.mkv file issue with 1.0
HankTheTurtle
Post Fri Aug 17, 2012 6:07 pm
I searched the forums and found other mkv issues, but nothing sounded quite like my problem. If it's been addressed, and I just couldn't tell because of my lack of fluency in technical jargon, I apologize.
I have a number of mkv files that played fine with 0.6.2, but now that I've upgraded to 1.0.1, there's a problem. They seem to play alright, but the duration shows as incredibly long (like, 200 to 500 hours). This makes it impossible to jump ahead at all. I haven't checked all my mkv files, but every one I have checked has had the same issue (though with different durations). I downloaded some sample mkv files that I will test out to see if any of them work any better.
I have a Samsung C series TV, and am using the C/D profile. I tried updating ffmpeg, but that didn't seem to help. Any suggestions? I know I should probably post a log file or something, but I don't know what exactly is needed. I already have debug on. Is it just the log file, or is there something else?
I've also had issues with jumping forward on certain wmv files. It just freezes and I can't get back to the menu or anything until the TV times out and turns itself off and on again. I've had this problem with all versions of Serviio, though, and from what I turned up through searching around is that there's really no fix for this at this point. Is that correct?
Post Sat Aug 18, 2012 10:32 am
Re: .mkv file issue with 1.0
the long duration happens for transcoded files. I dont think there has been any change in the c/d profile to add more file to be transcoded. You can post detailed log of then playing the file and ffmpeg -i of the file.
HankTheTurtle
Post Sun Aug 19, 2012 2:06 am
There's something else I hadn't noticed before, because I hadn't watched any of the files long enough to see it. There's a sync issue as well. Do you think that would be caused by the same issue?
Anyway, here's the info on the file. I think I did it right.
2012-08-18 15:52:40,640 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root' (filter: ALL) [No_Restriction]
2012-08-18 15:52:40,640 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-08-18 15:52:40,656 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-18 15:52:40,859 DEBUG [WebServer] Incoming connection from /192.168.1.50:59435
2012-08-18 15:52:40,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:40,859 DEBUG [ResourceTransportRequestHandler] GET /resource/579802/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,859 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:40,859 DEBUG [ResourceDeliveryProcessor] Request for resource 579802 and type 'COVER_IMAGE' received
2012-08-18 15:52:40,859 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 579802)
2012-08-18 15:52:40,859 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 579802
2012-08-18 15:52:40,859 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5389
2012-08-18 15:52:40,859 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:40,859 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5389,Date: Sat, 18 Aug 2012 19:52:40 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,890 DEBUG [WebServer] Incoming connection from /192.168.1.50:59436
2012-08-18 15:52:40,890 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:40,890 DEBUG [ResourceTransportRequestHandler] GET /resource/579803/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,890 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:40,890 DEBUG [ResourceDeliveryProcessor] Request for resource 579803 and type 'COVER_IMAGE' received
2012-08-18 15:52:40,890 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 579803)
2012-08-18 15:52:40,890 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 579803
2012-08-18 15:52:40,890 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3129
2012-08-18 15:52:40,890 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:40,890 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3129,Date: Sat, 18 Aug 2012 19:52:40 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,890 DEBUG [WebServer] Incoming connection from /192.168.1.50:59437
2012-08-18 15:52:40,890 DEBUG [ResourceTransportRequestHandler] GET /resource/579804/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,906 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:40,906 DEBUG [ResourceDeliveryProcessor] Request for resource 579804 and type 'COVER_IMAGE' received
2012-08-18 15:52:40,906 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 579804)
2012-08-18 15:52:40,906 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 579804
2012-08-18 15:52:40,906 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4539
2012-08-18 15:52:40,906 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:40,906 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4539,Date: Sat, 18 Aug 2012 19:52:40 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,906 DEBUG [WebServer] Incoming connection from /192.168.1.50:59438
2012-08-18 15:52:40,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:40,921 DEBUG [ResourceTransportRequestHandler] GET /resource/579805/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,921 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:40,921 DEBUG [ResourceDeliveryProcessor] Request for resource 579805 and type 'COVER_IMAGE' received
2012-08-18 15:52:40,921 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 579805)
2012-08-18 15:52:40,921 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 579805
2012-08-18 15:52:40,921 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2108
2012-08-18 15:52:40,921 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:40,921 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2108,Date: Sat, 18 Aug 2012 19:52:40 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,921 DEBUG [WebServer] Incoming connection from /192.168.1.50:59439
2012-08-18 15:52:40,921 DEBUG [ResourceTransportRequestHandler] GET /resource/579806/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:40,921 DEBUG [ResourceDeliveryProcessor] Request for resource 579806 and type 'COVER_IMAGE' received
2012-08-18 15:52:40,921 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 579806)
2012-08-18 15:52:40,937 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 579806
2012-08-18 15:52:40,937 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5287
2012-08-18 15:52:40,937 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:40,937 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5287,Date: Sat, 18 Aug 2012 19:52:40 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-18 15:52:45,171 DEBUG [WebServer] Incoming connection from /192.168.1.50:35602
2012-08-18 15:52:45,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:45,171 DEBUG [ResourceTransportRequestHandler] HEAD /resource/552519/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.4:8895]]
2012-08-18 15:52:45,171 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:45,171 DEBUG [ResourceDeliveryProcessor] Request for resource 552519 and type 'MEDIA_ITEM' received
2012-08-18 15:52:45,171 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 552519 (local)
2012-08-18 15:52:45,171 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 552519)
2012-08-18 15:52:45,171 DEBUG [VideoDAOImpl] Reading a Video (id = 552519)
2012-08-18 15:52:45,187 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 552519, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-18 15:52:45,187 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv
2012-08-18 15:52:45,187 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-18 15:52:45,187 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-18 15:52:45,187 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 19:52:45 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-18 15:52:45,187 DEBUG [WebServer] Incoming connection from /192.168.1.50:48635
2012-08-18 15:52:45,187 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:45,187 DEBUG [ResourceTransportRequestHandler] GET /resource/552519/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.4:8895]]
