Serviio on ReadyNas Pro 6
Scouser
Post Mon Jan 16, 2012 7:02 pm
Had loads of problems with the stock ReadyDLNA and looked for an alternative.
Found Serviio, installed it on my Pro 6 and it has been working brilliantly now for several months.
Note that you will need Java 6 installed and I believe this is only available for x86 ReadyNAS machines.
You will also need a full feature ffmpeg. In the end I built my own. If you need an ffmpeg for x86 ReadyNas for serviio, contact me.
Thanks Petr for your excellent software.
Post Mon Jan 16, 2012 7:39 pm
Re: Serviio on ReadyNas Pro 6
Scouser wrote:Had loads of problems with the stock ReadyDLNA and looked for an alternative.
can u do me a full howto and send a copy of the ffmpeg build please then i can add it to our wiki. :)
Scouser
Post Mon Jan 16, 2012 7:43 pm
Sure. Give me a day or so and I will put it all together for you.
Post Mon Jan 16, 2012 7:45 pm
Scouser wrote:Sure. Give me a day or so and I will put it all together for you.
thanks, as i don't own most of these devices (would cost me a fortune) i am unable to do the guides myself so user help is always appreciated :)
jgasparine
Post Thu Aug 16, 2012 5:25 pm
Phil,
I can't seem to find instructions for ReadyNas installation on the Wiki. Do you still have plans to update the Wiki accordingly?
Return to User experiences
