Hibernation
hansol123
Post Sun Nov 13, 2011 7:52 am
Hibernation
I have just purchased a new Sony Bravio for my bedroom and Serviio appears to have resolved problems I was experiencing with Windows media player refusing to play some of my BBC HD recordings .
My Windows 7 64bit PC is set to hibernate after one hour which was not a problem in the past when I was streaming to a Toshiba via my WDTV box which appears to be 100% compatible with WMP and stops the PC from hibernating when streaming files.
The question is there a simple method of stopping the PC from hibernating when streaming from Serviio apart from switching off the hibernation function on the PC.
Thanks for your assistance
Post Mon Nov 14, 2011 10:06 am
Re: Hibernation
it's a feature that will be implemented in future.
hansol123
Post Thu Aug 23, 2012 5:38 pm
Re: Hibernation
The hibernation problem persists in the new version is there any chance of fixing this issue
Post Thu Aug 23, 2012 5:41 pm
Re: Hibernation
Try viewtopic.php?f=3&t=1947&p=45927#p45865 until it gets implemented properly
