M6 Replay (France) [BROKEN]
Post Thu Jul 05, 2012 4:15 pm
Re: M6 Replay (France)
ayour wrote:Thank you very much for your help.
Enjoy it !
insane822
Post Tue Jul 10, 2012 2:07 am
Custom ffmpeg build moved here:
http://www.mediafire.com/?s65x9pnsqsi5hap
samcro49
Post Tue Jul 10, 2012 5:01 pm
i don't see the channel on my tv
ayour
Post Wed Jul 11, 2012 12:13 pm
For me it doesn't work to. After using new ffmpeg, M6 replay and W9 replay works but all others plugins disapear (I installed it in serviio lib) I romeved new ffmpeg and install old one. Now I have all others plugin, but I don't see any M6 replay or W9 replay folder.
I have windows 7 (x86).
I think it's a probleme with new beta ffmpeg. Sorry for my bad english.
Thinks.
ayour
Post Wed Aug 01, 2012 1:05 pm
Is it working?
For me not.
Post Wed Aug 01, 2012 4:57 pm
ayour wrote:Is it working?
For me not.
No.
M6Replay Website has been updated again, I will post a new plugin soon.
Post Wed Aug 01, 2012 6:34 pm
Plugin updated, see first post.
___Warning___
M6 Replay servers changed the rtmp protocol and use "HandShake Type 10 answer".
But the librtmp library used by serviio does not support this latest protocol.
You can use this following specific ffmpeg windows version (thanks insane822): http://www.mediafire.com/?s65x9pnsqsi5hap
This is not an official ffmpeg version
ayour
Post Fri Aug 03, 2012 1:06 am
Thank you very much. It works great for me. Merci beaucouuuuuuuuuuuuuuuuuuuup.
samcro49
Post Fri Aug 03, 2012 10:42 pm
cela ne marche pas pour moiu je vois les dossiers mais rien dedans
don't work for me
i can see folder but nothing video
Post Sat Aug 04, 2012 9:12 am
samcro49 wrote:cela ne marche pas pour moiu je vois les dossiers mais rien dedans
don't work for me
Dans l'état actuel (version 1.0 de serviio), il est nécessaire d'utiliser une version spécifique de ffmpeg disponible ici : http://www.mediafire.com/?s65x9pnsqsi5hap
Il doit remplacer le fichier "...\Serviio\lib\ffmpeg.exe" (fais une copie du fichier ffmpeg.exe d'origine)
Chez moi cela fonctionne très bien, par exemple la première video du catalogue M6 Replay [Series & Fictions]-[Melrose Place nouvelle génération]...:
C:\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i rtmpe://m6replayfs.fplive.net/m6replaytoken/streaming app=m6replaytoken/streaming?start_time=20120804090648&end_time=20120804111148&digest=0881494c51cc76532a06c playpath=mp4:production/regienum/m6_melrose-place-nouvelle-gen_s1e18_376428_300720121010.mp4?start_time=20120804090648&end_time=20120804111148&digest=0881494c51cc76532a06c swfUrl=http://l3.player.m6.fr/swf/ReplayPlayerV2Hds.swf swfVfy=1 buffer=100000000 -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts D:\temp\ServiioTemp\Serviio\transcoding-temp-1000000000010001-sony2010-ORIGINAL.stf
___Warning___
patters
Post Sun Aug 05, 2012 1:58 pm
Hi illico, I compile my own FFmpeg on Linux so where can I find source code for libRTMP with this handshake 10 support?
Post Sun Aug 05, 2012 4:10 pm
you can check with insane822 viewtopic.php?f=20&t=5118&start=30#p47519
patters
Post Sun Aug 05, 2012 10:16 pm
Thanks, looking through that thread I found the sources. However, the Changelog implies that it may only work for x86. I'm compiling for ARM.
https://github.com/svnpenn/rtmpdump/blo ... /ChangeLog
gcc -Wall  -I/opt -DRTMPDUMP_VERSION=\"v2.5\" -DUSE_OPENSSL  -O2    -c -o rtmpe10.o rtmpe10.c
rtmpe10.c: In function 'InjectFlashPlayerRtmpe10HandshakeCode':
rtmpe10.c:19795: warning: implicit declaration of function 'memcpy'
rtmpe10.c:19795: warning: incompatible implicit declaration of built-in function 'memcpy'
rtmpe10.c:19800: warning: implicit declaration of function 'memset'
rtmpe10.c:19800: warning: incompatible implicit declaration of built-in function 'memset'
rtmpe10.c: In function 'rtmpe10_sig':
rtmpe10.c:19828: warning: initialization makes pointer from integer without a cast
ar rs librtmp.a rtmp.o log.o amf.o hashswf.o parseurl.o rtmpe10.o
ar: creating librtmp.a
make[1]: Leaving directory `/volume1/public/temp/svnpenn-rtmpdump-264f508/librtmp'
gcc -Wall  -I/opt -DRTMPDUMP_VERSION=\"v2.5\"   -O2   -c -o rtmpdump.o rtmpdump.c
gcc -Wall -L/tmp/lib -o rtmpdump rtmpdump.o -Llibrtmp -lrtmp -lssl -lcrypto -ldl -lz
rtmpdump.o: In function `main':
rtmpdump.c:(.text+0x1710): undefined reference to `InjectFlashPlayerRtmpe10HandshakeCode'
rtmpdump.c:(.text+0x2310): undefined reference to `RemoveFlashPlayerRtmpe10HandshakeCode'
collect2: ld returned 1 exit status
make: *** [rtmpdump] Error 1
Post Mon Aug 06, 2012 5:26 am
patters wrote:However, the Changelog implies that it may only work for x86. I'm compiling for ARM.
Yes, it seems to use some low level x86 resources.
Post Mon Aug 06, 2012 12:46 pm
I think they are using assembly code for x86, so doubt it'll work on other architectures.
patters
Post Mon Aug 06, 2012 10:02 pm
Oh well, that's a bit of a pain. The whole point of open source stuff like this is that it's meant to be portable.
samcro49
Post Wed Aug 08, 2012 5:14 pm
don't work with ffmpeg inofficial
i don"t see folders in my tv
Post Wed Aug 08, 2012 6:27 pm
samcro49 wrote:don't work with ffmpeg inofficial
Its OK for me!!
- What is your OS ?
- What is your CPU familly (x86, AMD, etc) ?
samcro49
Post Thu Aug 09, 2012 10:32 am
installed on windows home server 2011
Amd socket fm1 apu A8-3850
tv samsung ue40es7000
thks
Post Thu Aug 09, 2012 11:03 am
OK,
For the moment, the in official ffmpeg version only support INTEL processor (not AMD).
Sorry. You have to wait for an official version with new handshake support.
Return to Available plugins
Users browsing this forum: Majestic-12 [Bot] and 5 guests
