0.6.2 to 1.0 upgrade causes online plug-ins to break
hwmonkey
Post Sat Aug 04, 2012 3:16 pm
I have been running 0.6.2 for quite some time. I resolved some transcoding issues with my Sony BDP last month making me even more thrilled with it. 1.0 came out and I waited a few days before upgrading to see if people posted any issues. None found, so I proceeded.
This is running on ubuntu.
I upgraded, keeping my library directory, config file, and plug-ins directory. From the console, I see my online sources. The ones that I had disabled have lines through them (new GUI style with 1.0). If I click edit, the "Check stream URL" is greyed out. If I add one, the button is functional. When I then connect from my client, none of the online streams are listed. I have clicked refresh library. iLive was working as was ABC. I think hulu was also. Anyway, here is part of the log.
2012-08-04 11:00:51,169 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ILive): The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.RuntimeException: The operation took more than 30000 ms and has been cancelled.
   at org.serviio.library.online.PluginExecutionProcessor.execute(PluginExecutionProcessor.java:64)
   at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
   ... 4 more
2012-08-04 11:02:29,638 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEa1a5cabRd.add8bbcqcjaEdJapccaNbB-bqhtMk-c0-ZnMDrDq1Cxp&aifp=sll02152008&slist=hulu7/156/60099156;.international=false&hgt=OZU7Pvs7j27-nhteNno7wo3KoqKeU3IIIofmSmyTRTBsCTY4BzF9i73g5f-qTXHRyk5HFfSQc84U-baQzhxa_B3XAxudOhoZ76XnjZzcBeNsCNvuKDNgQiko85nMlcBqlwYcmJA0sTS08J3rMpM5xsxIIGVv_Ge44pbIYJovyLfOL9KFmAi5YqjGESyMWzQUDQM_ildbzTd9KLivHEYuzzvhbj7uffcS7C1wQkk1j_r70q8q7FyXWdwEnF0JOwcv&hgt_ver=331370278 app=ondemand?auth=daEa1a5cabRd.add8bbcqcjaEdJapccaNbB-bqhtMk-c0-ZnMDrDq1Cxp&aifp=sll02152008&slist=hulu7/156/60099156;.international=false&hgt=OZU7Pvs7j27-nhteNno7wo3KoqKeU3IIIofmSmyTRTBsCTY4BzF9i73g5f-qTXHRyk5HFfSQc84U-baQzhxa_B3XAxudOhoZ76XnjZzcBeNsCNvuKDNgQiko85nMlcBqlwYcmJA0sTS08J3rMpM5xsxIIGVv_Ge44pbIYJovyLfOL9KFmAi5YqjGESyMWzQUDQM_ildbzTd9KLivHEYuzzvhbj7uffcS7C1wQkk1j_r70q8q7FyXWdwEnF0JOwcv&hgt_ver=331370278 playpath=mp4:hulu7/156/60099156/agave50321917_10912067_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:381)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
   ... 2 more
2012-08-04 11:02:34,273 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEaMbYdkaxdaaAcxaabsc8dFdsdrdYawa0-bqhtMp-c0-4oFErCq1Axs&aifp=sll02152008&slist=hulu4/153/60099153;.international=false&hgt=OZU7Pvs7j27-nhteNno7wjZ8mS1DHcEV9IYSOjn0AcqYiesJ61mk4-79ZTw3ryEl_ITtJZpyM59NIcuV2cHeup4DE-bw0eRKKPMB_nfmHGVL64Ex_6dtA3vZp1k0fE6DdsvELTwHIvpEG68D9KYcdsygUVj-E5BmN-P5lrnAR6GaMTK4n8Wc4neItFMlrYiirfCDWA-2kOZD6qLrJcoLwQuKKulENCvbGNGknh98SiuMH2zqTMoSeDib3clJXdg1&hgt_ver=331370278 