2012-08-18 15:52:45,187 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:45,187 DEBUG [ResourceDeliveryProcessor] Request for resource 552519 and type 'MEDIA_ITEM' received
2012-08-18 15:52:45,187 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 552519 (local)
2012-08-18 15:52:45,187 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 552519)
2012-08-18 15:52:45,187 DEBUG [VideoDAOImpl] Reading a Video (id = 552519)
2012-08-18 15:52:45,203 DEBUG [VideoDeliveryEngine] Delivering item '552519' for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:45,203 DEBUG [VideoDeliveryEngine] Delivering file 'Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv' using transcoding
2012-08-18 15:52:45,203 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-552522-7-ORIGINAL.stf', will stop the job
2012-08-18 15:52:45,203 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-552522-7-ORIGINAL.stf'
2012-08-18 15:52:45,281 DEBUG [TranscodingJobListener] Deleted temp file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-552522-7-ORIGINAL.stf': true
2012-08-18 15:52:45,281 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:45,281 DEBUG [MediaItemDAOImpl] Getting file of media item 552519
2012-08-18 15:52:45,281 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\TV\Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv
2012-08-18 15:52:45,281 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i E:\TV\Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-552519-7-ORIGINAL.stf
2012-08-18 15:52:46,781 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-18 15:52:46,796 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-18 15:52:46,796 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 552519) as read
2012-08-18 15:52:46,812 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-18 15:52:46,812 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-18 15:52:46,812 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-18 15:52:46,812 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1692.0/1692,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 19:52:46 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=1692000;]]
2012-08-18 15:52:47,328 DEBUG [WebServer] Incoming connection from /192.168.1.50:41940
2012-08-18 15:52:47,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-18 15:52:47,328 DEBUG [ResourceTransportRequestHandler] HEAD /resource/552519/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-18 15:52:47,328 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-18 15:52:47,328 DEBUG [ResourceDeliveryProcessor] Request for resource 552519 and type 'MEDIA_ITEM' received
2012-08-18 15:52:47,328 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 552519 (local)
2012-08-18 15:52:47,328 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 552519)
2012-08-18 15:52:47,343 DEBUG [VideoDAOImpl] Reading a Video (id = 552519)
2012-08-18 15:52:47,343 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 552519, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-18 15:52:47,343 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv
2012-08-18 15:52:47,343 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-18 15:52:47,343 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 552519)
2012-08-18 15:52:47,343 DEBUG [MediaItemDAOImpl] Getting file of media item 552519
2012-08-18 15:52:47,343 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-18 15:52:47,343 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sat, 18 Aug 2012 19:52:47 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Adam>cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\TV\Weeds.S08E07.720p.HDTV.x264-IM
MERSE.mkv"
ffmpeg version N-43594-gf0896a6 Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug 15 2012 21:25:48 with gcc 4.7.1 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l
ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj
peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
  libavutil      51. 69.100 / 51. 69.100
  libavcodec     54. 52.100 / 54. 52.100
  libavformat    54. 23.101 / 54. 23.101
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3.  9.100 /  3.  9.100
  libswscale      2.  1.101 /  2.  1.101
Input #0, matroska,webm, from 'E:\TV\Weeds.S08E07.720p.HDTV.x264-IMMERSE.mkv':
  Duration: 00:28:12.90, start: 0.000000, bitrate: 3168 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x714, SAR 1:1 DAR 640:357
, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
Like I said, I didn't have this problem with 0.6.2 or earlier versions. There was a similar problem with a few files before (though I can't remember if they were mkv files), but they were so few that I just avoided those files. This is with all mkv files that I've tried so far.
HankTheTurtle
Post Sun Aug 19, 2012 5:41 am
Hmm. After a restart of the Serviio service, the above file seems to play fine (as do many others), but I'm still having the issue with other files that played fine pre-1.0.
Here's the info for a file that still won't work right. It's hard to tell where the relevant information starts and stops in the debug log, but I think this is it.
2012-08-19 01:01:07,781 DEBUG [VideoDeliveryEngine] Delivering item '551276' for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 01:01:07,781 DEBUG [VideoDeliveryEngine] Delivering file 'Jack's POV 16 - Scene 06 - Credits.mkv' using transcoding
2012-08-19 01:01:07,781 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-551388-7-ORIGINAL.stf', will stop the job
2012-08-19 01:01:07,781 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-551388-7-ORIGINAL.stf'
2012-08-19 01:01:07,796 DEBUG [TranscodingJobListener] Deleted temp file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-551388-7-ORIGINAL.stf': true
2012-08-19 01:01:07,796 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 01:01:07,796 DEBUG [MediaItemDAOImpl] Getting file of media item 551276
2012-08-19 01:01:07,796 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: F:\Tor\HC\POV\HD\Jack's POV\Jack's POV 16\Jack's POV 16 - Scene 06 - Credits.mkv
2012-08-19 01:01:07,796 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i F:\Tor\HC\POV\HD\Jack's POV\Jack's POV 16\Jack's POV 16 - Scene 06 - Credits.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-551276-7-ORIGINAL.stf
2012-08-19 01:01:09,296 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-19 01:01:09,312 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Jack's POV 16 - Scene 06 - Credits.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-19 01:01:09,312 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 551276) as read
2012-08-19 01:01:09,312 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-19 01:01:09,312 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 01:01:09,312 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 01:01:09,312 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-28.0/28,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 05:01:09 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=28000;]]
2012-08-19 01:01:09,609 DEBUG [WebServer] Incoming connection from /192.168.1.50:41156
2012-08-19 01:01:09,609 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-19 01:01:09,609 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551276/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-19 01:01:09,609 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 01:01:09,609 DEBUG [ResourceDeliveryProcessor] Request for resource 551276 and type 'MEDIA_ITEM' received
2012-08-19 01:01:09,609 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551276 (local)
2012-08-19 01:01:09,609 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551276)
2012-08-19 01:01:09,609 DEBUG [VideoDAOImpl] Reading a Video (id = 551276)
2012-08-19 01:01:09,609 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551276, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 01:01:09,609 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Jack's POV 16 - Scene 06 - Credits.mkv
2012-08-19 01:01:09,625 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Jack's POV 16 - Scene 06 - Credits.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-19 01:01:09,625 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551276)
