G30 - no transcoding for mkv's
Maliniak
Post Sun Aug 19, 2012 12:07 pm
I started using Serviio recently and I love it. However my Panas G30E has problems with some of my mkv's. I thought that's the header compression issue which makes most of devices unable to play mkv but I used MediaInfo to check if it has it applied. Looks like it doesn't. I even used MKVmerge to rebuild this particular mkv with no compression at all and it still can't be opened. Here is mediainfo for it:
Unique ID                                : 218261531626040059839659352496558115615 (0xA433A4569D75D6D4BE52ACC34AB90B1F)
Complete name                            : J:\The.Dark.Knight.2008.720p.BluRay.DTS.x264-ESiR\The.Dark.Knight.2008.720p.BluRay.DTS.x264-ESiR.mkv
Format version                           : Version 1
File size                                : 7.91 GiB
Duration                                 : 2h 32mn
Overall bit rate                         : 7 441 Kbps
Movie name                               : The.Dark.Knight.2008.720p.BluRay.DTS.x264-ESiR
Encoded date                             : UTC 2008-11-24 21:06:49
Writing application                      : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Attachment                               : Yes / Yes / Yes
Format settings, ReFrames                : 8 frames
Duration                                 : 2h 32mn
Bit rate                                 : 5 850 Kbps
Bits/(Pixel*Frame)                       : 0.265
Stream size                              : 6.06 GiB (77%)
Title                                    : The Dark Knight
Writing library                          : x264 core 65 r1016M dbc5ef0
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.8:0.8 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5850 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=30 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.70
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 2h 32mn
Bit rate                                 : 1 510 Kbps
Stream size                              : 1.61 GiB (20%)
Title                                    : DTS 5.1 @ 1.5 Mbps
Audio #2
Format                                   : Vorbis
Format settings, Floor                   : 1
Codec ID                                 : A_VORBIS
Duration                                 : 2h 32mn
Bit rate                                 : 80.0 Kbps
Stream size                              : 87.1 MiB (1%)
Title                                    : Vorbis 2.0 @ 80 kbps Commentary
Writing library                          : libVorbis 1.1.1/1.1.2 (UTC 2005-03-04)
Text #1
Format                                   : ASS
Codec ID                                 : S_TEXT/ASS
Codec ID/Info                            : Advanced Sub Station Alpha
Compression mode                         : Lossless
Text #2
Format                                   : ASS
Language                                 : Romanian
Text #3
Format                                   : ASS
Language                                 : German
Text #4
Format                                   : ASS
Language                                 : Dutch
Text #5
Format                                   : ASS
Language                                 : Finnish
Text #6
Format                                   : ASS
Language                                 : Swedish
Text #7
Format                                   : ASS
Language                                 : Norwegian
Text #8
Format                                   : ASS
Language                                 : French
Text #9
Format                                   : ASS
Language                                 : Spanish
Text #10
Format                                   : ASS
Language                                 : Portuguese
Text #11
Format                                   : ASS
Language                                 : Hungarian
Text #12
Format                                   : ASS
Language                                 : Danish
I am using Serviio 1.0.1 with Panasonic Viera With AVI Support profile (I even replaced it with the one posted on forum). Problem is every mkv is streaming directly to my TV without transcoding. How can I force Serviio to use transcoding for every mkv my TV cannot play?
Maliniak
Post Sun Aug 19, 2012 3:57 pm
Re: G30 - no transcoding for mkv's
OK so it looks like I fixed my problem myself. Transcoding works fine with "Panasonic Viera G/GT/DT/UT/VT (2011/2012)" profile - however it's transcoding DTS to DD even though DTS is supported by G30. I did some checks and mkv that is working without transcoding is playing with DTS but after transcoding you only get DD. How can you force transcoder to leave original audio if it is supported by the TV? Same with subtitles but that's common issue and I believe there is no fix for that as muxed subs into mkv are not displayed.
Post Sun Aug 19, 2012 8:21 pm
Look at the profile, it says:
   <!-- Some models support DTS natively, so the folowing line can be removed for those -->
   <Matches container="matroska" vCodec="h264" aCodec="dca" />
So remove the dca (DTS) matching and it should play natively.
Maliniak
Post Sun Aug 19, 2012 9:26 pm
Now it doesn't transcode with this profile.
Return to Panasonic
