio.rar
(249.39 KiB) Downloaded 596 times
Post Mon Jul 30, 2012 6:26 pm
the log shows the file has been added. The fact that it shows it in the console means it's the last added file and will be there visible until a new file is found.
Romfrosk
Post Mon Jul 30, 2012 7:27 pm
Tried to remove Episode 4 and 5 from the library, and now it adds all the other episodes as it should.
Even the freezing of the application stopped after removing them.
I'll look into why these files made the library not add more files.
Any tips?
(it worked fine in 0.6.2)
bazzilla
Post Tue Jul 31, 2012 9:19 pm
zip wrote:can you post ffmpeg -i of the files you cannot see?
Hi! I have the same problem: serviio cannot see all mkv file.
Here is the ffmpeg -i of one of missing mkv file:
g-config
[matroska,webm @ 002CBC20] Unsupported encoding typeUnsupported encoding typeUns
upported encoding typeInput #0, matroska,webm, from 'F:\video\1080p\example.1080p.mkv':
    creation_time   : 2012-07-12 09:47:23
  Duration: 01:39:32.03, start: 0.000000, bitrate: 11433 kb/s
    Chapter #0.0: start 0.000000, end 564.856000
      title           : 00:00:00.000
    Chapter #0.1: start 564.856000, end 1207.123000
      title           : 00:09:24.856
    Chapter #0.2: start 1207.123000, end 1853.060000
      title           : 00:20:07.123
    Chapter #0.3: start 1853.060000, end 2402.317000
      title           : 00:30:53.060
    Chapter #0.4: start 2402.317000, end 2926.882000
      title           : 00:40:02.317
    Chapter #0.5: start 2926.882000, end 3621.743000
      title           : 00:48:46.882
    Chapter #0.6: start 3621.743000, end 4216.421000
      title           : 01:00:21.743
    Chapter #0.7: start 4216.421000, end 4758.712000
      title           : 01:10:16.421
    Chapter #0.8: start 4758.712000, end 5433.803000
      title           : 01:19:18.712
    Chapter #0.9: start 5433.803000, end 5972.032000
      title           : 01:30:33.803
    Stream #0:0: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.9
      title           : HDRip
    Stream #0:1(ita): Audio: ac3, 48000 Hz, 5.1(side), s16, 448 kb/s (default)
      title           : Ac3 ITA
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s
      title           : Ac3 Eng
    Stream #0:3(ita): Subtitle: dvd_subtitle (default)
      title           : Forced
    Stream #0:4(ita): Subtitle: dvd_subtitle
      title           : Ita
    Stream #0:5(eng): Subtitle: dvd_subtitle
      title           : Eng
I've installed serviio 1.0 on Windows 7 SP1.
[Update] I've temporaly solved replacing ffmpeg.exe in serviio/lib folder with a newer executable.
Post Tue Jul 31, 2012 9:27 pm
thanks, I've fixed this and will release in 1.0.1 soon.
Users browsing this forum: Baidu [Spider], Google [Bot] and 39 guests
