[SOLVED] missing sound on many online channels with v1.0
beano
Post Fri Jul 27, 2012 10:20 am
aprox half of my online TV channels are silent since installing the above on my Sony Bravia 2011 TV, has anybody got any ideas how I can resolve this?
Post Sun Jul 29, 2012 7:44 am
Re: missing sound on many online channels with v1.0
Could you provide link?
Could you enable detailed logging, restart serviio and post log ? (see signature)
JonB
Post Wed Aug 01, 2012 4:17 pm
I have the same problem here is a link : http://www.ted.com/talks/rss
Post Wed Aug 01, 2012 7:10 pm
JonB wrote:I have the same problem here is a link : http://www.ted.com/talks/rss
No problem with my 2010 model.
The following command line is used:
ffmpeg.exe -fflags +genpts -i "http://download.ted.com/talks/MichaelAnti_2012G.mp4" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts D:\temp\ServiioTemp\Serviio\transcoding-temp-1000000000100003-sony2010-ORIGINAL.stf
Could you enable detailed serviio logging and find the ffmpeg command line used ?
NX3
Post Wed Aug 01, 2012 8:22 pm
I've not sorted out a log file but adding a me2 for Sony 2011 series, no audio online. Working on other devices on the network.
NX3
Post Thu Aug 02, 2012 5:51 pm
Playing Skyfall trailer from HD Trailers (youtube, iplayer don't have audio on Sony 2011 either, other devices fine.)
The line you mentioned is "Starting ffmpeg -fflags +genpts -i http://pdl.stream.aol.com/pdlext/aol/br ... 20p_dl.mov -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-1000000000200001-sony2011-ORIGINAL.stf"
2012-08-02 18:43:29,665 DEBUG [FeedItemUrlExtractor] HDTrailers: Starting extraction of url for item: [1]Skyfall
2012-08-02 18:43:30,596 DEBUG [FeedItemUrlExtractor] HDTrailers: Getting item: [1]Skyfall
2012-08-02 18:43:30,596 DEBUG [FeedItemUrlExtractor] HDTrailers: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov, thumbnailUrl=http://www.hd-trailers.net/thumbnail/skyfall-1b38-4c0a3d9bbac00-poster.jpg, expiresImmediately=true, cacheKey=http://www.hd-trailers.net/movie/skyfall/_720, live=false, userAgent=]
2012-08-02 18:43:30,596 DEBUG [VideoDeliveryEngine] Successfully set new URL for the feed item
2012-08-02 18:43:30,597 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov
2012-08-02 18:43:30,597 DEBUG [ProcessExecutor] Starting ffmpeg -fflags +genpts -i http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-1000000000200001-sony2011-ORIGINAL.stf
2012-08-02 18:43:31,598 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-02 18:43:31,599 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov: AVC_TS_MP_HD_AAC_MULT5_ISO
2012-08-02 18:43:31,599 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-02 18:43:31,599 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-02 18:43:31,599 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-08-02 18:43:31,600 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-153.0/153,Date: Thu, 02 Aug 2012 17:43:31 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-02 18:43:35,368 DEBUG [WebServer] I/O error: Broken pipe
2012-08-02 18:43:35,385 DEBUG [WebServer] Incoming connection from /192.168.1.223:33605
2012-08-02 18:43:35,386 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:35,388 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000200001/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA ";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="1.7";,Host: 192.168.1.106:8895]]
2012-08-02 18:43:35,388 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:35,389 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.223, Profile=Sony Bravia TV (2011)'
2012-08-02 18:43:35,389 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000200001 and type 'MEDIA_ITEM' received
2012-08-02 18:43:35,389 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000200001 (online)
2012-08-02 18:43:35,390 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 20)
2012-08-02 18:43:35,392 DEBUG [VideoDeliveryEngine] Delivering item '1000000000200001' for client 'IPAddress=/192.168.1.223, Profile=Sony Bravia TV (2011)'
2012-08-02 18:43:35,392 DEBUG [VideoDeliveryEngine] Delivering file 'http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov' using transcoding
2012-08-02 18:43:35,392 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.223, Profile=Sony Bravia TV (2011)'
2012-08-02 18:43:35,392 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-02 18:43:35,393 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://pdl.stream.aol.com/pdlext/aol/brightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov: AVC_TS_MP_HD_AAC_MULT5_ISO
2012-08-02 18:43:35,393 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-02 18:43:35,393 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-02 18:43:35,393 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-08-02 18:43:35,393 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-153.0/153,Date: Thu, 02 Aug 2012 17:43:35 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-02 18:43:44,382 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.106, timeout = 0
2012-08-02 18:43:44,383 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device e5738f9a-567c-3169-8f16-9e102aa87386
