GoPro HD Hero 2 - MP4 videos on Panasonic TX-PF42G20S
ScratMan
Post Sun Aug 19, 2012 10:44 pm
I'm new to Serviio, and I'm trying to play my footage shot with a GoPro HD Hero 2 on my Panasonic TX-PF42G20S
The issue is that the video is choppy, and the sound doesn't play immediately. And when the sound comes, it is choppy too.
If I set the serviio console not to produce the best video quality, the sound comes immediately at video start, but the video is still choppy for several seconds, then it plays OK, and becomes choppy again...
I have another MP4 file, from internet, that plays correctly, so it seems the difference comes from the video original encoding and transcoding profile.
I'm using Panasonic Viera 2010 profile, and these are the mediainfo log for both videos :
GoPro video that doesn't work :
Complete name                            : D:\GOPR0061.MP4
Format profile                           : JVT
Codec ID                                 : avc1
File size                                : 1.55 GiB
Duration                                 : 14mn 42s
Overall bit rate                         : 15.1 Mbps
Encoded date                             : UTC 2012-08-16 11:26:54
Tagged date                              : UTC 2012-08-16 11:26:54
AMBA                                     :
Format profile                           : Main@L4.2
Format settings, GOP                     : M=1, N=15
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 14mn 42s
Bit rate                                 : 15.0 Mbps
Nominal bit rate                         : 5 120 bps
Height                                   : 1 080 pixels
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.289
Stream size                              : 1.54 GiB (99%)
Title                                    : GoPro AVC
Codec ID                                 : 40
Duration                                 : 14mn 42s
Bit rate                                 : 128 Kbps
Delay relative to video                  : 40ms
Stream size                              : 13.5 MiB (1%)
Title                                    : GoPro AAC
Video that works :
Complete name                            : D:\working_video.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 612 MiB
Duration                                 : 21mn 45s
Overall bit rate                         : 3 930 Kbps
Writing application                      : Lavf53.4.0
Comment                                  : FlixEngineLinux_8.0.17.1 (www.on2.com)
Format profile                           : High@L5.1
Format settings, ReFrames                : 16 frames
Codec ID                                 : avc1
Duration                                 : 21mn 45s
Bit rate                                 : 3 868 Kbps
Frame rate                               : 29.970 fps
Bits/(Pixel*Frame)                       : 0.062
Stream size                              : 603 MiB (99%)
Writing library                          : x264 core 115
Encoding settings                        : cabac=1 / ref=16 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=abr / mbtree=1 / bitrate=3868 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Tagged date                              : UTC 2011-08-18 03:48:35
Codec ID                                 : 40
Duration                                 : 21mn 45s
Bit rate                                 : 48.0 Kbps
Maximum bit rate                         : 64.0 Kbps
Stream size                              : 7.59 MiB (1%)
Is there something I should do to have GoPro videos playing fine on my TV ?
Thanks for help
ScratMan
Post Tue Aug 21, 2012 6:41 pm
Re: GoPro HD Hero 2 - MP4 videos on Panasonic TX-PF42G20S
Here are the FFmpeg info for the files :
Not working video from GoPro :
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\DivX\GoPro\GOPR0061.mp4':
    major_brand     : avc1
    minor_version   : 0
    compatible_brands: avc1isom
  Duration: 00:14:42.04, start: 0.000000, bitrate: 15138 kb/s
    Stream #0:0(eng): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1920x1080
 [SAR 1:1 DAR 16:9], 15004 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
      handler_name    :  GoPro AVC
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 128
 kb/s
      handler_name    :  GoPro AAC
Working Video :
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\DivX\GoPro\working_video.mp4':
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    creation_time   : 1970-01-01 00:00:00
    encoder         : Lavf53.4.0
    comment         : FlixEngineLinux_8.0.17.1 (www.on2.com)
  Duration: 00:21:45.55, start: 0.000000, bitrate: 3930 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080
 [SAR 1:1 DAR 16:9], 3877 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 59.94 tbc
      handler_name    : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 48
kb/s
      handler_name    : SoundHandler
Post Tue Aug 21, 2012 6:46 pm
That could be due to video bitrate. Could you check with this tool : http://wiki.serviio.org/doku.php?id=vbitrate
ScratMan
Post Tue Aug 21, 2012 8:08 pm
I made some captures with bitrate viewer on 3 different videos from the GoPro (all videos have same playing issues) :
GoPro Video 1
GoPro Video 2
GoPro Video 3
ScratMan
Post Tue Aug 21, 2012 8:10 pm
And the working video, with a much lower bitrate...
