Serviio 1.0 will not Show all files?
• Page 2 of 2 • 1, 2
Whene coming 1.0.1?
Re: Serviio 1.0 will not Show all files?
Not sure if this is the same issue others are having but after I added the paths in the Library the folders show up on my DLNA device but no files. When I click Force Refresh in the console and check status it just shows red dots for both Checking New Files and Checking updates. I previously had no issues with 0.6.2. I like the concept of 1.0, and plan to purchase Pro version, if it works. Any suggestion? Will 1.0.1 solve this problem?
rlbrown wrote:Not sure if this is the same issue others are having but after I added the paths in the Library the folders show up on my DLNA device but no files. When I click Force Refresh in the console and check status it just shows red dots for both Checking New Files and Checking updates. I previously had no issues with 0.6.2. I like the concept of 1.0, and plan to purchase Pro version, if it works. Any suggestion? Will 1.0.1 solve this problem?
Post detailed log. This looks like access rights issue (perhaps you run the Serviio service as a different user before?)
Petr
Help translate Serviio
Here is what I get.
2012-08-03 21:45:38,996 INFO [ServiioConsole] Starting Serviio Console
2012-08-03 21:45:39,050 INFO [ServiioConsole] Connecting to Serviio REST on xxx.xxx.x.x:23423
2012-08-03 21:45:49,177 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-08-03 21:45:59,207 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-03 21:45:59,208 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.console.ServiioConsole.setupConsoleSettings(ServiioConsole.java:120)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:103)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-08-03 21:45:59,211 INFO [ServiioConsole] Leaving Serviio Console
... and I have port forwarding set on router for 23423
Not sure if you need port forwarding. Are you running the console in locally with the server? Either the service is not running or the console cannot connect to the 23423 port on localhost.
Petr
I am running Serviio on a Synology DS411 NAS using Windows computer to configure. I have added the following line to the serviio-console VMOPTIONS file: -Dserviio.remoteHost=xxx.xxx.x.x (the IP address for my NAS). Does that help debug the issue?
i also had some files not showing up, nore the folder that contained them.. added another file (1 that did show up in another folder), now folder appears but only that newly added file is in it.. i think it has something to do with the embedded subtitle format of the files not showing, they are in S_HDMV/PGS format.. removed them with mkvmerge and now all files show up
Windows 7 x64, Serviio 1.0
With Version 1.01 ist the problem solved and Serviio working fine now.
