problems with file recognition on upgrade to 1.0.1
rachbinoz
Post Thu Aug 16, 2012 9:12 am
I have just upgraded to the latest version and now 90% of the files that were recognisded before are no longer there?! :shock:
Any ideas on how i can find them or get back to my old version of Serviio?
Thank you
Post Thu Aug 16, 2012 11:13 am
Re: problems with file recognition on upgrade to 1.0.1
Serviio will recreate the whole library during the upgrade, so it might take some time to show all your files.
rachbinoz
Post Fri Aug 17, 2012 10:28 am
Thanks you are right they all show now.
New problem is that files that were playing now play for 1-3 seconds and then stop?! Any ideas what thats about?
Thanks for your help.
Post Fri Aug 17, 2012 10:50 am
has your library finished updating? it might be too busy for streaming
xs2inattar
Post Fri Aug 17, 2012 4:40 pm
make sure your transcoding temp folder has enuff space.
In linux if you are using /tmp as your transcoding folder then change it to something else. /tmp linux temp folder has limited space.
rachbinoz
Post Sat Aug 18, 2012 5:17 am
My library has finished upgrading.
I am sorry but i am not tech savvy enough to know what my transcoding temp folder is?! :oops: - or linux for that matter :?
All i know is that prior to the upgrade ALL of my movie files played fine...now i play one and it goes for a few seconds and then cuts off. It does not seem like a steaming issue because it cuts off suddenly and always in the same place each time (as though it is unable to play/recognise the file?) Really wierd as, like i say, they were all fine prior to upgrade.
Any advice would be greatly appreciated.
Thank you
Post Sat Aug 18, 2012 10:13 am
post detailed log (see my signature for how to do it), it might be due to failing (old) ffmpeg
