Samsung UE40D7000 can not connect to serviio
pharyx
Post Tue Aug 07, 2012 9:30 am
Hi!
I installed serviio on my debian pc a few days ago and everything went fine. My tv was detected and I could stream my video files.
Yesterday I noticed that the message which pops up when serviio starts and detect my tv was missing. Now I don't get it to work again.
I turned detailed logging on and my logfiles says now:
2012-08-07 11:05:58,634 DEBUG [WebServer] Incoming connection from /192.168.178.8:52986
2012-08-07 11:05:58,636 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.8
2012-08-07 11:05:58,637 DEBUG [DeviceDescriptionRequestHandler] Device /192.168.178.8 does not have access to the server, returning 403
2012-08-07 11:05:58,734 DEBUG [WebServer] Incoming connection from /192.168.178.8:37247
2012-08-07 11:05:58,735 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.8
2012-08-07 11:05:58,737 DEBUG [DeviceDescriptionRequestHandler] Device /192.168.178.8 does not have access to the server, returning 403
2012-08-07 11:05:58,835 DEBUG [WebServer] Incoming connection from /192.168.178.8:57959
2012-08-07 11:05:58,836 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.8
2012-08-07 11:05:58,837 DEBUG [DeviceDescriptionRequestHandler] Device /192.168.178.8 does not have access to the server, returning 403
2012-08-07 11:05:59,834 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
I installed serviio on another debian machine here and it worked immediately. The popup on the tv showed up, I pushed OK and I could see the content.
I also removed the complete serviio folder on the affected pc and installed it again. No change.
192.168.178.8 is my tv. Serviio is running at 192.168.178.4. Is the tv blocking serviio or is serviio blocking my tv? The WebUI v 1.0 is seeing my tv, no problem.
So, what happened? Any help would be appreciated. ;)
Thanks in advance.
pharyx
Post Tue Aug 07, 2012 3:35 pm
Re: Samsung UE40D7000 can not connect to serviio
You set up the TV not to have access in the Renderers list - I'm actually not sure if you can change that in the current version of the web UI, you might see this because the old version is not compatible with 1.0
pharyx
Post Tue Aug 07, 2012 6:48 pm
hmm, strange. If I can't see it in the web UI, how can it happen?
I deleted the serviio folder completely and installed it again. Nothing changed. Where is that setting saved?
and why it is working on another machine with the same setup?
Post Tue Aug 07, 2012 10:03 pm
Possibly if you save the Status tab with old web UI it defaults to disabled state for all devices.
pharyx
Post Wed Aug 08, 2012 8:14 am
So I have to wait for an update of the web UI.
I solved it yesterday the following way:
I installed serviio on a windows machine, because I don't use a desktop environment on my linux machines. There I configured the serviio console for remote access
(added in ServiioConsole.exe.vmoptions -> -Dserviio.remoteHost=192.168.178.4). In the renderer list my tv was crossed out. I removed the entry and after detecting
my tv again it works.
So there is still the question where this setting is saved. I deleted the serviio folder and the web UI completely and after a reinstall it didn't change anything !?
Anyway, thanks for your help. :)
Post Wed Aug 08, 2012 9:19 am
it's saved in the library folder in serviio installation.
Users browsing this forum: No registered users and 55 guests
