Samsung E Series Profiles
Currently Serviio has no profiles for Samsung's current LED line, the E Series. I'm using the C/D profile at the moment, however something seems a bit off compared to the Samsung's Allshare server.
Microsoft Windows XP [Versione 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Utente>C:\Programmi\Serviio\lib\ffmpeg.exe -i "*************.mkv"
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 50.00 (50/1)
Input #0, matroska,webm, from '*************.mkv':
Duration: 00:20:52.00, start: 0.000000, bitrate: 3980 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 2
5 fps, 50 tbr, 1k tbn, 47.95 tbc
Stream #0:1(ita): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s (default)
