Trying to play online source
Regional Signal Inc
Post Fri Aug 17, 2012 4:10 pm
I have be using serviio but I have a customer that is trying to play a radio station that is online. I cant seem to get it to work.... not even sure if it will work. Any info would be great . The link is below
http://cfrb.player.amri.ca/
Also we are using serviio to serve our Russound DMS 3.1
xs2inattar
Post Fri Aug 17, 2012 4:31 pm
Re: Trying to play online source
try this
rtmp://cp111664.live.edgefcs.net/live/ playpath=cfrb-aac@40298 pageUrl=http://cfrb.player.amri.ca/ swfUrl=http://cfrb.player.amri.ca
/sites/all/swf/senshuPlayer_v2AK.swf live=true
Regional Signal Inc
Post Fri Aug 17, 2012 4:52 pm
Thanks for the info
I tried but still no luck. When I go to my device it still doesnt show up. Im I doing something wrong? I put it under online services as a live stream source type
xs2inattar
Post Fri Aug 17, 2012 4:59 pm
My bad, there was an extra character in the stream url i pasted previously.
try the following one.
rtmp://cp111664.live.edgefcs.net/live/ playpath=cfrb-aac@40298 pageUrl=http://cfrb.player.amri.ca/ swfUrl=http://cfrb.player.amri.ca/sites/all/swf/senshuPlayer_v2AK.swf live=true
Please do let me know if it works or not.
Regional Signal Inc
Post Fri Aug 17, 2012 5:10 pm
Getting there.... Now it shows in my list of online music but it still wont play.
xs2inattar
Post Fri Aug 17, 2012 5:12 pm
Zip, please look into this.
The above audio stream works fine with ffmpeg
 ffmpeg -i "rtmp://cp111664.live.edgefcs.net/live/ playpath=cfrb-aac@40298 pageUrl=http://cfrb.player.amri.ca/ swfUrl=http://cfrb.player.amri.c/
sites/all/swf/senshuPlayer_v2AK.swf live=true"
ffmpeg version N-42368-gbf53863-Serviio Copyright (c) 2000-2012 the FFmpeg developers
  built on Jul 11 2012 01:45:53 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/tmp/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --extra-version=Serviio
[flv @ 0xf903d0] max_analyze_duration 5000000 reached at 5014000
[flv @ 0xf903d0] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://cp111664.live.edgefcs.net/live/ playpath=cfrb-aac@40298 pageUrl=http://cfrb.player.amri.ca/ swfUrl=http://cfrb.player.amri.c/sites/all/swf/senshuPlayer_v2AK.swf live=true':
  Duration: N/A, start: 0.000000, bitrate: N/A
    Stream #0:0: Audio: aac, 44100 Hz, stereo, s16
Serviio check stream also verifies successfully.
But the audio stream never shows up at client.
Logs
2012-08-17 13:10:26,267 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-17 13:10:26,267 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-17 13:10:26,271 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 143)
2012-08-17 13:10:26,272 DEBUG [OnlineContentCacheDecorator] Stored online content 'rtmp://cp111664.live.edgefcs.net/live/ playpath=cfrb-aac@40298...
2012-08-17 13:10:28,847 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2012-08-17 13:10:29,177 DEBUG [EventDispatcher] Sending event notification #10 for subscription 123dd995-e168-4adf-b6bc-4b642962f366 to endpoint...
2012-08-17 13:10:29,183 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.3:2869
2012-08-17 13:10:29,188 DEBUG [EventDispatcher] Event notification sent and received successfully
2012-08-17 13:10:29,189 DEBUG [EventDispatcher] Sending event notification #7 for subscription 35f858f6-d7ab-47c6-9166-214dbc64fdc0 to endpoint...
2012-08-17 13:10:29,190 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.3:51325
2012-08-17 13:10:29,197 DEBUG [EventDispatcher] Event notification sent and received successfully
2012-08-17 13:10:32,408 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.11, timeout = 0
2012-08-17 13:10:32,409 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 61cd396e-1894-3da9-91a2-e8090bcf4e54
2012-08-17 13:10:34,387 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:38
No ffmpeg calls for the audio stream in the logs???
Regional Signal Inc
Post Fri Aug 17, 2012 5:32 pm
So is it something im doing wrong??
xs2inattar
Post Fri Aug 17, 2012 5:34 pm
It does not seem to be working.
I have posted the logs for Zip to take a look at and comment. Hopefully we will hear from him soon.
Post Fri Aug 17, 2012 6:02 pm
It is working fine for me in mediabrowser. Did you enter it as an "audio" livstream?
xs2inattar
Post Fri Aug 17, 2012 6:10 pm
:oops: It is working for me too.
I had the online audio disabled in presentation tab and I was searching for it in the online video at the client and was wondering why its not showing up. :lol:
Post Fri Aug 17, 2012 6:31 pm
LOL..best laugh this week!
Regional Signal Inc
Post Sun Aug 19, 2012 6:50 pm
I have been messing with this and I still cant get it to play. Any ideas???
Users browsing this forum: Baidu [Spider] and 54 guests
