Intel Atom D525 NAS enable SSSE3 ?
NX3
Post Thu Aug 02, 2012 6:38 pm
I've got a self build NAS that appears to be similar spec to Synology as some models use the Intel Atom D525 now days it seems. Anyway I'm compiling ffmpeg sources and trying to get the best performance out of this CPU.
I'm using Platters guide as below as my guide as as the generic guides on Ubuntu forums are too generic.
http://pcloadletter.co.uk/2011/12/30/co ... h-librtmp/
Serviio Wiki is pretty usefull too;
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
Using the code below compiles but SSSE3 isn't enabled though the command seems to be correct. I'm running Ubuntu 11.10 32 bit desktop edition, I know I could run 64bit but I've not got around to a clean build yet!
./configure --enable-ssse3 --target-os=linux --prefix=/usr/local/x86-linux-gnu --extra-cflags='-I/usr/local/x86-linux-
gnu/include' --extra-ldflags='-L/tmp/lib' --enable-static --extra-version=Serviio --enable-static --disable-shared --
bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-pthreads --disable-mmx --enable-gpl --enable-libfaac --
enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx
--enable-libx264 --enable-nonfree --enable-version3 --enable-librtmp --pkg-config=pkg-config
This works but if you spot any other mistakes please let me know as I'm still getting to grips with this, thanks.
Post Thu Aug 02, 2012 7:33 pm
Re: Intel Atom D525 NAS enable SSSE3 ?
I would be intered in this as I have a similar setup.
When you run configure, it should spit out lots of info as it goes, have you checked that/paste it here. There is also a config.log you can check that, although it will be quite big, look for the point where it tries to enable SSSE3.
NX3
Post Sun Aug 05, 2012 8:08 pm
Thanks for the reply.
I've check /proc/cpuinfo and D525 I have definetly supports SSSE3, just to be sure ;-)
From my command for 'make' it comes up SSSE3 = NO, in the long list of whats been enabled and its the only thing that looks wrong to me. I've check config.log and I see references to SSSE3 but no errors or anything that indicates why its not enabled it.
From ffmpeg logs "The Atom has SSSE3 support, which is useful in many cases, but sometimes the SSSE3 version is slower than the SSE2 equivalent on the Atom, but is generally faster on other processors supporting SSSE3. This flag allows for selectively disabling certain SSSE3 functions on the Atom."
Question for Platters perhaps as he was using the flag for atom NAS builds.
patters
Post Tue Aug 07, 2012 6:33 pm
Hi - I didn't know how to check whether it really is being enabled or not. At the time I first cross compiled it I didn't even have an Intel Synology to try it on. How do you tell?
NX3
Post Wed Aug 08, 2012 5:51 pm
When you enter the ./configure it lists the features it will and won't use. So even though ssse3 is enabled and accepted it gets turned off. I've tried sse as well, no joy and a bit stuck now.
~/Downloads/ffmpeg/ffmpeg$ ./configure --enable-gpl --enable-ssse3 --target-os=linux  --extra-ldflags='-L/tmp/lib' --enable-static --extra-version=Serviio --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-pthreads --disable-mmx --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-libvpx --enable-librtmp --enable-libxvid --pkg-config=pkg-config
install prefix            /usr/local
source path               .
C compiler                gcc
ARCH                      x86 (generic)
version string suffix     Serviio
big-endian                no
runtime cpu detection     no
yasm                      no
MMX enabled               no
MMX2 enabled              no
3DNow! enabled            no
3DNow! extended enabled   no
SSE enabled               no
SSSE3 enabled             no
AVX enabled               no
CMOV enabled              no
CMOV is fast              no
EBX available             yes
EBP available             yes
debug symbols             yes
strip symbols             yes
optimize for size         no
optimizations             yes
static                    yes
shared                    no
postprocessing support    yes
new filter support        yes
network support           yes
NX3
Post Wed Aug 08, 2012 8:46 pm
If you do "--enable-ssse3" without any disable e.g MMX command it enables all features, MMX, MMX2, 3dNow, 3dnow plus, SSE, SSSE3 which is interesting as the atom doesn't have 3dnow stuff at all. However with any disable combination then all off them get disabled even if specifically requested. It doesn't seem to matter what order you do things in either.... I'm compiling now with everything on, I'll see how that performs !
patters
Post Tue Aug 14, 2012 12:18 pm
Are you natively compiling? I cross-compiled mine on a Ubuntu system in a VM on my MacBook Air (Core i5 CPU). I'll have a look more closely at the ./configure output when I get home.