2012-08-19 01:01:09,625 DEBUG [MediaItemDAOImpl] Getting file of media item 551276
2012-08-19 01:01:09,625 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 01:01:09,625 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 05:01:09 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-19 01:01:09,625 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-19 01:01:18,312 DEBUG [WebServer] Incoming connection from /192.168.1.50:38371
2012-08-19 01:01:18,312 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-19 01:01:18,312 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551276/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-19 01:01:18,328 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 01:01:18,328 DEBUG [ResourceDeliveryProcessor] Request for resource 551276 and type 'MEDIA_ITEM' received
2012-08-19 01:01:18,328 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551276 (local)
2012-08-19 01:01:18,328 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551276)
2012-08-19 01:01:18,328 DEBUG [VideoDAOImpl] Reading a Video (id = 551276)
2012-08-19 01:01:18,328 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551276, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 01:01:18,328 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Jack's POV 16 - Scene 06 - Credits.mkv
2012-08-19 01:01:18,328 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Jack's POV 16 - Scene 06 - Credits.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-19 01:01:18,328 DEBUG [MediaItemDAOImpl] Getting file of media item 551276
2012-08-19 01:01:18,328 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 01:01:18,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 05:01:18 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\Tor\HC\POV\HD\Jack's POV\Jack's P
OV 16\Jack's POV 16 - Scene 06 - Credits.mkv"
ble-zlib
Input #0, matroska,webm, from 'F:\Tor\HC\POV\HD\Jack's POV\Jack's POV 16\Jack's
POV 16 - Scene 06 - Credits.mkv':
    creation_time   : 2010-11-29 00:36:00
  Duration: 00:00:28.84, start: 0.000000, bitrate: 1928 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9],
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), s16, 640 kb/s (default)
Post Sun Aug 19, 2012 11:10 am
did you make any change to the c/d/e profile? It should play without transcoding.
adebian
Post Sun Aug 19, 2012 12:57 pm
I have the exact same problem on a Samsung UE40D5500 since 1.0, i can't forward/backward on most mkv files and the duration is shown as 00:00:00
Here is some debug log from an mkv files that worked pre-1.0:
2012-08-19 15:51:55,267 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.2, timeout = 0
2012-08-19 15:51:55,267 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 83403509-60a4-3ac0-bae1-94340baf2344
2012-08-19 15:51:57,232 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:37
2012-08-19 15:52:03,901 DEBUG [WebServer] Incoming connection from /192.168.1.201:54859
2012-08-19 15:52:03,902 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:03,902 DEBUG [ResourceTransportRequestHandler] HEAD /resource/667/MEDIA_ITEM/AVC_TS_HD_DTS_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.2:8895]]
2012-08-19 15:52:03,903 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:03,903 DEBUG [ResourceDeliveryProcessor] Request for resource 667 and type 'MEDIA_ITEM' received
2012-08-19 15:52:03,903 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 667 (local)
2012-08-19 15:52:03,903 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:03,904 DEBUG [VideoDAOImpl] Reading a Video (id = 667)
2012-08-19 15:52:03,904 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 667, format AVC_TS_HD_DTS_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 15:52:03,905 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv
2012-08-19 15:52:03,905 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv: AVC_TS_HD_DTS_ISO
2012-08-19 15:52:03,905 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 15:52:03,905 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 12:52:03 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_DTS_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-19 15:52:03,913 DEBUG [WebServer] Incoming connection from /192.168.1.201:39421
2012-08-19 15:52:03,913 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:03,913 DEBUG [ResourceTransportRequestHandler] GET /resource/667/MEDIA_ITEM/AVC_TS_HD_DTS_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.2:8895]]
2012-08-19 15:52:03,914 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:03,914 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:03,914 DEBUG [ResourceDeliveryProcessor] Request for resource 667 and type 'MEDIA_ITEM' received
2012-08-19 15:52:03,914 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 667 (local)
2012-08-19 15:52:03,914 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:03,915 DEBUG [VideoDAOImpl] Reading a Video (id = 667)
2012-08-19 15:52:03,915 DEBUG [VideoDeliveryEngine] Delivering item '667' for client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:03,915 DEBUG [VideoDeliveryEngine] Delivering file 'Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv' using transcoding
2012-08-19 15:52:03,915 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:03,974 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-19 15:52:03,976 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv: AVC_TS_HD_DTS_ISO
2012-08-19 15:52:03,976 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 667) as read
2012-08-19 15:52:03,982 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-19 15:52:03,982 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 15:52:03,983 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:03,983 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-6143.0/6143,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 12:52:03 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_DTS_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=6143000;]]
2012-08-19 15:52:07,365 DEBUG [WebServer] Incoming connection from /192.168.1.201:44050
2012-08-19 15:52:07,366 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:07,367 DEBUG [ResourceTransportRequestHandler] HEAD /resource/667/MEDIA_ITEM/AVC_TS_HD_DTS_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-19 15:52:07,368 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:07,369 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:07,369 DEBUG [ResourceDeliveryProcessor] Request for resource 667 and type 'MEDIA_ITEM' received
2012-08-19 15:52:07,370 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 667 (local)
2012-08-19 15:52:07,370 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:07,371 DEBUG [VideoDAOImpl] Reading a Video (id = 667)
2012-08-19 15:52:07,373 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 667, format AVC_TS_HD_DTS_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 15:52:07,373 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv
2012-08-19 15:52:07,374 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv: AVC_TS_HD_DTS_ISO
2012-08-19 15:52:07,374 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:07,375 DEBUG [MediaItemDAOImpl] Getting file of media item 667
2012-08-19 15:52:07,377 DEBUG [SubtitlesService] Found subtitle file: E:\Movies\Movies\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.srt
2012-08-19 15:52:07,377 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 15:52:07,377 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 12:52:07 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,CaptionInfo.sec: http://192.168.1.2:8895/resource/667/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_DTS_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-19 15:52:07,382 DEBUG [WebServer] Incoming connection from /192.168.1.201:60430
2012-08-19 15:52:07,383 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:07,384 DEBUG [ResourceTransportRequestHandler] HEAD /resource/667/MEDIA_ITEM/AVC_TS_HD_DTS_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-19 15:52:07,384 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:07,386 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:07,386 DEBUG [ResourceDeliveryProcessor] Request for resource 667 and type 'MEDIA_ITEM' received