2012-08-02 18:43:44,988 DEBUG [WebServer] Incoming connection from /192.168.1.223:33607
2012-08-02 18:43:44,988 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:44,989 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e5738f9a-567c-3169-8f16-9e102aa87386 from 192.168.1.223 (headers = [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";])
2012-08-02 18:43:44,989 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:44,990 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";]
2012-08-02 18:43:44,991 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:44,994 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2011)'
2012-08-02 18:43:45,004 DEBUG [WebServer] Incoming connection from /192.168.1.223:33608
2012-08-02 18:43:45,005 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,006 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-08-02 18:43:45,007 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-02 18:43:45,020 DEBUG [WebServer] Incoming connection from /192.168.1.223:33609
2012-08-02 18:43:45,020 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,021 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-08-02 18:43:45,023 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-02 18:43:45,038 DEBUG [WebServer] Incoming connection from /192.168.1.223:33610
2012-08-02 18:43:45,039 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,039 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.223:
2012-08-02 18:43:45,048 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-02 18:43:45,052 DEBUG [WebServer] Incoming connection from /192.168.1.223:33611
2012-08-02 18:43:45,052 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,053 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.223:
2012-08-02 18:43:45,053 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,058 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2011)'
2012-08-02 18:43:45,075 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-02 18:43:45,133 DEBUG [WebServer] Incoming connection from /192.168.1.223:33612
2012-08-02 18:43:45,134 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,135 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e5738f9a-567c-3169-8f16-9e102aa87386 from 192.168.1.223 (headers = [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";])
2012-08-02 18:43:45,136 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,136 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";]
2012-08-02 18:43:45,137 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,140 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2011)'
2012-08-02 18:43:45,153 DEBUG [WebServer] Incoming connection from /192.168.1.223:33613
2012-08-02 18:43:45,153 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,154 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-08-02 18:43:45,154 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-02 18:43:45,164 DEBUG [WebServer] Incoming connection from /192.168.1.223:33614
2012-08-02 18:43:45,164 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,165 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-08-02 18:43:45,166 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-08-02 18:43:45,198 DEBUG [WebServer] Incoming connection from /192.168.1.223:33615
2012-08-02 18:43:45,198 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,199 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.223:
2012-08-02 18:43:45,199 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,207 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-02 18:43:45,214 DEBUG [WebServer] Incoming connection from /192.168.1.223:33616
2012-08-02 18:43:45,214 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,215 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.1.223:
2012-08-02 18:43:45,215 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,220 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2011)'
2012-08-02 18:43:45,236 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-02 18:43:45,306 DEBUG [WebServer] Incoming connection from /192.168.1.223:33617
2012-08-02 18:43:45,307 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,308 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e5738f9a-567c-3169-8f16-9e102aa87386 from 192.168.1.223 (headers = [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";])
2012-08-02 18:43:45,308 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,309 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.106:8895,Date: Thu, 02 Aug 2012 17:43:45 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA MN";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA MN"; mv="1.7";]
2012-08-02 18:43:45,310 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,313 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2011)'
2012-08-02 18:43:45,324 DEBUG [WebServer] Incoming connection from /192.168.1.223:33618
2012-08-02 18:43:45,324 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.223
2012-08-02 18:43:45,325 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
ffmpeg updated with latest serviio sources, no difference.
