ac3 to mp3 or aac
xs2inattar
Post Tue Aug 21, 2012 9:44 pm
ac3 to mp3 or aac
My device does not support ac3 audio format.
It does support mp3 and aac.
What would be the best option to transcode it to MP3 or AAC ?
Please suggest? As I am running serviio on NAS, please recommend what would be more efficient and less CPU intensive.
xs2inattar
Post Tue Aug 21, 2012 10:23 pm
Re: ac3 to mp3 or aac
So, after running some tests, aac as well as mp3 transcoding cant keep up and video playing stops suddenly.
any suggestions??
Post Wed Aug 22, 2012 6:24 pm
What is your device ? Could you provide some information about format supported ? (see signature link)
xs2inattar
Post Thu Aug 23, 2012 12:07 am
Vizio CoStar. Just released by vizio.
I am sending it back :) not worth it.
long2know
Post Sat Sep 01, 2012 2:31 pm
I also have a Vizio Costar. I was out of town all week, but finally got a chance to play with it a bit.
It is true that it does not support AC3 in MKV at least. All of my videos are 640 kbps AC3 MKV, which presented a bit of a problem - I get no audio on any thing.
I added this simple profile and set Serviio to use it for the costar:
<Profile id="150" name="Vizio Costar" extendsProfileId="1">
<Video targetContainer="mpegts" targetACodec="mp3" aBitrate="320" forceInheritance="true">
All this does is transcode the audio, regardless of type, for every MKV file to 320 kbps mp3. So far, it seems to work fine with the Costar. I finally get audio with all of my videos.
Anyhow, hope that helps some.
robojerk
Post Tue Dec 04, 2012 11:38 pm
The Vizio Costar only supports AC3 via HDMI passthrough. Meaning if your TV, or sound system supports AC3 it can pass the job over to the next device.
I have tried Serviio, Plex, and some other DLNA transcoding software. I have tried using profiles others have written for to costar, I tried editing them, I have tried making my own profile. No success..
With the latest update, the costar work really well through the Chrome browser. PBS, HBO Go, Amazon VOD, Vimeo, machinima, all play really well. MP4 files using AAC the Vizio plays them really good as well. Honestly the 1 thing that really annoys me about the device is not being able to play my files that happen to be using AC3. I'm nearing the point of just converting everything to MP4 files and transcode the AC3 to AAC.
A good xmas gift would be either Dolby Digital sells the codec on the Play Store, Google allows apps to run natively on GTV (VLC), or Vizio updates the box to support native AC3.
viewtopic.php?f=7&t=7442#p52847
Post Tue Dec 04, 2012 11:41 pm
Did you try transcoding to AAC with a profile?
robojerk
Post Wed Dec 05, 2012 12:08 am
zip wrote:Did you try transcoding to AAC with a profile?
Yes, but I'm doing something wrong.
robojerk
Post Wed Dec 05, 2012 2:39 am
If someone could help me write a profile for the CoStar that would be appreciated.
Vizio Co-Star (VAP430)
Marvell Armada platform (ARM)
AVI/DIVX - Video: MPEG4 ASP, XVid, DivX4/5/6, MJPEG; Audio: MP3, PCM, AC3(pass-through only).
MKV - Video: H.264 (inc. Hi10P), MPEG2; Audio: PCM, MP3, AAC, Vorbis, AC3(pass-through only);
MP4/M4V - Video: H.264 (inc. Hi10P), MPEG4 ASP; Audio: AAC, AC3(pass-through only);
3GPP - Video: H.263, H.264; Audio: AAC, MP3;
TS/MTS/MPEGTS/M2TS - Video: MPEG4 ASP, H.264(HiP 4.1), MPEG2; Audio: AAC, AC3(pass-through only);
VOB/MPEG - Video: Video: MPEG1, MPEG2; Audio: MPA, PCM, AC3(pass-through only);
WMV/ASF - Video: Windows Media Video 9 (WMV9), VC-1; Audio: WMA(Pro);
FLV - Video: H.263, H.264, VP6; Audio: MP3, AAC;
Vizio Co-Star notes and issues:
DTS sound is NOT supported.