2012-08-19 15:52:07,386 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 667 (local)
2012-08-19 15:52:07,386 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:07,387 DEBUG [VideoDAOImpl] Reading a Video (id = 667)
2012-08-19 15:52:07,388 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 667, format AVC_TS_HD_DTS_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 15:52:07,388 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv
2012-08-19 15:52:07,388 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.mkv: AVC_TS_HD_DTS_ISO
2012-08-19 15:52:07,388 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:07,389 DEBUG [MediaItemDAOImpl] Getting file of media item 667
2012-08-19 15:52:07,389 DEBUG [SubtitlesService] Found subtitle file: E:\Movies\Movies\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.srt
2012-08-19 15:52:07,390 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 15:52:07,390 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Sun, 19 Aug 2012 12:52:07 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,CaptionInfo.sec: http://192.168.1.2:8895/resource/667/SUBTITLE.srt,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_DTS_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-19 15:52:07,393 DEBUG [WebServer] Incoming connection from /192.168.1.201:40288
2012-08-19 15:52:07,394 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:07,394 DEBUG [ResourceTransportRequestHandler] GET /resource/667/SUBTITLE.srt HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Background]]
2012-08-19 15:52:07,395 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:07,395 DEBUG [ResourceDeliveryProcessor] Request for resource 667 and type 'SUBTITLE' received
2012-08-19 15:52:07,395 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 667)
2012-08-19 15:52:07,395 DEBUG [MediaItemDAOImpl] Getting file of media item 667
2012-08-19 15:52:07,396 DEBUG [SubtitlesService] Found subtitle file: E:\Movies\Movies\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT\Man.on.a.Ledge.2012.1080p.BluRay.x264.DTS.RoSubbed-CzT.srt
2012-08-19 15:52:07,396 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 667
2012-08-19 15:52:07,414 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 90830
2012-08-19 15:52:07,414 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:07,414 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: smi/caption,Content-Length: 90830,Date: Sun, 19 Aug 2012 12:52:07 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Background]]
2012-08-19 15:52:12,445 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-19 15:52:12,445 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-19 15:52:12,447 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-19 15:52:12,512 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-08-19 15:52:15,217 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-08-19 15:52:15,356 DEBUG [WebServer] Incoming connection from /192.168.1.201:42506
2012-08-19 15:52:15,356 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,357 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.201:
2012-08-19 15:52:15,357 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,360 DEBUG [ContentDirectory] Browse() called for renderer UE40D5500 (profile 7) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-08-19 15:52:15,360 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-19 15:52:15,360 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-08-19 15:52:15,363 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-19 15:52:15,370 DEBUG [WebServer] Incoming connection from /192.168.1.201:44931
2012-08-19 15:52:15,370 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,371 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.201:
2012-08-19 15:52:15,371 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,374 DEBUG [ContentDirectory] Browse() called for renderer UE40D5500 (profile 7) with parameters: objectID = V_M, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 30, sortCriteria =
2012-08-19 15:52:15,374 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-19 15:52:15,374 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-08-19 15:52:15,383 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-19 15:52:15,605 DEBUG [WebServer] Incoming connection from /192.168.1.201:40289
2012-08-19 15:52:15,605 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,606 DEBUG [ResourceTransportRequestHandler] GET /resource/1157/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,606 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,606 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,606 DEBUG [ResourceDeliveryProcessor] Request for resource 1157 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,607 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1157)
2012-08-19 15:52:15,607 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1157
2012-08-19 15:52:15,607 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5288
2012-08-19 15:52:15,607 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,607 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5288,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,687 DEBUG [WebServer] Incoming connection from /192.168.1.201:40290
2012-08-19 15:52:15,688 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,688 DEBUG [ResourceTransportRequestHandler] GET /resource/1159/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,689 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,689 DEBUG [ResourceDeliveryProcessor] Request for resource 1159 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,689 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1159)
2012-08-19 15:52:15,689 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1159
2012-08-19 15:52:15,689 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5607
2012-08-19 15:52:15,690 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,690 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5607,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,760 DEBUG [WebServer] Incoming connection from /192.168.1.201:40291
2012-08-19 15:52:15,763 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,764 DEBUG [ResourceTransportRequestHandler] GET /resource/1160/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,764 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,764 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,764 DEBUG [ResourceDeliveryProcessor] Request for resource 1160 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,764 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1160)
2012-08-19 15:52:15,765 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1160
2012-08-19 15:52:15,765 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5607
2012-08-19 15:52:15,765 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5607,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,846 DEBUG [WebServer] Incoming connection from /192.168.1.201:40292
2012-08-19 15:52:15,847 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,848 DEBUG [ResourceTransportRequestHandler] GET /resource/1745/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,848 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,848 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,848 DEBUG [ResourceDeliveryProcessor] Request for resource 1745 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,848 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1745)
2012-08-19 15:52:15,849 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1745
2012-08-19 15:52:15,849 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4930
2012-08-19 15:52:15,849 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,849 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4930,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,912 DEBUG [WebServer] Incoming connection from /192.168.1.201:40293
