problem with eyetv media
jooooost
Post Thu Aug 02, 2012 8:10 pm
Dear all,
I would like to address a problem that has already been posted (viewtopic.php?f=11&t=4210&p=27928&hilit=eyetv#p27821) but as far as I understand has not yet been solved.
I run Serviio 0.6.2 on MAC OSX Version 10.6.8
Using EyeTV (3.5.5) I saved a few TV clips and wanted to view them on my Sony KDL-32EX725.
The problem is that some of the saved clips will play on my TV and others will not.
To provide some information to solve the problem I started ffpeg -i once with a clip that can be played (i called it video-good.mpg) and one clip that is refused to play (I called video-bad.mpg). Both clips are just plain output of EyeTV.
You can find the output here in the addendum.
Any ideas how I can solve the problem?
Best Regards
Jochem
Addendum
jupiter-lan:Test pat$ ./ffmpeg -i video-good.mpg
built on Dec 14 2011 01:44:37 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[mpegts @ 0x1004c00] max_analyze_duration 5000000 reached at 5016000
[NULL @ 0x100c400] start time is not set in estimate_timings_from_pts
[mpegts @ 0x1004c00] PES packet size mismatch
Last message repeated 1 times
Input #0, mpegts, from 'video-good.mpg':
Duration: 01:32:32.16, start: 76589.595989, bitrate: 4263 kb/s
Program 514
service_name : ?ZDF
service_provider: ?ZDFmobil
Stream #0:0[0x221]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 704x576 [SAR 16:11 DAR 16:9], 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x222](deu): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
Stream #0:2[0x227](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:3[0x223](mis): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, mono, s16, 96 kb/s
Stream #0:4[0x22b]: Unknown: none ([5][0][0][0] / 0x0005)
Program 515
service_name : ?3sat
Program 517
service_name : ?neo/KiKa
Program 516
service_name : ?ZDFinfokanal
jupiter-lan:Test pat$ ./ffmpeg -i video-bad.mpg
ffmpeg(12208) malloc: *** mmap(size=208896) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
Last message repeated 22 times
[mp1 @ 0x105d800] Header missing
Last message repeated 2 times
[mpeg2video @ 0x1009800] mpeg_decode_postinit() failure
Last message repeated 13 times
[mpeg2video @ 0x1009800] skipped MB in I frame at 20 32
[mpeg2video @ 0x1009800] Warning MVs not available
[mpeg2video @ 0x1009800] concealing 44 DC, 44 AC, 44 MV errors
[NULL @ 0x100a800] start time is not set in estimate_timings_from_pts
[NULL @ 0x100d600] start time is not set in estimate_timings_from_pts
[NULL @ 0x105f400] start time is not set in estimate_timings_from_pts
Seems stream 5 codec frame rate differs from container frame rate: inf (1/0) -> 90000.00 (90000/1)
Input #0, mpegts, from 'video-bad.mpg':
Duration: 26:46:37.20, start: 73177.162711, bitrate: 32 kb/s
Program 262
Program 225
Program 16387
Program 16413
Program 514
service_name : ?ZDF
Program 515
Stream #0:0[0x231]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 704x576 [SAR 16:11 DAR 16:9], 15000 kb/s, 27.40 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x232]: Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
Stream #0:2[0x237](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream #0:3[0x233](mis): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16, 192 kb/s
Program 516
Program 517
service_name : ?neo/KiKA
No Program
Stream #0:5[0xe11]: Video: mpeg2video, 90k tbr, 90k tbn
Stream #0:6[0xe17]: Audio: mp1, 0 channels, s16
Stream #0:7[0xe12]: Audio: mp3, 0 channels
Serviio 0.6.2 | Mac OS 10.6.8 | Zyxel 500 MB Powerline-Ethernet | Sony KDL-32EX725 and Sony KDL-46EX729
Post Thu Aug 02, 2012 8:17 pm
Re: problem with eyetv media
from the output you can see there are a lot of errors in the second file's output, mostly related to the mpeg2 video stream.
jooooost
Post Fri Aug 03, 2012 7:38 am
Dear Petr,
thank you for the immediate answer. For me there is still one question left:
Why do ohter renderers like the EyeTV-Software itself or the VLC-player on my mac DO play BOTH files? They seem to have no problems with the failures in the file "video-bad.mpg".
Is it possible to change the settings off ffmpeg in a way so that it is also as fault-tolerant as the decoders used by EyeTV or VLC?
I think this question might become even more relevant as more users will use serviio for serving recorded TV-clips (received over the air so maybe with some failures in the stream) in their Home-Network.
(My wife needs here "CSI:Miami" daily - I have to find a solution... :D )
Thanks for any suggestions or ideas
Jochem
Post Fri Aug 03, 2012 10:28 am
All good and bad files are visible on serviio library ?
Does the bad file is delivered in native format or transcoded by ffmpeg ? See detailed serviio log file.(See signature links)
jooooost
Post Tue Aug 07, 2012 12:09 pm
yes both files (video-good.mpg and video-bad.mpg) are visibile in the serviio-library. They are also visible in the directory on the TV-screen and can be attached via the Home Network using DLNA. Up to here everything looks normal to me.
Both files are delivered in native format without using the transcoding-option.
The user experience is as follows: The name of both files is displayed in the directory on the TV screen. Both of them have preview pictures. When clicking on the file-names for both files the spinning wheel in the upper-left-corner of the TV shows up (the Sony "please wait"-Icon). After a few seconds the spinning wheel disappaers. Up to this point everything looks normal for both files. The difference appears after this point. While the file video-good.mpg starts to play for the file video-bad.mpg the TV-screen just stays black. When I press the "Info"-button on the TV it even shows me for both files the correct total lenght of the clip. But for video-bad.mpg it does not start the video...
Last weekend I made some experiments with more captured TV-clips and I get more and more convinced that the problem is closely related to the question of "fault-tolerance" (see posting before) regarding the videostream.
I will come back with some detailed serviio log file like you asked for. This may take some days...
Up to this point: Any more suggestions to solve the problem?
Cheers Jochem
jooooost
Post Tue Aug 07, 2012 6:09 pm
Ok, I started serviio in DEBUG mode.
Then I first tried to start the file named "video-bad.mpg" on my TV. I did not start.
Then I tried to start the file named "video-good.mpg". That worked fine.
In the attachment you will find the corresponding log-file in DEBUG mode.
Does this help to come closer to a solution for the problem?
(106.74 KiB) Downloaded 548 times