AC3(Dolby Digital) pass-through do not work on some firmwares (needs latest update).
DivX3.11 is NOT supported.
10-bit video (H.264 Hi10P) IS supported.
Aspect ratio selection is supported.
Zoom is NOT supported.
FLAC sound files are supported.
robojerk
Post Thu Dec 06, 2012 3:17 am
This works....
      <Video targetContainer="mpegts" targetACodec="mp3" aBitrate="192" forceInheritance="true">
         <Matches container="matroska" aCodec="ac3" />
         <Matches container="mpeg" aCodec="ac3" />
         <Matches container="mpegts" aCodec="ac3" />
robojerk
Post Thu Dec 06, 2012 6:44 am
Well, it sort of works.. most files only play for 2 - 5 seconds before the player on the CoStar freezes or quits back to the Selection screen....
robojerk
Post Sun Dec 16, 2012 7:17 pm
Any ideas on why the transcoding will only work for a few seconds?
I'm running Serviio on a Windows Home Server (pretty much a light version of Windows Server 2003). Java 6U37.
robojerk
Post Mon Dec 24, 2012 4:01 am
Just upgraded to Serviio 1.1 from 1.01
It doesn't crash anymore....
:D :D :D :D :D :D :D :D
My observations... (Likely have little to do with Serviio)
When I ply using PlayPoint (the pre-installed DLNA video player) it takes about 10-12 before the video starts to play.
When I play videos using GTVBox the videos play a lot faster.
If I run across any other issues, quirks I'll bring them up.
as400jockey
Post Thu Oct 29, 2020 3:52 pm
I have a Netgear MP101. One of my favorite streams appears to have gone to .aac . Netgear can't deal with it. I think I'm trying to transcode AAC to MP3. How do I do that?
The link set up in Serviio v1.10.1 is
https://stream.revma.ihrhls.com/zc7750/hls.m3u8
Set up as live stream, audio.
I can listen from MediaBrowser, but not from Netgear MP101..
Thoughts??
Post Fri Oct 30, 2020 1:31 am
I had trouble figuring out what the Netgear MP101 is. But I finally found it, and you appear to be correct that it does not support AAC. The datasheet only lists MP3 and WMA as supported codecs.
There is no profile in Serviio for your player, so it's using the generic profile, which does almost no transcoding. I tried listening to your link with VLC but was unable to get it working. I also tried adding it to my test Serviio server and it too doesn't work.
I searched through all the OnlineTranscoding sections, and very few of them provide audio transcoding. You'll need to build one yourself to try. I don't have the time at the moment, but if you feel game you can find some other user profiles and add something like this:
<OnlineTranscoding>
      <Audio targetContainer="mp3" aBitrate="320" forceInheritance="true">
         <Matches container="*"  />
</OnlineTranscoding>
This should capture any online audio stream, regardless of container, and transcode it into mp3.
as400jockey
Post Thu Nov 05, 2020 9:07 pm
Thanks for the info about transcoding. But I have more info on this.
The stream I'm trying to feed to my MP101 is on iHeart Radio. Looking at the source of the page was sending me on a wild goose chase.
"streams":{"hls_stream":"http://stream.revma.ihrhls.com/zc7750/hls.m3u8","shoutcast_stream":"http://stream.revma.ihrhls.com/zc7750","secure_hls_stream":"https://stream.revma.ihrhls.com/zc7750/hls.m3u8","secure_shoutcast_stream":"https://stream.revma.ihrhls.com/zc7750"}
I think I was starting with the first link labeled HLS stream. That downloaded a file hls.m3u8, which had a reference to another file playlist.m3u8, which had a reference to a streaming address...
Then I noticed the 'shoutcast stream' and if I put that link,
into Serviio, I can play it in MediaBrowser, or Winamp, or my MP101 .
So it seems to be working again... and fyi, Winamp reports that these streams are:
Content-Type: audio/aac
Metadata received: 121 bytes
Metadata interval: 16000 bytes
THanks again for the help.
Users browsing this forum: Google [Bot] and 5 guests