2012-08-19 15:52:15,912 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,913 DEBUG [ResourceTransportRequestHandler] GET /resource/1626/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,913 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,913 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,913 DEBUG [ResourceDeliveryProcessor] Request for resource 1626 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,913 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1626)
2012-08-19 15:52:15,914 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1626
2012-08-19 15:52:15,914 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5853
2012-08-19 15:52:15,914 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,914 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5853,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,991 DEBUG [WebServer] Incoming connection from /192.168.1.201:40294
2012-08-19 15:52:15,992 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,992 DEBUG [ResourceTransportRequestHandler] GET /resource/1161/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:15,993 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:15,993 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:15,993 DEBUG [ResourceDeliveryProcessor] Request for resource 1161 and type 'COVER_IMAGE' received
2012-08-19 15:52:15,993 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1161)
2012-08-19 15:52:15,993 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1161
2012-08-19 15:52:15,994 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5489
2012-08-19 15:52:15,994 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:15,994 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5489,Date: Sun, 19 Aug 2012 12:52:15 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,066 DEBUG [WebServer] Incoming connection from /192.168.1.201:40295
2012-08-19 15:52:16,067 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,068 DEBUG [ResourceTransportRequestHandler] GET /resource/1162/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,068 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,068 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:16,068 DEBUG [ResourceDeliveryProcessor] Request for resource 1162 and type 'COVER_IMAGE' received
2012-08-19 15:52:16,068 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1162)
2012-08-19 15:52:16,069 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1162
2012-08-19 15:52:16,069 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5320
2012-08-19 15:52:16,069 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:16,069 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5320,Date: Sun, 19 Aug 2012 12:52:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,139 DEBUG [WebServer] Incoming connection from /192.168.1.201:40296
2012-08-19 15:52:16,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,140 DEBUG [ResourceTransportRequestHandler] GET /resource/1753/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,141 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:16,141 DEBUG [ResourceDeliveryProcessor] Request for resource 1753 and type 'COVER_IMAGE' received
2012-08-19 15:52:16,141 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1753)
2012-08-19 15:52:16,141 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1753
2012-08-19 15:52:16,141 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5103
2012-08-19 15:52:16,141 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:16,141 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5103,Date: Sun, 19 Aug 2012 12:52:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,287 DEBUG [WebServer] Incoming connection from /192.168.1.201:40297
2012-08-19 15:52:16,288 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,289 DEBUG [ResourceTransportRequestHandler] GET /resource/1164/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,290 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,291 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:16,291 DEBUG [ResourceDeliveryProcessor] Request for resource 1164 and type 'COVER_IMAGE' received
2012-08-19 15:52:16,291 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1164)
2012-08-19 15:52:16,293 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1164
2012-08-19 15:52:16,293 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4923
2012-08-19 15:52:16,293 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:16,293 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4923,Date: Sun, 19 Aug 2012 12:52:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,359 DEBUG [WebServer] Incoming connection from /192.168.1.201:40298
2012-08-19 15:52:16,360 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,362 DEBUG [ResourceTransportRequestHandler] GET /resource/1522/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.2:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-19 15:52:16,362 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.201
2012-08-19 15:52:16,363 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.201, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 15:52:16,364 DEBUG [ResourceDeliveryProcessor] Request for resource 1522 and type 'COVER_IMAGE' received
2012-08-19 15:52:16,364 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1522)
2012-08-19 15:52:16,365 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1522
2012-08-19 15:52:16,365 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5326
2012-08-19 15:52:16,366 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 15:52:16,366 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5326,Date: Sun, 19 Aug 2012 12:52:16 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
HankTheTurtle
Post Sun Aug 19, 2012 1:49 pm
zip wrote:did you make any change to the c/d/e profile? It should play without transcoding.
No. I added something someone mentioned in a thread around here to try to fix it, but I reverted back when it had no effect.
Post Sun Aug 19, 2012 7:51 pm
try to remove this line from profiles.xml in the c/d/e profile:
<Matches container="matroska" mkvHeaderCompressed="true" />
Can you also post MediaInfo of the mkv file? This line has been added to enable playing files with mkv header compression.
adebian
Post Sun Aug 19, 2012 8:39 pm
Indeed removing that line fixes the problem for all mkv files i tested on. Everything work again as it should.
By metainfo u mean the ffmpeg -i output ? :
g-config
Input #0, matroska,webm, from 'Carnage.mkv':
    creation_time   : 2012-03-02 11:10:18
  Duration: 01:19:37.73, start: 0.000000, bitrate: 9825 kb/s
    Stream #0:0(rum): Subtitle: text (default) (forced)
    Stream #0:1(eng): Video: h264 (High), yuv420p, 1920x824, SAR 1:1 DAR 240:103
    Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.0(side), s16, 1536 kb/s (def
ault)
HankTheTurtle
Post Mon Aug 20, 2012 3:12 am
zip wrote:try to remove this line from profiles.xml in the c/d/e profile:
I removed that line and it didn't seem to have an effect.
HankTheTurtle
Post Thu Aug 23, 2012 3:54 pm
Restarting Serviio and Serviio Service didn't change anything, but I had to restart my computer and now they seem to play fine. Thanks.
I've got another issue with a couple mp4 files, though. It might be a similar problem, but I'm not sure. The duration comes up as over 5 hours for both these files (I think both show the same number for their duration), but unlike the mkv issue I was having, these don't play smoothly otherwise. There's an image, but every 2 seconds or so it pauses and says "Preparing to play". Any Ideas?
Here are the ffmpeg logs:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\Tor\HC\POV\HD\IKTG - 1080.mp4"
ble-zlib
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'F:\Tor\HC\POV\HD\IKTG - 1080.mp4':
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    encoder         : Lavf54.3.100
  Duration: 00:37:45.94, start: 0.000000, bitrate: 12632 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080
 [SAR 1:1 DAR 16:9], 12001 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc
      handler_name    : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 128
 kb/s
      handler_name    : SoundHandler
Codec 0x0 is not in the full list.
