Folders are empty on UE40D8000
toast3r
Post Sat Aug 11, 2012 8:57 pm
Re: Folders are empty on UE40D8000
I tried restarting it from the console and from the services manager.
Regarding the weird IP, I'm really lost. I disconnected every single device from the network, including my server, except my lapto and my box and I can still ping this bloody IP.
I'm really confused now.
Post Sat Aug 11, 2012 9:47 pm
does the TV have a wifi and wired connections? If you use wired connection, disable wifi on the TV.
toast3r
Post Sat Aug 11, 2012 10:10 pm
You can't have both. You chose how you want to connect your TV to the network in the menu.
toast3r
Post Sun Aug 12, 2012 7:25 pm
It looks like it's something known if I refer yo the posts below. It seems to happen not only with Samsung TVs:
http://forum.serviio.org/viewtopic.php?f=10&t=4842
http://forum.serviio.org/viewtopic.php?f=11&t=6030
http://forum.serviio.org/viewtopic.php?f=5&t=4117
I couldn't find any solution in any of them though. I'm still searching but in of these posts it's says that it's working with Serviio 0.52
Post Mon Aug 13, 2012 6:20 pm
Right, so the last one says about changing router, any chance of borrowing one?
toast3r
Post Mon Aug 13, 2012 7:39 pm
Not really and sounds more like a workaround than a real fix to be honnest.
Post Mon Aug 13, 2012 7:42 pm
It looks like a setting somewhere on your network, so I don't think I can fix it on my end. Maybe there is a setting somewhere on your current router. Not sure why else it'd be giving the TV 2 IP addresses.
Previous