gismrey
Post Sun Aug 05, 2012 11:49 pm
Hi all,
I have the same problem (no audio). When I play the streams in VLC I get audio. I am using mac OX 10.5, Sony Bravia KDL46EX720 (2011 series). Here is an example:
2012-08-06 01:43:40,938 DEBUG [FeedItemUrlExtractor] LiveFeeds: Starting extraction of url for item: Al Jazerra Sports 2
2012-08-06 01:43:40,939 DEBUG [FeedItemUrlExtractor] LiveFeeds: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://2m4u.com/index2.php?q=aHR0cDovLzE3My4xOTMuNDguMTM3OjkwMDAvSlNDMj9pZD0wMDoxRDo5MjpGMTo1QTo2QSZpcD0xNzYuMzEuMjUxLjg2JmF1dGg9NTdjNGJmZWE1YTYyODA1YTRkZjk3NTRjMmYxYTEzZjI, thumbnailUrl=https://sites.google.com/site/serviiorss/aljazsport.jpg, expiresImmediately=false, live=true, ]
2012-08-06 01:43:40,939 DEBUG [FeedParser] Added feed item 6: 'Al Jazerra Sports 2' (http://2m4u.com/index2.php?q=aHR0cDovLzE3My4xOTMuNDguMTM3OjkwMDAvSlNDMj9pZD0wMDoxRDo5MjpGMTo1QTo2QSZpcD0xNzYuMzEuMjUxLjg2JmF1dGg9NTdjNGJmZWE1YTYyODA1YTRkZjk3NTRjMmYxYTEzZjI)
2012-08-06 01:43:40,940 DEBUG [FeedItemUrlExtractor] LiveFeeds: Starting extraction of url for item: Al Jazerra Sports 9
2012-08-06 01:43:40,941 DEBUG [FeedItemUrlExtractor] LiveFeeds: Finished extraction of url: ContentURLContainer [fileType=VIDEO, contentUrl=http://2m4u.com/index2.php?q=aHR0cDovLzE3My4xOTMuNDguMTM3OjkwMDAvSlNDOT9pZD0wMDoxRDo5MjpGMTo1QTo2QSZpcD0xNzYuMzEuMjUxLjg2JmF1dGg9NTdjNGJmZWE1YTYyODA1YTRkZjk3NTRjMmYxYTEzZjI, thumbnailUrl=https://sites.google.com/site/serviiorss/aljazsport.jpg, expiresImmediately=false, live=true, ]
2012-08-06 01:43:40,941 DEBUG [FeedParser] Added feed item 7: 'Al Jazerra Sports 9' (http://2m4u.com/index2.php?q=aHR0cDovLzE3My4xOTMuNDguMTM3OjkwMDAvSlNDOT9pZD0wMDoxRDo5MjpGMTo1QTo2QSZpcD0xNzYuMzEuMjUxLjg2JmF1dGg9NTdjNGJmZWE1YTYyODA1YTRkZjk3NTRjMmYxYTEzZjI)
2012-08-06 01:43:40,941 DEBUG [OnlineContentCacheDecorator] Stored online content 'https://sites.google.com/site/serviiorss/LiveFeeds_HD_Sports.rss' in the cache (online_feeds), returning it
2012-08-06 01:43:40,943 DEBUG [OnlineLibraryManager] Resource https://sites.google.com/site/serviiorss/LiveFeeds_HD_Sports.rss will expire in the cache on Mon Aug 06 07:43:40 CEST 2012
I really have no idea where to look for the relevant information in the log. Therefore I attached the whole log as well. There are also channels like Sky Sport HD 1 which show up in VLC but not in my bravia.
Can you post any live sport streams, such as Sky sport or Eurosport, almost all streams on http://piscui.webear.net/rtmpgui/rtmpgui.php don't work.
Thanks in advance,
gmr
(455.94 KiB) Downloaded 867 times
NX3
Post Tue Aug 07, 2012 5:57 pm
I think we might need Zip to look at this as the logs don't seem to show an error. Its clearly a fault with Sony 2011 audio, even on pass thru to my amp I get nothing.
patters
Post Tue Aug 07, 2012 6:54 pm
The notable change to the audio handling on Sony Bravias between 0.6.2 and 1.0 was to allow native playback of AAC audio (rather than force transcoding of everything to AC-3). This works fine on my 2009 Bravia and owners of more recent models had reported successful testing.
Perhaps it doesn't work in some regions. Are you in Europe or the US (so PAL or NTSC)? Can you try playing test downloaded media which has AAC audio? Is it silent too?
Could the problem streams perhaps be using HE-AAC which the Sony devices might not support?
