[SOLVED] X_MS_MediaReceiverRegistrar Service
steve666
Post Fri Aug 10, 2012 10:13 am
Dear all, my Serviio media server does not offer the "X_MS_MediaReceiverRegistrar"-Service for my Upnp/DLNA music streaming device. The streaming device is expecting the authorization information coming along with the "X_MS_MediaReceiverRegistrar"-service. The effect is currently that the serviio media server does see the streaming device, the streaming device itself does not recognize the serviio media server. IS there a way that I can modify the settings of the serviio media server that it also publishes (maybe also as a dummy) the requested service?
Post Fri Aug 10, 2012 10:55 am
Re: X_MS_MediaReceiverRegistrar Service
This service is provided by Serviio. You can check it via DeviceSpy (Intel tools)
steve666
Post Fri Aug 10, 2012 12:58 pm
Mmh, thanks for your reply. I have a synology device with the latest firmware version. Synology told me that they use the serviio media server. If I check the upnp service profile (I have a upnp-inspector tool installed on my PC) of my synology (serviio) media server, it does not display the MS service part (but for an old other NAS device that I installed now for test purposes). The synology support was not able to answer my questions on this in the last week. Therefore I try to find a solution directly with the serviio community. Could it be that synology is distributing the serviio installation in a different way than I would directly install it manually?
Post Fri Aug 10, 2012 1:13 pm
AFAIK Synology distribute other DLNA server. You would have to get Serviio for Synology on the Serviio download page
steve666
Post Sat Aug 11, 2012 11:46 am
I installed the serviio media server directly on to the synology machine and now the streaming works fine. Thanks for your help.
Users browsing this forum: No registered users and 217 guests
