ILIVE - A Video Livestreams Server Collection
hwmonkey
Post Sun Aug 05, 2012 2:35 pm
Re: ILIVE - A Video Livestreams Server Collection
glenb wrote:not working in 1.0 worked fine .62
Same thing here. In 0.6.2 I had several streams listed as online resources for ilive. Now, ilive does not even show up as online content
Post Sun Aug 05, 2012 3:25 pm
Posted Version 2, to fix problem when used with Serviio 1.0
Post Mon Aug 13, 2012 9:23 pm
Posted V3 with Version logging.
wapman
Post Fri Aug 24, 2012 1:19 pm
I don´t see any channels in the iLive folder, can anybody confirm that there are no channels online now?..I use 1.0.1 and v3 pluggin.
Cheers!
seaman
Post Fri Aug 24, 2012 3:28 pm
wapman wrote:I don´t see any channels in the iLive folder, can anybody confirm that there are no channels online now?..I use 1.0.1 and v3 pluggin.
Yes, I can confirm. There are not channels in iLive folder... :(
Post Fri Aug 24, 2012 3:42 pm
There seems to be a problem at ilive site. The menu of channels shows in the browser but requests to play any of them just yield a black screen. That's why the plugin displays no channels.
wapman
Post Fri Aug 24, 2012 3:46 pm
Okay, thanks for the response..:)
Cheers
Post Fri Aug 24, 2012 7:43 pm
Actually ilive changed its code so I've posted an updated V4 that now extracts correctly.
kappclark
Post Sat Aug 25, 2012 8:26 pm
Thanks ! Always enkoy scanning the menu at iLive
George_L
Post Sat Sep 22, 2012 5:39 pm
This suddenly stopped working for me. All the thumbnail links continue to appear. Can no longer access any links. Get a 'not supported file format' error on all links. Was working fine up until couple days ago with latest software and plugin.
Post Sat Sep 22, 2012 6:39 pm
The site is down. No idea why.
sleepykid
Post Sat Oct 13, 2012 1:00 pm
Anybody have this working?
I'm running servvio 1.0.1 on a mac watching through vlc. the shows show up in the list, but when I click on it to watch, it just loads for a long time and seems to get stuck.
other plugins work fine like MyIPlayer, Hulu, etc. also, the website works fine.
thanks
Post Tue Oct 16, 2012 6:00 am
Thanks for posting. V5 now available to fix that. There are now over 60 channels available.
mirchy
Post Wed Oct 17, 2012 10:26 am
thanks, working
sleepykid
Post Mon Oct 22, 2012 3:23 am
hmm.. still having issues playing anything back with serviio 1.01 running on a mac playing through vlc for this channel. what set up are you running that works for you? thanks
Post Mon Oct 22, 2012 6:13 am
Thanks. They changed their ip again! Version 6 released which will also display all ilive streams regardless of the max videos set in the console. This allows max videos to be set small but all ilive streams displayed.
a6point6
Post Tue Oct 23, 2012 9:01 am
Downloaded the plugin to the Serviio Plug folder (running v1.0.1) on W7
Added the http://www.ilive.to/channels to Online Sources as a Web Resource
But it doesnt appear on my mediaplayer. Other Web Sources appears.
What am i doing wrong?
Post Tue Oct 23, 2012 3:33 pm
V6 is working correctly. Check your debug log to verify it says
2012-10-23 07:36:39,621 DEBUG [FeedItemUrlExtractor] ILive: Parsing with Ilive V6
sleepykid
Post Thu Oct 25, 2012 3:20 am
works great! thx
kappclark
Post Sat Oct 27, 2012 6:23 pm
Thx - working here
Return to Available plugins
