[1.0.1] Online Sources streaming in 320Kbps
Satras
Post Sun Aug 19, 2012 10:07 am
I just realized that all audio online streams are now streaming in 320Kbps instead of the original 128/256 Kbps.
Is this a know bug ?
Post Sun Aug 19, 2012 11:02 am
Re: [1.0.1] Online Sources streaming in 320Kbps
why should it be a bug? It's probably define in the profile you are using.
Satras
Post Sun Aug 19, 2012 11:38 am
Are you talking about the "prefered online contend quality" setting ?
I know that on 0.6.x the stream to my upnp device was always matching the stream quality to serviio.
You know I opened this post where I had issues with some di.fm streams.
They are offering webradio streams in 256K/128K but Serviio converts tehm to 320K.
How or where can I change that the stream is not "transcoded" ?
grolschie
Post Mon Aug 20, 2012 12:13 pm
If the stream is being transcoded (because the device cannot play the source codec natively), then the higher the target bitrate the better (within reason). For example, if a 128k WMA stream is being transcoded to MP3 (because the device recognizes MP3 but not WMA) then transcoding with a bitrate of 320K would result in less loss of information than say transcoding to 128K MP3.
tl;dr version: Transcoding from 128k WMA to 128k MP3 may not sound as good as transcoding to 320k MP3.
Without knowing what your device is though and the stream URL, we cannot really offer much help.
Satras
Post Mon Aug 20, 2012 12:35 pm
Source stream is 256K MP3
Target Stream is 320K MP3
Same for:
Source stream is 128K MP3
Stream 128K
http://1live.akacast.akamaistream.net/7 ... .net/1live
Device:
Grundig Cosmopolit 3F WEB Internetradio
Ah and let me add... it was working fine in 0.6.x as mentioned above.
Satras
Post Mon Aug 20, 2012 5:04 pm
Ah, I guess you where asking for the profile...
The Device is using the Generic Profile... same for the past 3-6 month.
grolschie
Post Mon Aug 20, 2012 10:02 pm
Interesting. The "Generic DLNA profile" has this:
<Audio targetContainer="mp3" aBitrate="384" forceInheritance="true">
   <Matches container="flv"/>
   <Matches container="asf"/>
   <Matches container="rtp"/>
   <Matches container="rtsp"/>
   <Matches container="mp3"/>
</Audio>
You could just remove (or comment out) the "<Matches container="mp3"/>" line in the generic profile in profiles.xml. It seems strange that the aBitrate="384" whereas I presumed 320 was the maximum for MP3. I have no idea why MP3 would need to be re-encoded as MP3.
Anyways, better still is to create a new profile for your radio to play things natively where possible. Do you know what codecs your radio natively supports via DLNA/UPnP? I would guess anything that vTuner radios can normally play. I imagine it would be better to use vTuner rather than Serviio for radio streams though. It cuts out the middle-man so-to-speak. :)
Satras
Post Tue Aug 21, 2012 7:03 am
HA, I have not spotted this when i read trough the profile.
Thanx, I will check and come back with what my Radio can play, AAC streams are not working.. that for sure...
grolschie
Post Tue Aug 21, 2012 10:39 pm
Satras wrote:HA, I have not spotted this when i read trough the profile.
No problem. You might wish to change the line from:
<Matches container="mp3" />
to:
<Matches container="mp4" />
to ensure that AAC is transcoded to MP3.
Satras
Post Wed Aug 22, 2012 7:20 am
Thanx again !
I tried to find any infos on the codecs supported but other then "Can play MP3/WMA from an usb stick" wasn't available. Will check later today the manual...
grolschie
Post Wed Aug 22, 2012 8:22 am
No problem. Hopefully that one line change should be enough.
Satras
Post Thu Aug 23, 2012 7:24 am
The Manual is pretty useless. Ther is up to no information on supported codecs.
However it does have a v-tuner support, as you have mentioned.
