[SOLVED] No library update with Serviio 1.0-012
Fleetship1
Post Mon Aug 20, 2012 12:30 pm
Since Serviio 1.0 it is not possible anymore to update the library (searching for new files).
Neither with console nor with ServiiDroid it it possible to search for new files (status led´s are always red).
How can I fix that?
Thanks & Regards,
Fleetship1
Log:
2012-08-20 13:51:05,343 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-20 13:51:05,349 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-08-20 13:51:05,350 INFO [MediaServer] Petr Nejedly 2009-2012
2012-08-20 13:51:05,350 INFO [MediaServer] http://www.serviio.org
2012-08-20 13:51:05,351 INFO [MediaServer] Java 1.7.0_06-Oracle Corporation
2012-08-20 13:51:05,351 INFO [MediaServer] OS Linux arm 2.6.32.12
2012-08-20 13:51:05,352 INFO [MediaServer] File encoding: UTF-8
2012-08-20 13:51:05,354 INFO [MediaServer] Headless mode enabled: true
2012-08-20 13:51:05,355 INFO [MediaServer] User home dir: /var/services/homes/serviio
2012-08-20 13:51:05,355 INFO [MediaServer] Temp dir: /tmp
2012-08-20 13:51:05,355 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-20 13:51:06,277 INFO [WebServer] Socket buffer set to 65535 bytes
2012-08-20 13:51:06,289 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-08-20 13:51:06,529 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-08-20 13:51:06,531 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-08-20 13:51:06,614 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-08-20 13:51:17,660 INFO [MediaServer] ------------------------------------------------------------------------
2012-08-20 13:51:17,660 INFO [MediaServer] License: PRO (NORMAL, id: 3f746a21-e51a-4274-9d60-a21b0af04cd6)
2012-08-20 13:51:19,502 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-20 13:51:26,343 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-08-20 13:51:32,619 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-08-20 13:51:36,197 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-08-20 13:51:41,637 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-08-20 13:51:44,080 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-08-20 13:51:46,619 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-08-20 13:51:54,291 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-08-20 13:51:54,680 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-08-20 13:52:03,925 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-08-20 13:52:18,505 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-08-20 13:52:22,786 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-08-20 13:52:25,486 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-08-20 13:52:25,933 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-08-20 13:52:28,597 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-08-20 13:52:29,744 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-08-20 13:52:33,515 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-08-20 13:52:34,505 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-08-20 13:52:38,876 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-08-20 13:52:44,898 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-08-20 13:52:46,638 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-08-20 13:52:47,473 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-08-20 13:52:58,302 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-08-20 13:52:59,505 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-08-20 13:53:00,985 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-08-20 13:53:02,585 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-08-20 13:53:04,198 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-08-20 13:53:04,343 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-08-20 13:53:07,230 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-08-20 13:53:09,093 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-08-20 13:53:09,852 INFO [Device] Created UPnP Device with UUID: c41c5514-0d79-3774-967b-023b9e31d01f, bound address: 192.168.0.2
2012-08-20 13:53:10,360 INFO [PluginCompilerThread] Looking for plugins at /volume1/public/serviio/plugins
2012-08-20 13:53:10,367 INFO [PluginCompilerThread] Started looking for plugins
2012-08-20 13:53:10,379 INFO [UpdateChecker] Checking if a new version is available
2012-08-20 13:53:10,876 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-08-20 13:53:11,327 INFO [WebServer] WebServer starting on port 8895
2012-08-20 13:53:11,528 INFO [EventDispatcher] Starting EventDispatcher
2012-08-20 13:53:11,537 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-08-20 13:53:11,547 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-08-20 13:53:11,582 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.2, timeout = 0
2012-08-20 13:53:11,677 INFO [RendererSearchSender] Searching for Renderer devices
2012-08-20 13:53:11,684 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-08-20 13:53:15,958 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-0024bece8954', name = 'KDL-40W5800 ', ipAddress='192.168.0.6', pr
2012-08-20 13:53:21,803 INFO [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy)
2012-08-20 13:53:24,201 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-08-20 13:53:24,876 INFO [RendererManager] Stored a new renderer: uuid='cfc03f28-2b89-4b6f-bd99-96cccd56cc76', name = 'Sony Bravia TV (2009)', ipAddress='192.168.0.6
2012-08-20 13:53:25,924 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-08-20 13:53:27,245 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-08-20 13:53:38,247 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-08-20 13:53:38,308 INFO [PlaylistMaintainerThread] Started looking playlist changes
2012-08-20 13:56:55,581 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-08-20 13:57:01,277 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
2012-08-20 13:58:49,057 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-20 13:58:49,078 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-20 13:58:49,092 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-20 13:58:49,095 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-20 13:59:52,526 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-0024bece8954', name = 'KDL-40W5800 ', ipAddress='192.168.0.6', pr
2012-08-20 14:00:12,609 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-08-20 14:00:12,645 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-08-20 14:00:12,630 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-08-20 14:00:12,665 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-08-20 14:00:35,755 INFO [RendererManager] Stored a new renderer: uuid='66f7670e-ca53-4ddd-9e79-d4c1993a9b48', name = 'Sony Bravia TV (2009)', ipAddress='192.168.0.6
2012-08-20 14:07:22,555 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-0024bece8954', name = 'KDL-40W5800 ', ipAddress='192.168.0.6', pr
DS212j | Samsung UE40ES7090 | Sony BDP-S480 | modded xecuter Xbox 1
Post Mon Aug 20, 2012 1:15 pm
Re: No library update with Serviio 1.0-012
Have you actually added some new files that aren't being picked up/do you have updates ticked for the shared folder? The updates are a lot quicker now, so they may finish within the status update interval (IIRC 10 seconds for ServiiDroid and something a bit less for the normal console).
