[SOLVED] Cant see server in local network
sunrise
Post Mon Aug 13, 2012 3:11 pm
Hi there,
Im using serviio pro 1.0.1 at a linux machine (Ubuntu 11.10) but can only see the server on the machine running serviio.
I have no running firewall, bound the ip address and set up multicast routes. The Media Browser is available trough another machine.
Here the detailed log file:
2012-08-13 16:54:49,233 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-08-13 16:54:49,260 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-13 16:54:49,261 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-08-13 16:54:49,261 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-08-13 16:54:49,261 INFO  [MediaServer] http://www.serviio.org
2012-08-13 16:54:49,262 INFO  [MediaServer]
2012-08-13 16:54:49,262 INFO  [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-08-13 16:54:49,262 INFO  [MediaServer] OS Linux i386 3.0.0-23-generic
2012-08-13 16:54:49,262 INFO  [MediaServer] File encoding: US-ASCII
2012-08-13 16:54:49,263 INFO  [MediaServer] Headless mode enabled: true
2012-08-13 16:54:49,264 INFO  [MediaServer] User home dir: /root
2012-08-13 16:54:49,264 INFO  [MediaServer] Temp dir: /tmp
2012-08-13 16:54:49,264 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-13 16:54:49,665 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-08-13 16:54:49,670 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-08-13 16:54:49,777 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-08-13 16:54:49,778 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-08-13 16:54:49,821 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-13 16:54:49,849 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-08-13 16:54:54,218 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-08-13 16:54:54,221 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-08-13 16:54:54,223 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-08-13 16:54:54,225 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-08-13 16:54:54,227 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-08-13 16:54:54,229 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-08-13 16:54:54,231 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-08-13 16:54:54,233 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-08-13 16:54:54,235 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-08-13 16:54:54,237 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-08-13 16:54:54,239 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-08-13 16:54:54,241 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-08-13 16:54:54,293 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-08-13 16:54:54,635 INFO  [MediaServer] ------------------------------------------------------------------------
2012-08-13 16:54:54,635 INFO  [MediaServer] License: PRO (NORMAL, id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
2012-08-13 16:54:55,758 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-13 16:54:56,073 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-08-13 16:54:58,172 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-13 16:54:58,175 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-08-13 16:54:59,207 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-08-13 16:54:59,210 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-08-13 16:54:59,817 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-08-13 16:54:59,820 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-08-13 16:55:00,753 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-13 16:55:00,756 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-08-13 16:55:01,310 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-08-13 16:55:01,313 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-08-13 16:55:01,736 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-08-13 16:55:01,741 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-08-13 16:55:03,116 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-08-13 16:55:03,120 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-08-13 16:55:03,210 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-08-13 16:55:03,214 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2012-08-13 16:55:05,330 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-08-13 16:55:05,340 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-08-13 16:55:08,620 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-08-13 16:55:08,627 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-08-13 16:55:09,652 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-08-13 16:55:09,658 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-08-13 16:55:10,268 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-08-13 16:55:10,273 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-08-13 16:55:10,369 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-08-13 16:55:10,376 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-08-13 16:55:10,794 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-08-13 16:55:10,799 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-08-13 16:55:10,963 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-08-13 16:55:10,968 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2012-08-13 16:55:11,796 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-08-13 16:55:11,801 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2012-08-13 16:55:11,952 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-08-13 16:55:11,957 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2012-08-13 16:55:12,754 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-08-13 16:55:12,759 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2012-08-13 16:55:13,625 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-08-13 16:55:13,630 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2012-08-13 16:55:13,982 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-08-13 16:55:13,987 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2012-08-13 16:55:14,160 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-08-13 16:55:14,165 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2012-08-13 16:55:15,781 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-08-13 16:55:15,787 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2012-08-13 16:55:16,036 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-08-13 16:55:16,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2012-08-13 16:55:16,264 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-08-13 16:55:16,269 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2012-08-13 16:55:16,789 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-08-13 16:55:16,798 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2012-08-13 16:55:17,132 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-08-13 16:55:17,224 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-13 16:55:17,238 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2012-08-13 16:55:18,039 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-08-13 16:55:18,042 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2012-08-13 16:55:18,543 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-08-13 16:55:18,860 INFO  [Device] Created UPnP Device with UUID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx, bound address: 192.168.0.21
