.avi file no sound on PS3 after upgrading to 1.0.1
xs2inattar
Post Sun Aug 12, 2012 11:37 pm
This avi file was working fine with 1.0. Stopped playing sound when upgraded to 1.0.1.
file details are as follows.
Media-Info
Complete name                            : \\RR-DS212PLUS\video\Movies\Dilwale Dulhaniya Le Jayenge (1995)\Dilwale Dulhaniya Le Jayenge (1995) - part1.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 700 MiB
Duration                                 : 1h 45mn
Overall bit rate                         : 929 Kbps
Writing application                      : Nandub v1.0rc2
Writing library                          : Nandub build 1852/release
Format                                   : MPEG-4 Visual
Format profile                           : Simple@L3
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 1h 45mn
Bit rate                                 : 787 Kbps
Width                                    : 656 pixels
Height                                   : 272 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.184
Stream size                              : 593 MiB (85%)
Writing library                          : XviD 1.0.3 (UTC 2004-12-20)
Format                                   : MPEG Audio
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 1h 45mn
Bit rate                                 : 128 Kbps
Stream size                              : 97.3 MiB (14%)
Alignment                                : Split accross interleaves
Interleave, duration                     : 24 ms (0.58 video frame)
Interleave, preload duration             : 1429 ms
Logs
2012-08-12 19:21:11,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:11,891 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:11,892 DEBUG [ResourceDeliveryProcessor] Request for resource 2332 and type 'MEDIA_ITEM' received
2012-08-12 19:21:11,892 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2332 (local)
2012-08-12 19:21:11,892 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2332)
2012-08-12 19:21:11,894 DEBUG [VideoDAOImpl] Reading a Video (id = 2332)
2012-08-12 19:21:11,897 DEBUG [VideoDeliveryEngine] Delivering item '2332' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:11,897 DEBUG [VideoDeliveryEngine] Delivering file 'Dilwale Dulhaniya Le Jayenge (1995) - part1.avi' in native format
2012-08-12 19:21:11,897 DEBUG [MediaItemDAOImpl] Getting file of media item 2332
2012-08-12 19:21:11,899 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2332) as read
2012-08-12 19:21:12,157 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 19:21:12,158 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 733947904
2012-08-12 19:21:12,158 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:12,159 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 0-733947903/733947904,Content-Length: 733947904,Date: Sun, 12 Aug 2012 23:21:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-12 19:21:12,273 DEBUG [WebServer] I/O error: Broken pipe
2012-08-12 19:21:12,277 DEBUG [WebServer] Incoming connection from /192.168.1.8:52921
2012-08-12 19:21:12,277 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,279 DEBUG [ResourceTransportRequestHandler] GET /resource/2332/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,Range: bytes=727187456-733947903]]
2012-08-12 19:21:12,279 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,307 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,308 DEBUG [ResourceDeliveryProcessor] Request for resource 2332 and type 'MEDIA_ITEM' received
2012-08-12 19:21:12,308 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2332 (local)
2012-08-12 19:21:12,327 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2332)
2012-08-12 19:21:12,329 DEBUG [VideoDAOImpl] Reading a Video (id = 2332)
2012-08-12 19:21:12,331 DEBUG [VideoDeliveryEngine] Delivering item '2332' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,331 DEBUG [VideoDeliveryEngine] Delivering file 'Dilwale Dulhaniya Le Jayenge (1995) - part1.avi' in native format
2012-08-12 19:21:12,332 DEBUG [MediaItemDAOImpl] Getting file of media item 2332
2012-08-12 19:21:12,333 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2332) as read
2012-08-12 19:21:12,467 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 19:21:12,467 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6760448
2012-08-12 19:21:12,468 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:12,468 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 727187456-733947903/733947904,Content-Length: 6760448,Date: Sun, 12 Aug 2012 23:21:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-12 19:21:12,564 DEBUG [WebServer] I/O error: Broken pipe
2012-08-12 19:21:12,568 DEBUG [WebServer] Incoming connection from /192.168.1.8:52920
2012-08-12 19:21:12,569 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,570 DEBUG [ResourceTransportRequestHandler] GET /resource/2332/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,Range: bytes=733872128-733947903]]
2012-08-12 19:21:12,571 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,572 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,573 DEBUG [ResourceDeliveryProcessor] Request for resource 2332 and type 'MEDIA_ITEM' received
2012-08-12 19:21:12,573 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2332 (local)
2012-08-12 19:21:12,573 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2332)
2012-08-12 19:21:12,575 DEBUG [VideoDAOImpl] Reading a Video (id = 2332)
2012-08-12 19:21:12,578 DEBUG [VideoDeliveryEngine] Delivering item '2332' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,578 DEBUG [VideoDeliveryEngine] Delivering file 'Dilwale Dulhaniya Le Jayenge (1995) - part1.avi' in native format