    Stream #0:2(und): Data: unknown_codec (rtp  / 0x20707472)
      handler_name    : GPAC ISO Hint Handler
    Stream #0:3(und): Data: unknown_codec (rtp  / 0x20707472)
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\Tor\HC\_HD\B\LL - 1080.mp4"
ble-zlib
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'F:\Tor\HC\_HD\B\LL - 1080.mp4':
    major_brand     : isom
    minor_version   : 512
  Duration: 00:19:44.30, start: 0.000000, bitrate: 12556 kb/s
 [SAR 1:1 DAR 16:9], 11928 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc
 kb/s
And what I think is the relevant part of the debug log:
2012-08-23 10:36:16,098 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 7) with parameters: objectID = V_F^FOL_R25$F8764$F8765$F8766$F8770, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx, sec:dcmInfo, sec:MetaFileInfo,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 10, count = 1, sortCriteria =
2012-08-23 10:36:16,098 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-08-23 10:36:16,098 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 8770 [No_Restriction]
2012-08-23 10:36:16,098 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 8770 (from=10, count=1) [No_Restriction]
2012-08-23 10:36:16,129 DEBUG [GenreDAOImpl] Reading a Genre (id = 5)
2012-08-23 10:36:16,129 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551215)
2012-08-23 10:36:16,129 DEBUG [MediaItemDAOImpl] Getting file of media item 551215
2012-08-23 10:36:16,129 DEBUG [VideoDAOImpl] Reading a Video (id = 551215)
2012-08-23 10:36:16,129 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551215 and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:36:16,129 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:36:16,129 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:36:16,129 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:36:16,129 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578503)
2012-08-23 10:36:16,129 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 8770 (filter: ALL) [No_Restriction]
2012-08-23 10:36:16,144 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-08-23 10:36:16,160 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-23 10:36:16,207 DEBUG [WebServer] Incoming connection from /192.168.1.50:46961
2012-08-23 10:36:16,207 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:16,207 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551215/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.4:8895]]
2012-08-23 10:36:16,207 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:16,207 DEBUG [ResourceDeliveryProcessor] Request for resource 551215 and type 'MEDIA_ITEM' received
2012-08-23 10:36:16,207 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551215 (local)
2012-08-23 10:36:16,207 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551215)
2012-08-23 10:36:16,207 DEBUG [VideoDAOImpl] Reading a Video (id = 551215)
2012-08-23 10:36:16,207 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551215, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:36:16,207 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file IKTG - 1080.mp4
2012-08-23 10:36:16,207 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:36:16,207 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:36:16,207 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:36:16,207 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:36:16,207 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:36:16 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-23 10:36:16,223 DEBUG [WebServer] Incoming connection from /192.168.1.50:34086
2012-08-23 10:36:16,223 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:16,223 DEBUG [ResourceTransportRequestHandler] GET /resource/551215/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.4:8895]]
2012-08-23 10:36:16,223 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:16,223 DEBUG [ResourceDeliveryProcessor] Request for resource 551215 and type 'MEDIA_ITEM' received
2012-08-23 10:36:16,223 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551215 (local)
2012-08-23 10:36:16,223 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551215)
2012-08-23 10:36:16,223 DEBUG [VideoDAOImpl] Reading a Video (id = 551215)
2012-08-23 10:36:16,238 DEBUG [VideoDeliveryEngine] Delivering item '551215' for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:16,238 DEBUG [VideoDeliveryEngine] Delivering file 'IKTG - 1080.mp4' using transcoding
2012-08-23 10:36:16,238 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-551214-7-ORIGINAL.stf', will stop the job
2012-08-23 10:36:16,238 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-551214-7-ORIGINAL.stf'
2012-08-23 10:36:16,238 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-2104,5,main]
2012-08-23 10:36:16,238 DEBUG [ProcessUtils] Killing the Windows process: 772
2012-08-23 10:36:16,269 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-23 10:36:16,301 DEBUG [TranscodingJobListener] Deleted temp file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-551214-7-ORIGINAL.stf': true
2012-08-23 10:36:16,301 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:16,301 DEBUG [MediaItemDAOImpl] Getting file of media item 551215
2012-08-23 10:36:16,301 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: F:\Tor\HC\POV\HD\IKTG - 1080.mp4
2012-08-23 10:36:16,316 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Tor\HC\POV\HD\IKTG - 1080.mp4 -y -threads 2 -copyts -c:v mpeg2video -b:v 20000k -maxrate:v 20000k -bufsize:v 20000k -r 30000/1001 -g 15 -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-551215-7-ORIGINAL.stf
2012-08-23 10:36:18,848 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-23 10:36:18,863 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:36:18,863 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:36:18,863 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:36:18,863 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 551215) as read
2012-08-23 10:36:18,894 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-23 10:36:18,894 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-23 10:36:18,894 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:36:18,894 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1686.0/1686,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:36:18 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=1686000;]]
2012-08-23 10:36:25,676 DEBUG [WebServer] Incoming connection from /192.168.1.50:51865
2012-08-23 10:36:25,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:25,676 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551215/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-23 10:36:25,676 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:25,676 DEBUG [ResourceDeliveryProcessor] Request for resource 551215 and type 'MEDIA_ITEM' received
2012-08-23 10:36:25,723 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551215 (local)
2012-08-23 10:36:25,723 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551215)
2012-08-23 10:36:25,723 DEBUG [VideoDAOImpl] Reading a Video (id = 551215)
2012-08-23 10:36:25,723 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551215, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:36:25,723 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file IKTG - 1080.mp4
2012-08-23 10:36:25,723 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:36:25,723 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:36:25,723 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:36:25,723 DEBUG [MediaItemDAOImpl] Getting file of media item 551215
2012-08-23 10:36:25,754 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:36:25,754 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:36:25 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-23 10:36:25,894 DEBUG [WebServer] Incoming connection from /192.168.1.50:52505
2012-08-23 10:36:25,894 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:25,894 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551215/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-23 10:36:25,894 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:25,894 DEBUG [ResourceDeliveryProcessor] Request for resource 551215 and type 'MEDIA_ITEM' received
2012-08-23 10:36:25,894 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551215 (local)
2012-08-23 10:36:25,894 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551215)
