Using with Mac and Samsung Galaxy 3S
amcginn
Post Tue Jul 31, 2012 8:03 pm
On my samsung phone it asks for the server name and address. Where would I find that information on my Mac now that I have Serviio set up there?
Thank you
koan00
Post Wed Aug 01, 2012 7:13 pm
Re: Using with Mac and Samsung Galaxy 3S
Which app are you using on your phone? Web browser? ServiiDriod? ServiiGo?
Are you accessing serviio from your LAN, or remotely?
First find your Ip Address: http://osxdaily.com/2010/11/21/find-ip-address-mac/
You will also need to enable the port in the firewall if you have it enabled.
For ServiiGo, the port is 23424
amcginn
Post Thu Aug 02, 2012 9:55 pm
I have ServiiDroid on my phone.
Accessing remotely.
The firewall is off for the sake of trying to use this.
Post Thu Aug 02, 2012 10:07 pm
To use ServiiDroid (or ServiiGo) remotely you probably need to setup a Dynamic DNS.
http://www.serviio.org/component/conten ... ote_access
Has some help (note port 23423 is for ServiiDroid and 23424 is for ServiiGo)
This will give you an address which will point to your router from the Internet which you can type into the address box. You will also have to forward the required ports from your router to your mac.
Users browsing this forum: Baidu [Spider] and 213 guests