app=ondemand?auth=daEaMbYdkaxdaaAcxaabsc8dFdsdrdYawa0-bqhtMp-c0-4oFErCq1Axs&aifp=sll02152008&slist=hulu4/153/60099153;.international=false&hgt=OZU7Pvs7j27-nhteNno7wjZ8mS1DHcEV9IYSOjn0AcqYiesJ61mk4-79ZTw3ryEl_ITtJZpyM59NIcuV2cHeup4DE-bw0eRKKPMB_nfmHGVL64Ex_6dtA3vZp1k0fE6DdsvELTwHIvpEG68D9KYcdsygUVj-E5BmN-P5lrnAR6GaMTK4n8Wc4neItFMlrYiirfCDWA-2kOZD6qLrJcoLwQuKKulENCvbGNGknh98SiuMH2zqTMoSeDib3clJXdg1&hgt_ver=331370278 playpath=mp4:hulu4/153/60099153/agave50321914_10912053_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:02:39,013 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEaNc8bzbsdEd1cXa1cIcDbPcvaqagdIcv-bqhtMu-c0-5pFCwDv1AAp&aifp=sll02152008&slist=hulu19/593/60102593;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsqZW1jd7OPsPz4IZ18ZAPAaZgFpItIiv0L0cN21JyCh6mqMcajHZcNeO1zlWpAK2IBGfWVKiC5EGjquzsE9Y1hW_LOW8La2K0iwjkZcCZuQIKxJPvDymaX7DmBBnhpJKW3Lvs0iZdXeDdTU4uLMfQy4a29iMM3v68I5HNJo6XSIpQWTqrLabzfpfzoqi9gW69KdbmzkX_KFEmG8Rwio0nifwTL65GgwGPJvhnNY0ebR&hgt_ver=331370278 app=ondemand?auth=daEaNc8bzbsdEd1cXa1cIcDbPcvaqagdIcv-bqhtMu-c0-5pFCwDv1AAp&aifp=sll02152008&slist=hulu19/593/60102593;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsqZW1jd7OPsPz4IZ18ZAPAaZgFpItIiv0L0cN21JyCh6mqMcajHZcNeO1zlWpAK2IBGfWVKiC5EGjquzsE9Y1hW_LOW8La2K0iwjkZcCZuQIKxJPvDymaX7DmBBnhpJKW3Lvs0iZdXeDdTU4uLMfQy4a29iMM3v68I5HNJo6XSIpQWTqrLabzfpfzoqi9gW69KdbmzkX_KFEmG8Rwio0nifwTL65GgwGPJvhnNY0ebR&hgt_ver=331370278 playpath=mp4:hulu19/593/60102593/agave50325327_10994356_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:02:43,508 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEdOb5cacgcldrdFa4aSdPdxdZdNb7ctao-bqhtMy-c0-WoMDrEt0BAt&aifp=sll02152008&slist=hulu9/583/60102583;.international=false&hgt=OZU7Pvs7j27-nhteNno7wum5wKWFXOT2x6FuPd1WyKehg_exSocm9lvat5oSFujzFnzBTeBbbnX9yUrx9RQ2PiIU7G0UCFr_8y4BxwbuvEtDyeGHIkSvbYG1toE_GZEoQB8Q98Ajc--c31PQY7z8crZrlzGc3UuH2can3GtPTLayZvPIkaCEOQKfZQHaIF61v2pB2WPYOWWDko0mh9Ti7pHPVqWQEZIzIa5487yAorcX5soq48Dgkk5rVpUkeUuK&hgt_ver=331370278 app=ondemand?auth=daEdOb5cacgcldrdFa4aSdPdxdZdNb7ctao-bqhtMy-c0-WoMDrEt0BAt&aifp=sll02152008&slist=hulu9/583/60102583;.international=false&hgt=OZU7Pvs7j27-nhteNno7wum5wKWFXOT2x6FuPd1WyKehg_exSocm9lvat5oSFujzFnzBTeBbbnX9yUrx9RQ2PiIU7G0UCFr_8y4BxwbuvEtDyeGHIkSvbYG1toE_GZEoQB8Q98Ajc--c31PQY7z8crZrlzGc3UuH2can3GtPTLayZvPIkaCEOQKfZQHaIF61v2pB2WPYOWWDko0mh9Ti7pHPVqWQEZIzIa5487yAorcX5soq48Dgkk5rVpUkeUuK&hgt_ver=331370278 playpath=mp4:hulu9/583/60102583/agave50325318_10994300_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:02:48,373 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEa5acbFaYbdb6a0c_a6b_dZaUcjaLdQd0-bqhtMD-c0-3nHCsCnZDyu&aifp=sll02152008&slist=hulu17/316/60092316;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtrx-lyyc8CZUATGOGWkp26eoTLP9ASfjG7JXa37RRyAGWz_kxCBMhwmGKWHKDxo85tG0tKQTvNf-ZdP3xrPAfVOla1JVbUEqPQsa7oHqlbpVkRFmWpdi7DhjIbR7Rd1lXxIeYxTikcZT31Ai2r-VUWZw7KlWEukfq2ZjNktOVhHO04phTbymooTUiE5KFm41tfeW_sV3VF7QlhRGd5ou_kUXY3fmYvLNzdGfxzXeZYo&hgt_ver=331370278 