serviidb.com
Post Wed Aug 22, 2012 8:02 pm
Re: serviidb.com
That is what i am working on. If i take out the SQL part for plugin our works.
Post Sun Aug 26, 2012 6:06 pm
Re: serviidb.com
Will try the api in serviidbgroup.info and see how it works.
Post Sun Aug 26, 2012 6:24 pm
Re: serviidb.com
/api/media isn't connected up yet. It is also still outputting "taskhandler" at the start.
Side note, some of the videos seem to have 10-20 /r chars on the end of the urls.
Post Mon Aug 27, 2012 11:09 pm
Re: serviidb.com
yes, I had /api/media showing the actual sql generated.
I cleaned up all the URLs it was from the transfer from the old database.
Check and make sure it works with serviidroid and if it does I am going to transfer the domain serviidb.com to the new site and get rid of the old site.
Post Wed Aug 29, 2012 8:05 am
Re: serviidb.com
Sorry I missed your post, I'll test it tonight.
Post Wed Aug 29, 2012 9:37 am
Re: serviidb.com
You are returning status 302 instead of 200, can you fix that please as it breaks the simple http client that I'm using.
Side note, ITVPlayer content is missing. Also could you set my account so that I can edit/cleanup content added by other users, the OCD in me wants to sort out the case of the YouTube sources, some of which are called yourtube.
It would also be nice if content was sorted a->z based on the title on a per plugin basis, makes it easier to find stuff.
Post Thu Aug 30, 2012 1:54 am
Re: serviidb.com
will I will give you access to edit content. The API should be fixed. might still need to make a change or two in the background do to using varnish accelerator.
Post Thu Aug 30, 2012 8:00 am
Re: serviidb.com
I can now use the API however, the plugin field is blank on every response, also searching by plugin name doesn't work (unless it is in the title), but presumably that is because the plugin name isn't being fetched from the db properly.
Post Fri Aug 31, 2012 3:36 am
Re: serviidb.com
Will, check it now I think I have all the bugs worked out of the api.
Post Fri Aug 31, 2012 7:41 am
Re: serviidb.com
All working now, great job, the API is noticably faster. Whats the plan for the missing content? Transfer it manually? Also what about install counts (which are reset and don't seem to be updating)?
There seems to be a bit of extra white spacing on the urls, so I'll release an update that removes that (otherwise it won't detect if the source is already in the library).
Post Fri Aug 31, 2012 10:16 am
Re: serviidb.com
yes once I go live with the new site I will be adding content manually.
I will work on the install counts this weekend.
I cleaned up the white space in the URL so it should be good to go.
If everything, but the installs is working right, I am going to transfer the serviidb.com domain to the new site this weekend.
Let me know if there is anything else that needs corrected before I transfer domains.
Post Sat Sep 08, 2012 2:31 am
Re: serviidb.com
serviidb.com is live on its new server. Let me know of any problems or comments on the new server.
mpemberton5
Post Sat Sep 08, 2012 2:40 am
Re: serviidb.com
moltra wrote:serviidb.com is live on its new server. Let me know of any problems or comments on the new server.
Awesome! Still wondering where the "Like" button is on this forum. LOL!
Post Sat Sep 08, 2012 2:46 am
Re: serviidb.com
check it out and see if you see any difference in it. I am working to incorporate PHPbb3 in it soon if there is interest.
Xmantium
Post Sat Sep 08, 2012 6:06 am
Re: serviidb.com
Excellent, I'll be adding content over the weekend ;)
Post Sat Sep 08, 2012 7:24 am
Re: serviidb.com
Great work, the API is noticeably faster now, as is the site.
Post Wed Sep 12, 2012 10:59 pm
Re: serviidb.com
I have installed a copy of Serviio on my website so that people can see how the online media browser works in the Pro version. The link is Serviio Pro online Media Browser.
If anyone know of some free for commercial use music that I can use to show how the audio categories work, please let me know.
kairoh
Post Wed Sep 26, 2012 9:08 pm
Re: serviidb.com
Since a few days, serviidb API always returns 302 HTTP status codes (instead of 200), is it normal?
Could you please correct this?
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
Post Wed Sep 26, 2012 9:43 pm
Re: serviidb.com
Sorry was playing with varnish settings
Forgot a setting
kairoh
Post Thu Sep 27, 2012 8:08 pm
Re: serviidb.com
Thanks!
