HD-TS Record
kröbi
Post Wed Dec 01, 2010 10:02 am
HD-TS Record
I managed to run Serviio on my Lucid-Box to stream TS-recordings from VDR.
First my Samsung C-series won´t recognise Serviio, but after replugging the Ethernetcable it work´s as a charm.
It´s great. :shock: I even can FF on recordings that are still running.
The only problem I got is streaming HD won´t work.
In VDRs UPNP-Plugin I managed streaming of HD-recordings by assigning DLNA_PROFILE_AVC_TS_HD_EU_ISO to them.
Is ther any chance you might add this in the next version?
Thanks,
Dirk
Post Wed Dec 01, 2010 10:21 am
Re: HD-TS Record
Can you provide ffmpeg -i on the file?
kröbi
Post Wed Dec 01, 2010 11:05 am
Re: HD-TS Record
OK,
I will provide this tommorrow cause I´m in the office right now.
Greetings und thanks from snowy Cologne
Dirk
kröbi
Post Wed Dec 01, 2010 9:47 pm
Re: HD-TS Record
This is the output of ffmpeg:
[h264 @ 0x18119e0]number of reference frames exceeds max (probably corrupt input), discarding one
Seems stream 0 codec frame rate differs from container frame rate: 100.00 (100/1) -> 50.00 (50/1)
Last message repeated 8 times
Input #0, mpegts, from './00001.ts':
Duration: 00:00:53.56, start: 495.875011, bitrate: 13194 kb/s
Program 132
Stream #0.0[0x17de]: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50 tbr, 90k tbn, 100 tbc
Stream #0.1[0x17e8](deu): Audio: mp2, 48000 Hz, stereo, s16, 256 kb/s
Stream #0.2[0x17e9](mis): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.3[0x17eb](qaa): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.4[0x17ea](deu): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
It is public tv. As soon as i get a smartcardreader there will be recordings in the same format but with 1920x1080 [PAR 1:1 DAR 16:9] from private channels, where i would like to skip the commercials.
Post Wed Dec 01, 2010 10:01 pm
Re: HD-TS Record
I'll add the profile into 0.5
kröbi
Post Thu Dec 02, 2010 9:04 am
Re: HD-TS Record
Thanks a lot.
Great job you are doing.
Even answering every Post in this forum besides coding.
I´ll spread the word about Serviio
Return to Feature requests