app=ondemand?auth=daEa5acbFaYbdb6a0c_a6b_dZaUcjaLdQd0-bqhtMD-c0-3nHCsCnZDyu&aifp=sll02152008&slist=hulu17/316/60092316;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtrx-lyyc8CZUATGOGWkp26eoTLP9ASfjG7JXa37RRyAGWz_kxCBMhwmGKWHKDxo85tG0tKQTvNf-ZdP3xrPAfVOla1JVbUEqPQsa7oHqlbpVkRFmWpdi7DhjIbR7Rd1lXxIeYxTikcZT31Ai2r-VUWZw7KlWEukfq2ZjNktOVhHO04phTbymooTUiE5KFm41tfeW_sV3VF7QlhRGd5ou_kUXY3fmYvLNzdGfxzXeZYo&hgt_ver=331370278 playpath=mp4:hulu17/316/60092316/agave50316201_10764852_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:02:52,999 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEbvdFaycZdtaocBcvcEa1abdGd7aJdldl-bqhtMI-c0-XqGBvEo1Jxq&aifp=sll02152008&slist=hulu7/181/60090181;.international=false&hgt=OZU7Pvs7j27-nhteNno7wq-uXpXIoQTDLUzql-6ELqpzvs5RrmbfqVsWmyXQlG2UUSqxeFglYHjKWKpsj89wmhETLJ1g-x5EeUITMSLRIb4z5NYeWnU3vGH-Zszu1mcirDJ4ZwsuYOe0_xYl27i9jTincVETWQBnFYZ1HlrA14SutLnvWC0dchthkgauJHI43av8nCaYfEPkfURJFZbwcKAtUJVx5dwsB8ZslbZGmC-umwCkW15SBVLlkAHY5uI2&hgt_ver=331370278 app=ondemand?auth=daEbvdFaycZdtaocBcvcEa1abdGd7aJdldl-bqhtMI-c0-XqGBvEo1Jxq&aifp=sll02152008&slist=hulu7/181/60090181;.international=false&hgt=OZU7Pvs7j27-nhteNno7wq-uXpXIoQTDLUzql-6ELqpzvs5RrmbfqVsWmyXQlG2UUSqxeFglYHjKWKpsj89wmhETLJ1g-x5EeUITMSLRIb4z5NYeWnU3vGH-Zszu1mcirDJ4ZwsuYOe0_xYl27i9jTincVETWQBnFYZ1HlrA14SutLnvWC0dchthkgauJHI43av8nCaYfEPkfURJFZbwcKAtUJVx5dwsB8ZslbZGmC-umwCkW15SBVLlkAHY5uI2&hgt_ver=331370278 playpath=mp4:hulu7/181/60090181/agave50314072_10733164_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:02:57,663 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEaxbfaFb_dLafdQahbmakd_btaoc0aMag-bqhtMM-c0-ZoKBsDq1Hxr&aifp=sll02152008&slist=hulu8/182/60090182;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrodc0JGJpl8O3m1sf2P3t5wee05N2kEUO0TKEDtXVek4UARaQly092oFkMu3IfWsvK07wKJiBTQkvDgmvmX5e4hAo4MnTtfYIlHVUs27BoN1wD6-p4rc_TXf99xVR66N08W5jia_cMK_MRb-WVFUbwiTiP7BkRFPBQ6gRBfg2ke0CtyzTWggzjT5uamWgM2sF7jV1Qhdc85dVwf_qOKqN41IXmpNoSWvkehm0X41xjp&hgt_ver=331370278 app=ondemand?auth=daEaxbfaFb_dLafdQahbmakd_btaoc0aMag-bqhtMM-c0-ZoKBsDq1Hxr&aifp=sll02152008&slist=hulu8/182/60090182;.international=false&hgt=OZU7Pvs7j27-nhteNno7wrodc0JGJpl8O3m1sf2P3t5wee05N2kEUO0TKEDtXVek4UARaQly092oFkMu3IfWsvK07wKJiBTQkvDgmvmX5e4hAo4MnTtfYIlHVUs27BoN1wD6-p4rc_TXf99xVR66N08W5jia_cMK_MRb-WVFUbwiTiP7BkRFPBQ6gRBfg2ke0CtyzTWggzjT5uamWgM2sF7jV1Qhdc85dVwf_qOKqN41IXmpNoSWvkehm0X41xjp&hgt_ver=331370278 playpath=mp4:hulu8/182/60090182/agave50314073_10733178_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:03:02,573 