Serviio on Debian
W4RH4WK
Post Tue Jul 31, 2012 11:23 pm
Serviio on Debian
Hello there,
i just installed Serviio on a fresh / clean Debian Squeeze and encountered some issues
First. Is it normal that the serviio-console does not work with the current, stable default-jre package from the official debian repo?
Secound. i can't get transcoding to work. i didn't change the profile.xml file but followed the advice that the ffmpeg version from the debian repo is to old to work with serviio propperly. so i built the latest version from source
./configure --enable-version3 --enable-postproc --enable-avfilter --enable-libdc1394 --enable-libgsm --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-runtime-cpudetect --enable-vaapi --disable-vdpau --enable-memalign-hack --enable-pthreads --enable-bzlib --enable-zlib --enable-shared --enable-static --disable-debug --enable-gpl
is what i used for ffmpeg.
according to my point of view, ffmpeg works correctly by itself, but serviio doesn't transcode.
When i install serviio on my windows system and add the same files from the debian system to it's shared folder, everything (even transcoding) works fine. so i guess even the files and my TV is alright.
Any ideas what i can do to get transcoding to work?
Post Wed Aug 01, 2012 9:13 am
Re: Serviio on Debian
post detaild log of failed transcoding
W4RH4WK
Post Wed Aug 01, 2012 11:50 am
of course:
http://pastebin.com/J1rWX98t
here is the complete log file, the first few entries might have been added when i used the ffmpeg version from the official repo, so please focus on the last entries (there for i used the latest version of ffmpeg)
i guess my problem refers to these lines
2012-08-01 01:14:04,723 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-08-01 01:14:12,089 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file /tmp/Serviio/transcoding-temp-2-sony2010-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
ffmpeg from the commandline works
# whereis ffmpeg
ffmpeg: /usr/src/ffmpeg/ffmpeg.c /usr/src/ffmpeg/ffmpeg.d /usr/src/ffmpeg/ffmpeg.o /usr/src/ffmpeg/ffmpeg /usr/local/bin/ffmpeg
# ffmpeg -version
ffmpeg version N-43100-gd1dad7c
built on Aug  1 2012 01:08:30 with gcc 4.4.5 (Debian 4.4.5-8)
configuration: --enable-version3 --enable-postproc --enable-avfilter --enable-libdc1394 --enable-libgsm --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-runtime-cpudetect --enable-vaapi --disable-vdpau --enable-memalign-hack --enable-pthreads --enable-bzlib --enable-zlib --enable-shared --enable-static --disable-debug --enable-gpl
libavutil      51. 66.100 / 51. 66.100
libavcodec     54. 46.100 / 54. 46.100
libavformat    54. 22.100 / 54. 22.100
libavdevice    54.  2.100 / 54.  2.100
libavfilter     3.  5.101 /  3.  5.101
Post Wed Aug 01, 2012 11:54 am
Can you turn on detailed logging, see my sig and then re-do it. The log will then contain the ffmpeg command, which you can then run manually to get the real reason for the error.
W4RH4WK
Post Wed Aug 01, 2012 12:18 pm
i enabled detailed logging, started the server and tried to watch a video which needs to be transcoded.. i don't know why, but now it works.
http://pastebin.com/EZzQggYA this is the detailed logfile.
i disabled detailed logging, and it still works..
i don't the reason why it works now, so would you mind having a look at the log file, maybe this will give a hint what's the difference. My only guess is a whole system restart fixed the problem. i installed the server yesterday, and couldn't get transcoding to work even with a self compiled ffmpeg. Might serviio cache the location of ffmpeg the first time it starts? because the self compiled version is located in another directory than the precompiled (precompiled: /usr/bin | selfcompield: /usr/local/bin)
any ideas?
thank you for the help so far
Users browsing this forum: No registered users and 196 guests