2012-08-23 10:36:25,894 DEBUG [VideoDAOImpl] Reading a Video (id = 551215)
2012-08-23 10:36:25,894 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551215, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:36:25,894 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file IKTG - 1080.mp4
2012-08-23 10:36:25,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:36:25,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:36:25,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file IKTG - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:36:25,894 DEBUG [MediaItemDAOImpl] Getting file of media item 551215
2012-08-23 10:36:25,894 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:36:25,894 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:36:25 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-23 10:36:26,176 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2012-08-23 10:36:26,176 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2012-08-23 10:36:26,301 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-08-23 10:36:26,457 DEBUG [WebServer] Incoming connection from /192.168.1.50:52276
2012-08-23 10:36:26,457 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:26,488 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.50:
2012-08-23 10:36:26,488 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:26,504 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-23 10:36:27,004 DEBUG [WebServer] Incoming connection from /192.168.1.50:41261
2012-08-23 10:36:27,004 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:27,004 DEBUG [ResourceTransportRequestHandler] GET /resource/578502/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:36:27,004 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:27,004 DEBUG [ResourceDeliveryProcessor] Request for resource 578502 and type 'COVER_IMAGE' received
2012-08-23 10:36:27,004 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578502)
2012-08-23 10:36:27,019 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578502
2012-08-23 10:36:27,019 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4834
2012-08-23 10:36:27,019 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:36:27,019 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4834,Date: Thu, 23 Aug 2012 14:36:27 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:36:27,019 DEBUG [WebServer] Incoming connection from /192.168.1.50:41262
2012-08-23 10:36:27,019 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:27,019 DEBUG [ResourceTransportRequestHandler] GET /resource/578503/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:36:27,051 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:36:27,051 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:36:27,051 DEBUG [ResourceDeliveryProcessor] Request for resource 578503 and type 'COVER_IMAGE' received
2012-08-23 10:36:27,051 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578503)
2012-08-23 10:36:27,051 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578503
2012-08-23 10:36:27,051 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5885
2012-08-23 10:36:27,051 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:36:27,051 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5885,Date: Thu, 23 Aug 2012 14:36:27 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:02,410 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551552 and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:37:02,410 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578840)
2012-08-23 10:37:02,410 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551552)
2012-08-23 10:37:02,410 DEBUG [MediaItemDAOImpl] Getting file of media item 551552
2012-08-23 10:37:02,410 DEBUG [GenreDAOImpl] Reading a Genre (id = 5)
2012-08-23 10:37:02,410 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:02,410 DEBUG [MediaItemDAOImpl] Getting file of media item 551553
2012-08-23 10:37:02,426 DEBUG [VideoDAOImpl] Reading a Video (id = 551553)
2012-08-23 10:37:02,426 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551553 and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:37:02,426 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:37:02,426 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:37:02,426 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:37:02,426 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578841)
2012-08-23 10:37:02,426 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:02,441 DEBUG [MediaItemDAOImpl] Getting file of media item 551553
2012-08-23 10:37:02,441 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 8839 (filter: ALL) [No_Restriction]
2012-08-23 10:37:02,441 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-08-23 10:37:02,473 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-23 10:37:02,691 DEBUG [WebServer] Incoming connection from /192.168.1.50:41267
2012-08-23 10:37:02,691 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:02,691 DEBUG [ResourceTransportRequestHandler] GET /resource/578840/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:02,691 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:02,691 DEBUG [ResourceDeliveryProcessor] Request for resource 578840 and type 'COVER_IMAGE' received
2012-08-23 10:37:02,691 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578840)
2012-08-23 10:37:02,691 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578840
2012-08-23 10:37:02,691 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4890
2012-08-23 10:37:02,691 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:37:02,691 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4890,Date: Thu, 23 Aug 2012 14:37:02 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:02,707 DEBUG [WebServer] Incoming connection from /192.168.1.50:41268
2012-08-23 10:37:02,707 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:02,707 DEBUG [ResourceTransportRequestHandler] GET /resource/578841/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:02,707 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:02,707 DEBUG [ResourceDeliveryProcessor] Request for resource 578841 and type 'COVER_IMAGE' received
2012-08-23 10:37:02,707 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578841)
2012-08-23 10:37:02,707 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578841
2012-08-23 10:37:02,707 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5106
2012-08-23 10:37:02,707 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:37:02,707 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5106,Date: Thu, 23 Aug 2012 14:37:02 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:08,801 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-08-23 10:37:09,848 DEBUG [WebServer] Incoming connection from /192.168.1.50:55559
2012-08-23 10:37:09,848 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:09,848 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551553/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.1.4:8895]]
2012-08-23 10:37:09,848 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:09,848 DEBUG [ResourceDeliveryProcessor] Request for resource 551553 and type 'MEDIA_ITEM' received
2012-08-23 10:37:09,848 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551553 (local)
2012-08-23 10:37:09,848 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:09,848 DEBUG [VideoDAOImpl] Reading a Video (id = 551553)
2012-08-23 10:37:09,848 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551553, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:37:09,848 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file LL - 1080.mp4
2012-08-23 10:37:09,848 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:37:09,848 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:37:09,848 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:37:09,863 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:37:09,863 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:37:09 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-23 10:37:09,879 DEBUG [WebServer] Incoming connection from /192.168.1.50:52528
2012-08-23 10:37:09,879 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:09,879 DEBUG [ResourceTransportRequestHandler] GET /resource/551553/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.1.4:8895]]
2012-08-23 10:37:09,879 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:09,879 DEBUG [ResourceDeliveryProcessor] Request for resource 551553 and type 'MEDIA_ITEM' received
