Panasonic VT50 does not play mpg files (MPEG2-PS)
Sixstring
Post Thu Aug 02, 2012 10:05 pm
Hello, i am new to serviio and use it with my Panasonic VT50 Series TV. When i try to play *.mpg files (MPEG2-PS) the TV sys "wait a moment" and after a while it stops trying to play that file. If i put the same *.mpg file on an USB stick the TV can play it without a problem. Other files like avi, wmv, mp4, flv work wit serviio and the VT50, but these are not MPEG2-PS but MPEG2-TS or other. Can anyone help me with this?
Post Thu Aug 02, 2012 10:12 pm
Re: Panasonic VT50 does not play mpg files (MPEG2-PS)
Sixstring
Post Thu Aug 02, 2012 10:41 pm
This is what i get with ffmpeg. This *.mpg file doesn't work:
FFmpeg version SVN-r19159-Sherpya, Copyright (c) 2000-2009 Fabrice Bellard, et a
l.
libavutil 50. 3. 0 / 50. 3. 0
libavcodec 52.30. 2 / 52.30. 2
libavformat 52.34. 0 / 52.34. 0
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 0. 5. 0 / 0. 5. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Jun 12 2009 04:25:02, gcc: 4.5.0 20090517 (experimental)
Input #0, mpeg, from 'video.mpg':
Duration: 00:02:47.56, start: 0.708022, bitrate: 1421 kb/s
Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288 [PAR 178:163 DAR 195
8:1467], 1150 kb/s, 25 tbr, 90k tbn, 25 tbc
Stream #0.1[0x1c0]: Audio: mp2, 44100 Hz, stereo, s16, 224 kb/s
Here is another *mpg file which works with serviio and the TV:
l.
Input #0, mpeg, from 'test.mpg':
Duration: 00:01:14.00, start: 0.106122, bitrate: 758 kb/s
Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 512x352 [PAR 1:1 DAR 16:11],
104857 kb/s, 25 tbr, 90k tbn, 25 tbc
Stream #0.1[0x1c0]: Audio: mp2, 44100 Hz, stereo, s16, 96 kb/s
Post Thu Aug 02, 2012 11:02 pm
ok, and which profile are you using?
Sixstring
Post Thu Aug 02, 2012 11:24 pm
At first i used the normal "Panasonic Viera" profile. Now i use the following profile which solves some problems but not the one with those *.mpg files:
<Profile id="112" name="Panasonic Viera w/ AVI, MOV, MP4, 3GP (by huyz)" extendsProfileId="1">
<!-- remux DTS/FLAC/LPCM in MKV/MP4 to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="lpcm"/>
<!-- huyz: ST30 manual says AAC should work (and it does for MKV) but transcoding is needed for our .mp4 (and the equivalent .mov) files -->
<Matches container="mp4" vCodec="h264" aCodec="aac"/>
<!-- Remux all h264 video to MPEG-TS stream -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
<!-- huyz: do all AVIs, including mpeg4 (Xvid) and msmpeg4 video codecs
<Matches container="avi"/>
<Matches container="mp4" vCodec="mpeg4" /> <!-- huyz: this Panasonic doesn't support mpeg4 -->
<Matches container="asf" />
<Matches container="flv" />
<Matches container="ogg" />
<Matches container="3gp" />
<Audio targetContainer="mp3">
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="adts" />
</Audio>
Post Fri Aug 03, 2012 7:41 pm
This file format is probably delivered in native format.
Don't know what is the difference.(resolution and aspect ratio ?)
Could you provide MediaInfo tool result ?
Post Fri Aug 03, 2012 8:11 pm
The Viera profiles in 1.0 have this line which should transcode it to mpeg2:
<Matches container="mpeg" vCodec="mpeg1video" />
Can you confirm in the log this is happening?
