BDP-S590 not playing avi's after july 19th update
Anya1976
Post Sat Aug 04, 2012 10:50 am
this happened after the most recent update. I had just played some tv show avi files right before the update and all was fine. after the update they no longer worked. The few mp4 files still play fine.
Post Sat Aug 04, 2012 11:59 am
Re: BDP-S590 not playing avi's after july 19th update
Update of Serviio or player firmware?
Anya1976
Post Sun Aug 05, 2012 4:54 am
zip wrote:Update of Serviio or player firmware?
player firmware sorry forgot to include that
patters
Post Sun Aug 05, 2012 10:10 am
Same issue reported in this thread:
viewtopic.php?f=11&t=6776
Anya1976, could you answer some or all of the questions I ask in my last post in that thread please? Thanks.
Anya1976
Post Sun Aug 05, 2012 10:59 pm
patters wrote:Same issue reported in this thread:
I did try rewinding and fastforwarding thru an mp4 and it hanged quite a bit it wasn't as easy as it had been.
mdavej
Post Mon Aug 06, 2012 3:46 pm
It's been reported elsewhere that manually selecting the TV (in Serviio) or Bravia profile (in Homestream) solves the AVI and MKV issues.
Anya1976
Post Sat Aug 11, 2012 10:58 am
mdavej wrote:It's been reported elsewhere that manually selecting the TV (in Serviio) or Bravia profile (in Homestream) solves the AVI and MKV issues.
ok, thanks but I'm not using this with a fancy tv just thru my sony blu ray player. so I don't know what I'm switching. total noob when it comes to using dnla
NX3
Post Sat Aug 11, 2012 12:02 pm
In serviio you have a tab that lists your connected network devices and Serviio indentifies them and applies a profile (usually correctly). You need to go to the Serviio console interface, the profiles tab and select Sony Bluray player for your device, click save and this will fix the problem.
Anya1976
Post Sun Aug 12, 2012 8:56 pm
NX3 wrote:In serviio you have a tab that lists your connected network devices and Serviio indentifies them and applies a profile (usually correctly). You need to go to the Serviio console interface, the profiles tab and select Sony Bluray player for your device, click save and this will fix the problem.
mine is on the sony blu ray profile already there is not any other profile to choose that's it there is no specific player model listed.
mdavej
Post Mon Aug 13, 2012 2:31 pm
NX3 misspoke. The Blu-ray profile doesn't work anymore, so you definitely don't want to use that one. You need to pick the Bravia TV profile instead, as shown below.
(Thanks, to JosephR. at avsforum for the screen shot)
I realize you are streaming through your player and not your TV, but the TV profile has the correct info at the moment that works with the latest player firmware. That's the solution, whether it makes sense or not. Just do it, and it will work.
Anya1976
Post Mon Aug 13, 2012 7:38 pm
mdavej wrote:NX3 misspoke. The Blu-ray profile doesn't work anymore, so you definitely don't want to use that one. You need to pick the Bravia TV profile instead, as shown below.
oh ok now THAT explains things better :)
Users browsing this forum: No registered users and 65 guests