2012-08-13 16:55:18,952 INFO  [PluginCompilerThread] Looking for plugins at /home/sunrise/.serviio/plugins
2012-08-13 16:55:18,968 INFO  [UpdateChecker] Checking if a new version is available
2012-08-13 16:55:18,957 INFO  [PluginCompilerThread] Started looking for plugins
2012-08-13 16:55:18,987 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2012-08-13 16:55:19,000 DEBUG [ProcessExecutor] Starting ffmpeg
2012-08-13 16:55:19,143 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-13 16:55:19,261 INFO  [WebServer] WebServer starting on port 8895
2012-08-13 16:55:19,277 DEBUG [DiscoveryManager] UPNP device 98e34aab-271a-3538-805b-234817c25d5b (192.168.0.21) is available
2012-08-13 16:55:19,288 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-13 16:55:19,291 INFO  [EventDispatcher] Starting EventDispatcher
2012-08-13 16:55:19,295 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:55:19,297 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-13 16:55:19,310 INFO  [RendererSearchSender] Searching for Renderer devices
2012-08-13 16:55:19,311 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-08-13 16:55:19,317 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:55:19,326 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:55:19,378 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2012-08-13 16:55:19,380 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 98e34aab-271a-3538-805b-234817c25d5b
2012-08-13 16:55:19,408 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.21:35489
2012-08-13 16:55:19,409 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.21
2012-08-13 16:55:19,489 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.21:35489
2012-08-13 16:55:19,489 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.21
2012-08-13 16:55:19,498 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.21:35489
2012-08-13 16:55:19,499 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.21
2012-08-13 16:55:19,970 DEBUG [WebServer] Incoming connection from /192.168.0.111:2095
2012-08-13 16:55:19,979 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.111
2012-08-13 16:55:19,986 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 98e34aab-271a-3538-805b-234817c25d5b from 192.168.0.111 (headers = [Accept: text/xml, application/xml,User-Agent: Mozilla/4.0 (compatible; UPnP/1.0; Windows NT/5.1),Host: 192.168.0.21:8895,Connection: Keep-Alive,Cache-Control: no-cache,Pragma: no-cache])
2012-08-13 16:55:19,987 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.111
2012-08-13 16:55:19,990 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Accept: text/xml, application/xml,User-Agent: Mozilla/4.0 (compatible; UPnP/1.0; Windows NT/5.1),Host: 192.168.0.21:8895,Connection: Keep-Alive,Cache-Control: no-cache,Pragma: no-cache]
2012-08-13 16:55:19,996 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.111
2012-08-13 16:55:20,768 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2012-08-13 16:55:21,194 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-08-13 16:55:25,393 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2012-08-13 16:55:31,196 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:55:31,200 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 98e34aab-271a-3538-805b-234817c25d5b
2012-08-13 16:55:33,009 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2012-08-13 16:55:43,011 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:55:43,015 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 98e34aab-271a-3538-805b-234817c25d5b
2012-08-13 16:55:44,825 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:46
2012-08-13 16:55:45,407 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-08-13 16:55:45,436 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-13 16:55:45,522 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-13 16:55:45,531 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-08-13 16:56:20,880 DEBUG [WebServer] I/O error: Connection reset
2012-08-13 16:56:31,639 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:56:31,641 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 98e34aab-271a-3538-805b-234817c25d5b
2012-08-13 16:56:33,448 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:52
2012-08-13 16:57:25,835 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface wlan0 (wlan0) and address 192.168.0.21, timeout = 0
2012-08-13 16:57:25,839 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 98e34aab-271a-3538-805b-234817c25d5b
Edit:
Something new in my Logs. Its infinite repeating following lines if I start my client on another machine, but the server still dont show up
2012-08-13 18:44:24,527 DEBUG [WebServer] Incoming connection from /192.168.0.20:59350
2012-08-13 18:44:24,528 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.20
2012-08-13 18:44:24,528 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.20:
2012-08-13 18:44:24,529 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.20
2012-08-13 18:44:24,536 DEBUG [ContentDirectory] Browse() called for renderer Unrecognized device (profile 1) with parameters: objectID = A_T^INI_57, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 0, sortCriteria =
2012-08-13 18:44:24,537 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-08-13 18:44:24,546 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
Post Mon Aug 13, 2012 6:14 pm
Re: Cant see server in local network (running on Ubuntu 10.1
what is the client? It looks like something is connecting from .111 as well as from .21 (localhost).
