help: serviio console problems.
smaqbool
Post Fri Aug 03, 2012 1:36 am
I've been using Serviio for a few months now, one of the best apps for streaming to TV and PS3 i've ever used. I recently changed my router and since I don't think anything else has changed.
Serviio Console seems to open (in the services tab on task manager) but it doesn't appear on the screen. I've tried uninstall serviio, deleting all registry data and, rebooting the PC and then reinstalling but I get the same problem. My TV and Playstation wouldn't recognize serviio so I ran it as administrator and they pick up the server for serviio but none of the files that I am sharing.
I can't get serviio console to appear on the screen so I can't check anything or update the folder list.
Any help with this would be much appreciated.
Post Fri Aug 03, 2012 4:07 pm
Re: help: serviio console problems.
try to install a new Java version (and remove all previous versions)
smaqbool
Post Fri Aug 03, 2012 8:33 pm
Hey thanks for the help.
I was uninstalling previous versions of Java and had one left when Serviio Console just popped up, currently working with just Java 6 Update 29.
the help is much appreciated, hope the info i've given helps someone else aswell.
AWESOME APP!
Users browsing this forum: Google [Bot] and 277 guests