patters
Post Mon Aug 20, 2012 2:25 pm
Remember to allow the 'serviio' user read access to the shared folders which your media is stored in. Check in the Shared Folders Control Panel in Synology DSM.
Fleetship1
Post Mon Aug 20, 2012 5:32 pm
I have different new files and folders copied on the DS212j and "user servio" has read access to all relevant folders.
Mostly I use ServiiDroid to update the files manually. It is easy because I don´t have to start my PC. ServiiDroid
brings an audiosignal if the search for new files is finished. but now nothing happens.
Post Mon Aug 20, 2012 7:13 pm
Can you post a detailed log please? Also post permissions just to be sure.
Fleetship1
Post Mon Aug 20, 2012 8:41 pm
How can I get a detailed log? Sorry, but Linux is not exactly my strength. :oops:
Post Mon Aug 20, 2012 8:47 pm
There is a link in my signature for how to turn it on. Also post permissions of the folder / an example file in it.
Fleetship1
Post Mon Aug 20, 2012 10:00 pm
Please find attached the Log. How can I show you the permissions for serviio user?
Serviio Debug Log File
(264.67 KiB) Downloaded 750 times
patters
Post Tue Aug 21, 2012 2:28 pm
It could be some sort of character encoding problem. By the look of that log, most of the files you're trying to add contain characters that don't look to be normal UTF-8:
/volume1/Musik/Weihnachten/Festliche Weihnachtslieder/134 Dresdner Kreuzchor-Fr�hlich soll mein Herz springen.mp3
What does this filename look like in DSM, and on your computer?
Fleetship1
Post Thu Aug 23, 2012 3:31 pm
Hi patters,
this is german language (ü, ö, ä, ß) but I think, that is not the problem. Every time I stored a new file (mp3) in the musicfolder of my NAS,
I clicked on ServiiDroid (force update) and the "led" looking for new files switched to green. Now both "leds" are red and nothing happens.
This is also on the console (PC). I can´t update my files.
Post Thu Aug 23, 2012 3:49 pm
I think its a problem of writting permissions on your NAS.
Fleetship1
Post Thu Aug 23, 2012 7:01 pm
I gave the serviio user admin rights and for the directorys read and write access. Same problem as bevor.
Nothing about "no access".
I think the only possibility is to reinnstall the complete serviio package. Isn´t it?
Post Thu Aug 23, 2012 7:10 pm
Fleetship1 wrote:I think the only possibility is to reinnstall the complete serviio package. Isn´t it?
I don't know...
you can try to delete the library folder and restart serviio service.
When you remove/delete the library folder, serviio wil create a new one but you probably have to reconfigure the serviio console with your settings (share folders, online resources,etc).
Fleetship1
Post Fri Aug 24, 2012 6:06 pm
I think I have a installation problem. I tried to remove the library folder but I get back an error: [ServiioStatusService] NullPointerException occured. Returning error code 500 to the REST layer. Message: null
I think I have to reinstall. :cry:
Thank you for your help!
patters
Post Fri Aug 24, 2012 11:50 pm
Just seen this which may be related:
https://bitbucket.org/xnejp03/serviio/i ... accents-in
Fleetship1
Post Sat Aug 25, 2012 12:34 pm
I´ m so .......................... :oops: :twisted:
Fixed the problem now. In the console I added the directory with "add local" then network, nas, folder.
After I add the folders with "add path" for example "/volume1/videos" it works perfect. Sorry for my stupidity
and thanks again for your support.
Cheers,
Fleetship1
Edit:
Is this really my mistake? I think, I never changed the path after upgrading to version 1.0.1
Now the working path is: /volume1/music
The path bevore was: /volume1/homes/serviio/\\SYN-NAS\music
Post Mon Aug 27, 2012 10:48 pm
Re: [SOLVED] No library update with Serviio 1.0-012
I think your current path is right. It's the path of the files as viewed on the NAS, not on your PC (NAS is where serviio runs)
Users browsing this forum: Baidu [Spider] and 73 guests
