Upgrade from 0.62 to 1.0 made Serviio undetectable in PS3/LG
BurnServ
Post Wed Aug 01, 2012 10:59 pm
Hello.
I've updated to 1.00 version today and after the update my PS3 and my LG TV stopped detecting my Serviio Server.
I've tested everything from binding the IP, push the Serviio service down in starting order or manually set up the firewall exceptions.
Nothing works. The serviio console detects a MediaRender (using a generic DLNA profile) instead the actual TV (as it used to be) and the TV doesn't detect the server.
Using the Device Spy i don't have any problems detecting the TV. (a 47LW980S-ZA)
Any ideas on what may be the problem?
Post Wed Aug 01, 2012 11:14 pm
Re: Upgrade from 0.62 to 1.0 made Serviio undetectable in PS
post detailed log please
BurnServ
Post Wed Aug 01, 2012 11:51 pm
Added the log.
If you need more ask. (The rest is too big, added files information)
(46.93 KiB) Downloaded 676 times
Post Thu Aug 02, 2012 4:10 pm
can you try disabling the Hamachi network interace?
BurnServ
Post Thu Aug 02, 2012 5:33 pm
Disabled it (disabled the interface, removed the profiles, removed the bound IP stopped the server and started it again) and no changes. Still the same behavior.
EDIT: I tried to disable all other interfaces and leaving only the one i need and i still get the same results. (Although the search for devices seem to be a bit quicker)
Post Thu Aug 02, 2012 7:18 pm
Can you install DeviceSpy (Intel tools, my signature) on another machine and run it - can you see Serviio in there?
BurnServ
Post Thu Aug 02, 2012 8:16 pm
zip wrote:Can you install DeviceSpy (Intel tools, my signature) on another machine and run it - can you see Serviio in there?
Nop, it doesn't appear. Maybe a problem with the router? (strange that this didn't happen before)
Post Thu Aug 02, 2012 8:26 pm
might be router or firewall on your Serviio machine
BurnServ
Post Thu Aug 02, 2012 8:54 pm
zip wrote:might be router or firewall on your Serviio machine
Deactivated the firewall and nothing happened.
There was no changes in the router since i used 0.62 so i find it weird that I'm having this problem.
Update: I took a restart on the console/server but it appears that shutting down the the firewall made it available again.
Any idea why the firewall is messing with this new version of Serviio?
Post Thu Aug 02, 2012 9:16 pm
no idea, it's using the same ports. Maybe a Windows update?
Post Fri Aug 03, 2012 7:58 pm
Restart your rooter.
bkraptor
Post Wed Aug 08, 2012 4:27 pm
I also had some problems when upgrading from 0.62 to 1.0. After upgrading to 1.0, some files that were previously visible and also playable on a samsung 32D5000 suddently stopped appearing in the list. Enabling logging showed that for those files an error was returned stating that the file format was invalid. Rolling back to 0.62 fixed the issue.
