[SOLVED] Problem installing Serviio 1.0
centrius
Post Fri Jul 27, 2012 9:20 am
Hi all,
I just reasembled my computer and I am in the process to re-install all my programs. How ever, i am having huge problems installing Serviio. Every time i try install it the install consol asks if u have Java 6 and then asks me to dl it via the consol, but i always get a time out at this point. When i skip the part about the Java 6, i install the program, but when i start serviio i get an error msg saying that i need Java. I have installed Java 7.5 (or the newest one).
Any tips?
Post Fri Jul 27, 2012 12:51 pm
Re: Problem installing Serviio 1.0
uninstal all Java versions you have, intall the newest Java from Oracle and then install Serviio (it should not ask you to download Java any more at this point)
centrius
Post Fri Jul 27, 2012 9:34 pm
Thx, after a bit of try en error, it finaly worked
b00sh00
Post Mon Jul 30, 2012 2:08 am
Re: [SOLVED] Problem installing Serviio 1.0
I running windows vista 64. I tried the advice of removing previous java, reinstalling from oracle and then installing serviio., It still does not work.
I receive this message:
"No JVM found on system
Please define exe4j_java_home to point to a install 64-bit jdk or jre"
Please help.
Thank you.
corebox
Post Mon Jul 30, 2012 8:19 am
Im having exact same error. Windows 7 x64, Java 7 installed :|
cheers \o/
Post Mon Jul 30, 2012 8:29 am
You sure you installed the 64-bit version of Java?
corebox
Post Mon Jul 30, 2012 8:43 am
OK, i unintalled all previous Java updates, downloaded manulay from http://java.com/en/download/manual.jsp 64bit version and seems to be working now. But not apearing on TV as it used to be (with ver 0.6.2).. Could be up to my PC tho since working well on 2nd pc (1.0 version aswell). Tx
Post Mon Jul 30, 2012 8:51 am
corebox wrote:OK, i unintalled all previous Java updates, downloaded manulay from http://java.com/en/download/manual.jsp 64bit version and seems to be working now. But not apearing on TV as it used to be (with ver 0.6.2).. Could be up to my PC tho since working well on 2nd pc (1.0 version aswell). Tx
Try to bind it to your IP in the console
Users browsing this forum: Google [Bot] and 176 guests
