handling 2D and 3D film versions
ntfreak
Post Fri Jul 27, 2012 2:01 pm
Firstly thanks for a great piece of software :-)
Just wondering the best way to manage 2D/3D versions of the same film, so the user knows which version is which ?
I have the following files in the matching directories, however only the online metadata for the 2D version is found.
Toy Story 3 3D (2010).mp4
Toy Story 3 (2010).mp4
Because the metdata for the 3D version is not found the file does not show up in the 'Movies' catergory. Any way around this issue?
Any help greatly appreciated.
Spen
Post Fri Jul 27, 2012 6:02 pm
Re: handling 2D and 3D film versions
you could put them in different folders, like:
/movies/toy story 3.avi
/movies/3d/toy story 3.avi
ntfreak
Post Sun Jul 29, 2012 9:05 pm
While that does indeed get metadata for both files, i now have two entries for Toy Story 3.
For presentation i have 'Movies' set to 'Display Contecnt Only'
How is the user to know which file is the 3D version of example?
Cheers
Spen
Post Sun Jul 29, 2012 9:11 pm
You can't, unless you go there via the Folders category. It's the same movie, thus the same set of metadata.
ntfreak
Post Mon Jul 30, 2012 12:05 pm
Thanks,
As you point out the issue really relates to the online metadata being the same for both the 2D/3D versions of a film.
So is there any way to get serviio to use the online metadata but give the user the option to override locally ?
For example just the Title.
Cheers
Spen
Post Mon Jul 30, 2012 12:28 pm
not a the moment, unless you want to do it ll locally using XBMC .nfo metadata files (but you will not be able to use the online metadata functionality)
ntfreak
Post Mon Jul 30, 2012 1:25 pm
Ah OK, that looks like a possible option.
Cheers
Spen
Users browsing this forum: No registered users and 197 guests