sunrise
Post Mon Aug 13, 2012 6:47 pm
.111 used foobar2000 with upnp plugin and .21/.20 used vlc. But both dont have the server in their list.
jnanthony14
Post Mon Aug 13, 2012 6:49 pm
I just installed a similar setup, I had to add exceptions in my packet filter for lan before anything would work. Even then I could never open serviio console on another pc. I just installed xrdp on my ubuntu box and opened serviio console that way.
If you can, run an nmap scan of the server ip and make sure you can see udp 1900 and tcp 8895.
I kept having a problem with my smp-n200. I could see serviio and get a file list but couldnt stream. Turns out port 1900 was closed.
execute this on your ubuntu computer and make sure the port is listening on the correct ip address.
netstat -an | grep 1900
netstat -an | grep 8895
mine looks like this
udp 0 0 0.0.0.0:1900 0.0.0.0:*
tcp 0 0 0.0.0.0:8895 0.0.0.0:* LISTEN
tcp 0 125160 192.168.100.1:8895 192.168.100.3:40360 ESTABLISHED
192.168.100.3 is my smp-n200, the ESTABLISHED shows me that it is working correctly
Post Mon Aug 13, 2012 6:55 pm
weird, .20 is talking to the server and browsing content. .111 also received device description so it went through the firewall and should see the server. Any chance of running DeviceSpy on a Windows box? (Intel tools, link in my signature)
sunrise
Post Mon Aug 13, 2012 7:03 pm
did the nmap scan:
Starting Nmap 5.21 ( http://nmap.org ) at 2012-08-13 21:00 CEST
Nmap scan report for 192.168.0.21
Host is up (0.0017s latency).
PORT     STATE SERVICE
8895/tcp open  unknown
MAC Address: xxxxxxxxxxxxxxxx (AzureWave)
Starting Nmap 5.21 ( http://nmap.org ) at 2012-08-13 21:03 CEST
Host is up (0.0043s latency).
PORT     STATE         SERVICE
1900/udp open|filtered upnp
MAC Address: xxxxxxxxxxxxx (AzureWave)
sunrise
Post Mon Aug 13, 2012 7:23 pm
zip wrote:weird, .20 is talking to the server and browsing content. .111 also received device description so it went through the firewall and should see the server. Any chance of running DeviceSpy on a Windows box? (Intel tools, link in my signature)
device-spy shows me my server:
but netstat not the open ports:
sunrise@sunrise-1005PE:~$ netstat -an | grep 1900
sunrise@sunrise-1005PE:~$ netstat -an | grep 8895
Post Mon Aug 13, 2012 7:28 pm
Are you running VLC on the same machine as DeviceSpy? It should work.
sunrise
Post Mon Aug 13, 2012 7:32 pm
zip wrote:Are you running VLC on the same machine as DeviceSpy? It should work.
I installed it now:
tcp        0      0 192.168.0.21:8895       192.168.0.112:2142      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2150      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2123      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2141      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2151      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2133      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2144      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2131      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2138      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2143      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2147      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2139      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2149      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2127      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2137      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2125      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2128      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2135      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2136      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2126      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2122      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2146      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2129      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2134      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2140      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2152      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2130      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2145      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2124      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.20:37891      ESTABLISHED
tcp        0      0 192.168.0.21:8895       192.168.0.112:2148      TIME_WAIT
tcp        0      0 192.168.0.21:8895       192.168.0.112:2132      TIME_WAIT
But why cant I connect from ubuntu client > ubuntu server ? Or over a ssh tunnel from windows client > ubuntu server?
Post Mon Aug 13, 2012 7:40 pm
I'm not a network specialist tbh, so someone else will have to help you.
sunrise
Post Tue Aug 14, 2012 7:01 am
Okay my main problem is caused by my fault. My Client (VLC) wasnt up to date... and the ssh tunneling doesnt work cause serviio need a bidirectional connection and ssh can only create a tunnel for tcp ports and not for udp ports...
Users browsing this forum: No registered users and 107 guests