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEcGd1a4aRaldhaJbCbec8c1dQbFddblbt-bqhtMR-c0-YqIBxCqYBAt&aifp=sll02152008&slist=hulu7/831/60092831;.international=false&hgt=OZU7Pvs7j27-nhteNno7wlMr5whkdLHzUYhVXmBomg1lqK-rCRzxMl_rUrQWYPrdaElassWDpbMbDishOdj8B-7wnRrA8x021FTKqz9R3HRfgCdJGsbzLhFlBTMVsdGZssh6_y9dG0v7DmKybRC9f79MsAcGpZTqpoDiziIN5Xxhc4a9z7zQHMFnM6A-_p04YzEBwgAm-KLDASUcKeuxBBf8cFFdXrUE05oS6Ev0kneTCTOTscQkaoExTKyIE5fH&hgt_ver=331370278 app=ondemand?auth=daEcGd1a4aRaldhaJbCbec8c1dQbFddblbt-bqhtMR-c0-YqIBxCqYBAt&aifp=sll02152008&slist=hulu7/831/60092831;.international=false&hgt=OZU7Pvs7j27-nhteNno7wlMr5whkdLHzUYhVXmBomg1lqK-rCRzxMl_rUrQWYPrdaElassWDpbMbDishOdj8B-7wnRrA8x021FTKqz9R3HRfgCdJGsbzLhFlBTMVsdGZssh6_y9dG0v7DmKybRC9f79MsAcGpZTqpoDiziIN5Xxhc4a9z7zQHMFnM6A-_p04YzEBwgAm-KLDASUcKeuxBBf8cFFdXrUE05oS6Ev0kneTCTOTscQkaoExTKyIE5fH&hgt_ver=331370278 playpath=mp4:hulu7/831/60092831/agave50316700_10783814_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:03:08,166 WARN  [FeedUpdaterThread] Failed to retrieve online item information for rtmpe://cp39466.edgefcs.net/ondemand?auth=daEdacOdWasdXcFcfbsbtciaka_bidxb9bi-bqhtMX-c0-WpFEzCv1Jzn&aifp=sll02152008&slist=hulu24/198/50148198;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtghperO78rKHl6dU9xXLtjT-pI0zD3qr6P3CZA1bGg0zAQ3jhYm6S87Ow7zqf-G3jD9VCCjgufpgDcG6XCwW6QiC4Q-IOdrfDr2LJAPcF1JgNhEOKBcDay2RzTXCvILqVD9hLYD8uOEnfcZuk9ravFEcwJazGcnTVrNNM-v8kwuqZH7mFXKfJvcg7p8PvUPz5s3G2ppOmETCoraL2X5Q7InpNzmFl-q9gQI3rloj1-6&hgt_ver=331370278 app=ondemand?auth=daEdacOdWasdXcFcfbsbtciaka_bidxb9bi-bqhtMX-c0-WpFEzCv1Jzn&aifp=sll02152008&slist=hulu24/198/50148198;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtghperO78rKHl6dU9xXLtjT-pI0zD3qr6P3CZA1bGg0zAQ3jhYm6S87Ow7zqf-G3jD9VCCjgufpgDcG6XCwW6QiC4Q-IOdrfDr2LJAPcF1JgNhEOKBcDay2RzTXCvILqVD9hLYD8uOEnfcZuk9ravFEcwJazGcnTVrNNM-v8kwuqZH7mFXKfJvcg7p8PvUPz5s3G2ppOmETCoraL2X5Q7InpNzmFl-q9gQI3rloj1-6&hgt_ver=331370278 playpath=mp4:hulu24/198/50148198/agave50148198_5106295_H264_400.mp4 swfUrl=http://www.hulu.com/player.swf swfVfy=1. It might not play.
   ... 2 more
2012-08-04 11:03:38,171 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
2012-08-04 11:05:08,208 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
   ... 4 more
Any suggestions? Scrap all the feeds and recreate them?
Xmantium
Post Sun Aug 05, 2012 1:49 am
Re: 0.6.2 to 1.0 upgrade causes online plug-ins to break
There have been some plugins that gave errors in v1.0, please post on that individual plugin post here thats not working for you
Some plugins have already been updated for v1.0 so make sure you have the upto date version
Post Sun Aug 05, 2012 11:39 am
I will post an upgrade for the Ilive plugin which will fix the 30000 problem. Your other problem appears to be that all the links are invalid/expired.
Users browsing this forum: Google [Bot] and 12 guests
