Console won't Launch
jgasparine
Post Tue Aug 07, 2012 1:54 am
I have downloaded 'serviio-1.0-win-setup.exe' with intentions to install the console on Computer A. The server already runs on Computer B.
When launching the installer on Computer A, and prompted to 'Select Components to Install', I select 'Common Files' and 'Serviio Console' only (I uncheck the box for 'Serviio Server'). The install completes, and I launch the executable for Serviio Console. Nothing happens.
Computer A is running Windows 7 x64 Home Premium
I have tried uninstalling all previous versions of Java and Serviio, and manually installing Java 6u33 x64 before attempting to re-install Serviio per the steps described above. I have also tried this re-install sequence with Java 7u5 x64.
None of the above have resulted in the Console launching.
Everything runs fine on Computer B, which is a WinXP x32 machine.
Thoughts? This is driving me nuts...
Post Tue Aug 07, 2012 8:55 am
Re: Console won't Launch
Is there any log created on the machine B? Did you set the console for remote access?
jgasparine
Post Tue Aug 07, 2012 11:43 am
Here is what is in the Serviio log on Machine A:
2012-08-06 21:56:15,552 INFO  [ServiioConsole] Starting Serviio Console
2012-08-06 21:56:15,646 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-06 21:56:26,020 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-08-06 21:56:36,125 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-08-06 21:56:36,126 ERROR [ServiioConsole] Unexpected exception occured: null
   at org.serviio.console.ServiioConsole.setupConsoleSettings(ServiioConsole.java:120)
   at org.serviio.console.ServiioConsole.main(ServiioConsole.java:103)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-08-06 21:56:36,130 INFO  [ServiioConsole] Leaving Serviio Console
2012-08-06 21:57:11,910 INFO  [ServiioConsole] Starting Serviio Console
2012-08-06 21:57:12,038 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-08-06 21:57:22,323 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-08-06 21:57:27,065 INFO  [ServiioConsole] Leaving Serviio Console
I cannot find anything of note in the Windows logs. I did not look into the Machine B logs because I don't think Machine A ever made contact with Machine B.
To answer your second question, I have not set the console for remote access. This is because I cannot seem to locate find the following files in the Serviio directory/subdirectories: "ServiioService.exe.vmoption" and/or "serviio.bat".
I have my folder permissions set to show all hidden files, so I don't quite understand why they aren't appearing in the installation directory.
Short of Supplying you a series of screenshots, my installation directory looks like this:
Serviio
    bin (contains serviioconsole.exe only)
    lib (contains a variety of jar files only)
    log (only contains serviio.txt)
Thoughts?
Post Tue Aug 07, 2012 12:09 pm
You want to look for ServiioConsole.exe.vmoptions in the bin directory, if it isn't there, create it and add
-Dserviio.remoteHost=IP_ADDRESS_OF_COMPUTER_B
jgasparine
Post Tue Aug 07, 2012 10:23 pm
Creating the ServiioConsole.exe.vmoptions file was the missing piece!
Thanks Will!
Users browsing this forum: Google [Bot] and 281 guests
