How to transcode video audio only?
mrpessimist
Post Fri Aug 03, 2012 5:21 pm
Re: How to transcode video audio only?
Thanks for the help.
Is there a format that is less (or the least) CPU intensive? Is everything encoded through FFmpeg?
As I mentioned in a previous post, my poor Celeron M is maxed out when transcoding and it looks like FFmpeg continues to process the whole video file even if playback is stopped.
Post Fri Aug 03, 2012 8:18 pm
you could do this file manually - but it should generally work on other files
mrpessimist
Post Wed Aug 08, 2012 12:13 am
zip wrote:you could do this file manually - but it should generally work on other files
Not sure what you mean here.
When looking through the entire Profiles XML all I see is targetContainer="mpegts" targetVCodec="mpeg2video". Is this because that is the only output that FFmpeg produces? Are there any other target video container and codec options out there that can be used? Maybe a different container/codec mix would be lighter on my cpu.
For example: targetContainer="avi" targetVCodec="xvid"
Post Wed Aug 08, 2012 8:35 am
the available containers (mpegts, mpegps, asf) are the only ones that can be used for transcoding on-the-fly
mrpessimist
Post Thu Aug 09, 2012 3:35 pm
zip wrote:the available containers (mpegts, mpegps, asf) are the only ones that can be used for transcoding on-the-fly
Ok, good to know. Thank you.
ty2010
Post Tue Aug 28, 2012 1:10 am
Baseline level 3 in flv is processor light, would the same work in asf?
Previous
Users browsing this forum: Google [Bot] and 2 guests