Here's the FFmpeg information for the clip that featured in the log excerpt above:
C:\Windows\System32>c:\temp\ffmpeg -i "http://pdl.stream.aol.com/pdlext/aol/brig
htcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov"
ffmpeg version N-42069-g3233ad4 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jun 30 2012 13:22:04 with gcc 4.7.1
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass
 --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable
-libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope
njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth
eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-
libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e
nable-zlib
  libavutil      51. 63.100 / 51. 63.100
  libavcodec     54. 31.100 / 54. 31.100
  libavformat    54. 14.100 / 54. 14.100
  libavdevice    54.  0.100 / 54.  0.100
  libavfilter     3.  0.100 /  3.  0.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'http://pdl.stream.aol.com/pdlext/aol/br
ightcove/ame/201207/30/45947/premiumrush2_trlr_02_720p_dl.mov':
    major_brand     : qt
    minor_version   : 537199360
    compatible_brands: qt
    creation_time   : 2012-07-31 05:47:58
  Duration: 00:02:33.21, start: 0.000000, bitrate: 4509 kb/s
    Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720,
 4348 kb/s, 23.98 fps, 23.97 tbr, 2397 tbn, 4794 tbc
      handler_name    : Apple Alias Data Handler
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 156
 kb/s
NX3
Post Wed Aug 08, 2012 8:42 am
I'm in the UK and get no audio on anything from online be it Youtube, iPlayer, trailers etc... it must be a problem on the European 2011 models and AAC audio streaming.
I can test properly later but seems odd I get no audio at all from anything online, any source.
patters
Post Wed Aug 08, 2012 9:41 am
But downloaded movies with AAC play natively, or are they problematic too?
NX3
Post Wed Aug 08, 2012 4:54 pm
If I download the exact same files e.g the Skyfall trailer or the other clips and store locally I get sound. So its something to do with the audio when streaming isn't coming through for some reason. I've had a brief look at the new style profile xml file and not got my head around it yet to be honest. I'll try to figure it out later..... but something inherited for Sony 2011 stops all online audio working.
Ok I've had a look of the profiles.xml and I can't see anything inherited or reason to stop audio working. Some streams like iPlayer are AC3 so its not AAC specific.
Post Wed Aug 08, 2012 6:40 pm
NX3 wrote:If I download the exact same files e.g the Skyfall trailer or the other clips and store locally I get sound.
Strange...
I see that when its stream from "rtmp" there is an "buffer=100000000" option on ffmpeg command line. Don't know if the value can be changed.Try some other value.
don't know if with "http" link its the same.
NX3
Post Wed Aug 08, 2012 8:41 pm
"buffer=100000000" is listed in the logs for iPlayer as well but not for HD Trailers. I have no control over that, its something Serviio is putting in as e.g for BBC iPlayer I just feed a RSS link and off it goes.
patters
Post Thu Aug 09, 2012 1:35 pm
iPlayer is usually AAC.
Post Thu Aug 09, 2012 6:08 pm
I tried a youtube flv/h264/aac on 2012 Bravia and it plays sound.
NX3
Post Thu Aug 09, 2012 8:18 pm
Any suggestions on what else I can check ? its not just me, this has come up in a few other threads as well.
I've got a 37EX723 and 26EX320, same problem on both but Asus O!play, XBMC, WDTV all fine from same server.
Post Thu Aug 09, 2012 9:44 pm
So we could enable aac transcoding for online content... Illico/patters, do you remember the lines that have been added to 1.0?
NX3
Post Fri Aug 10, 2012 9:10 am
Is this the code that needs to be added to Sony 2011 profile ? my best guess..... I can't test just yet.
<OnlineTranscoding>
<Audio targetContainer="ac3" forceInheritance="false">
<Matches container="AAC" />
</Audio>
</OnlineTranscoding>
Post Sat Aug 11, 2012 6:17 am
zip wrote:So we could enable aac transcoding for online content... Illico/patters, do you remember the lines that have been added to 1.0?
Not sure 100%, but I remember that Sony Bravia inherit of generic profile that transcode all audio to ac3 for online video. I will look at my backup folders....
Users browsing this forum: Baidu [Spider] and 3 guests