2012-08-12 19:21:12,578 DEBUG [MediaItemDAOImpl] Getting file of media item 2332
2012-08-12 19:21:12,580 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2332) as read
2012-08-12 19:21:12,583 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 19:21:12,583 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 75776
2012-08-12 19:21:12,584 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:12,584 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 733872128-733947903/733947904,Content-Length: 75776,Date: Sun, 12 Aug 2012 23:21:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-12 19:21:12,599 DEBUG [WebServer] Incoming connection from /192.168.1.8:52919
2012-08-12 19:21:12,600 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,601 DEBUG [ResourceTransportRequestHandler] GET /resource/2332/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,Range: bytes=727318528-733947903]]
2012-08-12 19:21:12,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:12,603 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,604 DEBUG [ResourceDeliveryProcessor] Request for resource 2332 and type 'MEDIA_ITEM' received
2012-08-12 19:21:12,604 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2332 (local)
2012-08-12 19:21:12,604 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2332)
2012-08-12 19:21:12,606 DEBUG [VideoDAOImpl] Reading a Video (id = 2332)
2012-08-12 19:21:12,609 DEBUG [VideoDeliveryEngine] Delivering item '2332' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:12,609 DEBUG [VideoDeliveryEngine] Delivering file 'Dilwale Dulhaniya Le Jayenge (1995) - part1.avi' in native format
2012-08-12 19:21:12,609 DEBUG [MediaItemDAOImpl] Getting file of media item 2332
2012-08-12 19:21:12,611 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2332) as read
2012-08-12 19:21:12,614 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 19:21:12,614 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6629376
2012-08-12 19:21:12,615 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:12,615 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 727318528-733947903/733947904,Content-Length: 6629376,Date: Sun, 12 Aug 2012 23:21:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-12 19:21:13,514 DEBUG [WebServer] Incoming connection from /192.168.1.8:52918
2012-08-12 19:21:13,515 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:13,516 DEBUG [ResourceTransportRequestHandler] GET /resource/840/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-08-12 19:21:13,517 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:13,518 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:13,519 DEBUG [ResourceDeliveryProcessor] Request for resource 840 and type 'COVER_IMAGE' received
2012-08-12 19:21:13,519 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 840)
2012-08-12 19:21:13,521 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 840
2012-08-12 19:21:13,521 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5711
2012-08-12 19:21:13,521 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:13,522 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5711,Date: Sun, 12 Aug 2012 23:21:13 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-08-12 19:21:15,295 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:15,297 DEBUG [ResourceTransportRequestHandler] GET /resource/2332/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,Range: bytes=0-]]
2012-08-12 19:21:15,297 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:21:15,299 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:15,299 DEBUG [ResourceDeliveryProcessor] Request for resource 2332 and type 'MEDIA_ITEM' received
2012-08-12 19:21:15,300 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2332 (local)
2012-08-12 19:21:15,300 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2332)
2012-08-12 19:21:15,302 DEBUG [VideoDAOImpl] Reading a Video (id = 2332)
2012-08-12 19:21:15,304 DEBUG [VideoDeliveryEngine] Delivering item '2332' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:21:15,305 DEBUG [VideoDeliveryEngine] Delivering file 'Dilwale Dulhaniya Le Jayenge (1995) - part1.avi' in native format
2012-08-12 19:21:15,305 DEBUG [MediaItemDAOImpl] Getting file of media item 2332
2012-08-12 19:21:15,306 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2332) as read
2012-08-12 19:21:15,347 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-12 19:21:15,347 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 733947904
2012-08-12 19:21:15,348 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-12 19:21:15,348 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 0-733947903/733947904,Content-Length: 733947904,Date: Sun, 12 Aug 2012 23:21:15 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
Post Mon Aug 13, 2012 6:34 pm
Re: .avi file no sound on PS3 after upgrading to 1.0.1
The log looks ok, the last line is sending the final file so there might be some lines after that that could be relevant. The file is not transcoding so not sure what could be wrong as there was no change in 1.0.1 from 1.0 in this area.
Maybe PS3 upgrade?
xs2inattar
Post Mon Aug 13, 2012 7:53 pm
Didnot upgrade ps3 firmware, so not sure what it could be.
Based on the media-info of the file, can you recommend any changes that i can make to ps3 profile so that the audio is converted to some other ps3 compatible format???
Post Tue Aug 14, 2012 6:08 am
This file is delivered in native format.
If you want to transcode to another supported format, edit profiles.xml file.
Replace the following line, and restart serviio service :
by
<Matches container="avi" />
Then all avi file will be transcoded to mpegts/mpeg2video/ac3
Post Tue Aug 14, 2012 12:20 pm
Can you confirm it works with 1.0 or 0.6.2?