2012-08-23 10:37:09,879 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551553 (local)
2012-08-23 10:37:09,879 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:09,879 DEBUG [VideoDAOImpl] Reading a Video (id = 551553)
2012-08-23 10:37:09,879 DEBUG [VideoDeliveryEngine] Delivering item '551553' for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:09,879 DEBUG [VideoDeliveryEngine] Delivering file 'LL - 1080.mp4' using transcoding
2012-08-23 10:37:09,879 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-551215-7-ORIGINAL.stf', will stop the job
2012-08-23 10:37:09,879 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-551215-7-ORIGINAL.stf'
2012-08-23 10:37:09,879 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-2114,5,main]
2012-08-23 10:37:09,879 DEBUG [ProcessUtils] Killing the Windows process: 796
2012-08-23 10:37:09,894 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-23 10:37:09,894 DEBUG [TranscodingJobListener] Deleted temp file 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-551215-7-ORIGINAL.stf': false
2012-08-23 10:37:09,894 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:09,894 DEBUG [MediaItemDAOImpl] Getting file of media item 551553
2012-08-23 10:37:09,910 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: F:\Tor\HC\_HD\B\LL - 1080.mp4
2012-08-23 10:37:09,926 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Tor\HC\_HD\B\LL - 1080.mp4 -y -threads 2 -copyts -c:v mpeg2video -b:v 20000k -maxrate:v 20000k -bufsize:v 20000k -r 30000/1001 -g 15 -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-551553-7-ORIGINAL.stf
2012-08-23 10:37:12,910 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport) and address 192.168.1.4, timeout = 0
2012-08-23 10:37:12,910 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 204683ed-9f48-3c47-b70d-0da4ab7276fa
2012-08-23 10:37:12,941 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-23 10:37:12,941 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:37:12,941 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:37:12,941 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:37:12,941 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 551553) as read
2012-08-23 10:37:12,941 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-23 10:37:12,941 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-23 10:37:12,941 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:37:12,941 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-1184.0/1184,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:37:12 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=1184000;]]
2012-08-23 10:37:14,723 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:38
2012-08-23 10:37:20,660 DEBUG [WebServer] Incoming connection from /192.168.1.50:49385
2012-08-23 10:37:20,660 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:20,660 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551553/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-23 10:37:20,660 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:20,660 DEBUG [ResourceDeliveryProcessor] Request for resource 551553 and type 'MEDIA_ITEM' received
2012-08-23 10:37:20,660 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551553 (local)
2012-08-23 10:37:20,660 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:20,660 DEBUG [VideoDAOImpl] Reading a Video (id = 551553)
2012-08-23 10:37:20,660 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551553, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:37:20,660 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file LL - 1080.mp4.mp4
2012-08-23 10:37:20,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:37:20,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:37:20,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:37:20,660 DEBUG [MediaItemDAOImpl] Getting file of media item 551553
2012-08-23 10:37:20,676 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:37:20,676 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:37:20 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-23 10:37:28,863 DEBUG [WebServer] Incoming connection from /192.168.1.50:57658
2012-08-23 10:37:28,879 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:28,879 DEBUG [ResourceTransportRequestHandler] HEAD /resource/551553/MEDIA_ITEM/MPEG_TS_SD_KO_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-23 10:37:28,894 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:28,894 DEBUG [ResourceDeliveryProcessor] Request for resource 551553 and type 'MEDIA_ITEM' received
2012-08-23 10:37:28,894 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 551553 (local)
2012-08-23 10:37:28,894 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 551553)
2012-08-23 10:37:28,894 DEBUG [VideoDAOImpl] Reading a Video (id = 551553)
2012-08-23 10:37:28,894 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 551553, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-23 10:37:28,894 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file LL - 1080.mp4
2012-08-23 10:37:28,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_EU_ISO
2012-08-23 10:37:28,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_NA_ISO
2012-08-23 10:37:28,894 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file LL - 1080.mp4: MPEG_TS_SD_KO_ISO
2012-08-23 10:37:28,988 DEBUG [MediaItemDAOImpl] Getting file of media item 551553
2012-08-23 10:37:28,988 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-23 10:37:28,988 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 23 Aug 2012 14:37:28 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-08-23 10:37:30,332 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-08-23 10:37:30,519 DEBUG [WebServer] Incoming connection from /192.168.1.50:53118
2012-08-23 10:37:30,519 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:30,519 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.1.50:
2012-08-23 10:37:30,613 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-08-23 10:37:31,113 DEBUG [WebServer] Incoming connection from /192.168.1.50:41270
2012-08-23 10:37:31,113 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:31,113 DEBUG [ResourceTransportRequestHandler] GET /resource/578840/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:31,113 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:31,160 DEBUG [ResourceDeliveryProcessor] Request for resource 578840 and type 'COVER_IMAGE' received
2012-08-23 10:37:31,160 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578840)
2012-08-23 10:37:31,160 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578840
2012-08-23 10:37:31,160 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 4890
2012-08-23 10:37:31,160 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:37:31,160 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4890,Date: Thu, 23 Aug 2012 14:37:31 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:31,160 DEBUG [WebServer] Incoming connection from /192.168.1.50:41271
2012-08-23 10:37:31,160 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.50
2012-08-23 10:37:31,160 DEBUG [ResourceTransportRequestHandler] GET /resource/578841/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.1.4:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:31,160 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.50, Profile=Samsung TV / player (C/D/E-series)'
2012-08-23 10:37:31,160 DEBUG [ResourceDeliveryProcessor] Request for resource 578841 and type 'COVER_IMAGE' received
2012-08-23 10:37:31,160 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 578841)
2012-08-23 10:37:31,176 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 578841
2012-08-23 10:37:31,176 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5106
2012-08-23 10:37:31,176 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-23 10:37:31,176 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5106,Date: Thu, 23 Aug 2012 14:37:31 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-08-23 10:37:35,894 DEBUG [RendererManager] Removing renderer 7aebf80b-c410-5c76-5cae-78b376dd3947 from list of active renderers
Post Mon Aug 27, 2012 10:34 pm
Re: .mkv file issue with 1.0
adebian wrote:By metainfo u mean the ffmpeg -i output ? :
No, I mean result of MediaInfo program: viewtopic.php?f=5&t=1123
Users browsing this forum: Baidu [Spider] and 101 guests
