Serviio Won't Connect to PS3 or Sony Bravia
smaqbool
Post Wed Aug 22, 2012 11:04 pm
It was working fine until a few days ago. the only thing different is the router/hub that I have from BT. I had to replace it as the previous one was faulty.
I get an error saying "cannot connect to serviio server, it doesn't seem to being running, exiting..." when I try and open the serviio console.
I have Windows 7 with latest Java 7 Update 6 installed aswell.
Not sure what to do to fix the problem, any advice would be appreciated.
Shaz
NX3
Post Thu Aug 23, 2012 10:30 am
Re: Serviio Won't Connect to PS3 or Sony Bravia
So if you changed the router then its the problem. I'm sure I read before BT homehubs being problems for some people.... so log into your router and you may need to open up a port, see if it have options for DLNA etc
