Eliminating Series From Title Listing
StormyKnight
Post Thu Aug 02, 2012 6:27 am
Firstly, Serviio is a great program & is by far the best I have found for what I need to do, thank you to all involved! :)
I wish to remove my TV Series from the TITLE virtual folder (I think this is the right terminology for this folder)
Reason: I think the best way to find a movie is using the TITLE folder, the best way to find a TV Series is the SERIES folder, however the TITLE folder contains both movies & tvshow titles!
    My setup
  • Serviio is on a windows server
  • Over 100 Movies, 100 tv shows = 3000 episodes
  • Source files are on a ReadyNas Duo (Yes I worked out how to get these files to be seen - thanks to the FAQ :D )
  • All source files have a XBMC nfo (courtesy of MediaCompanion)
  • DLNA Devices - XBMC (Openelec), Samsung TV, Samsung S3 Phone, Android GPS
Is there any way to configure Serviio to do this?
Cheers
Richard
My Setup: Serviio running on XP Laptop, 2 x ReadyNas Duo Networked Drives, XBMC (openelec) on AsRock Ion 3D (Loungeroom), Samsung Smart TV (Bedroom), Samsung S3 Phone using Bubble UPnP.
I am also a MediaCompanion Developer (Opensource XBMC art collector, nfo creator & media file renamer).
Post Thu Aug 02, 2012 4:08 pm
Re: Eliminating Series From Title Listing
not presently, there is an open ticket for this
StormyKnight
Post Fri Aug 03, 2012 4:10 am
As a work around I have created folders A-Z & put my movies in there. That way I can just use FOLDERS to quickly locate my movies & Series.
Cheers
Users browsing this forum: No registered users and 243 guests