The downloaded working video : much lower bitrate...
Post Thu Aug 23, 2012 3:35 pm
The high video bitrate is probably the reason of the choppy video.
If you want to change the video bitrate, you have to force transcoding to mpeg2video with a lower bitrate (5Mb or 10Mb).
I will post you an exmple...
ScratMan
Post Thu Aug 23, 2012 3:40 pm
How can I do this ? :|
Post Thu Aug 23, 2012 3:47 pm
Illico wrote:I will post you an exemple...
I'm at work now...I'll post you a new profile that force transoding with a lower bitrate.
ScratMan
Post Thu Aug 23, 2012 4:31 pm
I looked in the forum and the Wiki, and it seems I managed to kick my problem out of my TV :D
I added the following to all video transcoding sections of all Panasonic viera profiles
maxVBitrate="17000" forceVTranscoding="true"
Now, I can keep the "produce max video quality" parameter activated, and the GoPro videos are played perfectly with very nice picture quality.
It gives the following :
   <Profile id="viera2011a" name="Panasonic Viera G/GT/DT/UT/VT (2011/2012)" extendsProfileId="1">
      <!-- Panasonic Viera G30, GT30, DT30, UT30 With avi (2011), xx50 (2012)  With AVI Support -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>(VIERA (G|D|U)T?(3|5)0?.*)|(VIERA VT50.*)</FriendlyName>
            <Manufacturer>Panasonic</Manufacturer>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
         <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="17000" forceVTranscoding="true" forceInheritance="true">
         <!-- remux VORBIS/FLAC/LPCM in MKV/MP4 to AC3 -->
         <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
             <!-- Some models support DTS natively, so the folowing line can be removed for those -->
             <Matches container="matroska" vCodec="h264" aCodec="dca" />
            <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
            <Matches container="mp4" vCodec="h264" aCodec="aac" />
         <!-- Remux MPEG-TS with no transcoding -->
         <Video targetContainer="mpegts" maxVBitrate="17000" forceVTranscoding="true" forceInheritance="true">
         <!-- Remux WTV files to MPEG-PS with no transcoding -->
         <Video targetContainer="mpeg" forceInheritance="true">
            <Matches container="wtv" />
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <Matches container="mp4" vCodec="mpeg4" />
            <Matches container="mpeg" vCodec="mpeg1video" />
            <Matches container="matroska" vCodec="mpeg4" />
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
         <!-- unsupported audio will be transcoded into lpcm audio -->
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
   <Profile id="viera2011" name="Panasonic Viera E/S/ST/VT (2011)" extendsProfileId="viera2011a">
      <!-- Panasonic Viera E3, E30, S30, ST30, VT30 (2011), E50 (2012)  Without AVI Support -->
      <Detection>
         <UPnPSearch>
            <FriendlyName>(VIERA (E|S)T?(3|5)0?.*)|(VIERA VT30.*)</FriendlyName>
         </UPnPSearch>
      </Detection>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="17000" forceVTranscoding="true">
            <Matches container="avi" />
   <Profile id="viera2010" name="Panasonic Viera (2010)" extendsProfileId="viera2011a">
      <!-- Panasonic Viera VT20, V20, G20, D25, D28 (2010) -->
      <!-- detection removed as it was interfering with detection of the 2011/2012 Viera profiles
      <Detection>
         <HttpHeaders>
            <User-Agent>.*Panasonic.*</User-Agent>
         </HttpHeaders>
      </Detection> -->
It may not be optimal to force transcoding on all formats, but I was pissed off, and made it quick and dirty :mrgreen:
Post Thu Aug 23, 2012 6:55 pm
ScratMan wrote:I looked in the forum and the Wiki, and it seems I managed to kick my problem out of my TV :D
Yes this is the solution.
I suggest to keep the original Panasonic profiles and create a custom only for "GoPro" files.
If you confirm that "GoPro" media are always mp4/h264/aac then you can add this at the end of the profiles.xml
   <Profile id="custom" name="Panasonic Viera (2010) for GoPro" extendsProfileId="viera2011a">
    <!-- This is a custom profile to force transcoding with lower bitrate of GoPro media files -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3">
ScratMan
Post Thu Aug 23, 2012 9:06 pm
It works. Thanks. I enabled the forceVTranscoding, as is was the last thing I did on my profile to make it work, and now everything is fine.
Thanks a lot for your support. :D
av1982
Post Fri Apr 19, 2013 3:58 am
Hi, I have the same high bitrate problem with my gopro hero 2 videos however I'm using serviio on Linux (fedora17) and my player is the ps3. will this fix work for me?