NX3
Post Tue Aug 14, 2012 4:37 pm
I'm natively compiling. The version of ffmpeg I compliled with everything on basically worked but performance dropped on and it wasn't great. I suspect from what I've read on ffmpeg mailing listings it was trying to call fuctions not supported. I'm recompiling now just back to a simple version to double check performance is back as was (over gigaether).
patters
Post Sat Aug 18, 2012 11:44 am
Just had a look. On my compile SSSE3 is definitely enabled. Are you installing or compiling yasm first (the assembler)? Maybe it doesn't optimize for these instructions without it. Looks like you may also be compiling 32bit too.
patters@ubuntu12:~/Downloads/ffmpeg$ ./configure --arch=x86_64 --enable-ssse3 --cross-prefix=x86_64-linux-gnu- --target-os=linux --prefix=/usr/local/x86_64-linux-gnu --extra-cflags='-I/usr/local/x86_64-linux-gnu/include' --extra-ldflags='-L/tmp/lib' --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --pkg-config=pkg-config --extra-version=Serviio
install prefix            /usr/local/x86_64-linux-gnu
source path               .
C compiler                x86_64-linux-gnu-gcc
ARCH                      x86 (generic)
big-endian                no
yasm                      yes
MMX enabled               yes
MMX2 enabled              yes
3DNow! enabled            yes
3DNow! extended enabled   yes
SSE enabled               yes
SSSE3 enabled             yes
AVX enabled               yes
CMOV enabled              yes
CMOV is fast              yes
EBX available             yes
EBP available             yes
debug symbols             yes
strip symbols             yes
optimizations             yes
static                    yes
shared                    no
NX3
Post Thu Aug 23, 2012 10:33 am
I figured eventually that my build of Ubuntu after a couple of in place upgrades had left it in a bit of a mess.
I've done a clean install, moved to 64 bit (I couldn't install originally due to a bug in the Intel mobo bios which they have now fixed). Everything is working fine, SSSE3 is enabled, thanks :)
Post Thu Aug 23, 2012 11:16 am
Any noticable improvement?
NX3
Post Thu Aug 23, 2012 8:40 pm
Very good question and something thats pretty hard to measure. I've now got a clean build ubuntu 12.04 64bit, latest ffmpeg etc....and SSSE3 enabled... something in that mix has had FF / RW better imo. 32 to 64, doubt that helps with that much, ffmpeg was fairly new anyway, I've not changed the partition setup at all so the HDD isn't faster etc.... if I'm just remuxing a mkv then it dumps out an hour in a couple of mins, if going to mpeg2 its working hard .. seriously, I can't really tell. Its marginal on a D525 cpu atom setup imo but it all helps I'm sure.
If you can think of a good way to test let me know !
patters
Post Fri Aug 24, 2012 11:30 pm
You could enable the detailed logging and play a relatively short test clip that will be transcoded to MPEG2. Get that FFmpeg command line from the log and run it manually, timing the result with both of your builds of FFmpeg.
Post Sat Aug 25, 2012 8:35 am
FFmpeg should output an average fps as it goes / at the end as well.
NX3
Post Sat Aug 25, 2012 10:33 am
With SSSE3 enabled :
frame= 3627 fps= 13 q=2.0 Lsize= 262428kB time=00:02:25.04 bitrate=14822.2kbits/s
video:235668kB audio:6807kB subtitle:0 global headers:0kB muxing overhead 8.228767%
Interestingly the clip didn't used to get transcoded to mpeg2 on Serviio 0.62, it is a lv 5.1 x264 encode but it played fine on a Sony 2011 set.
SSSE3 etc all disabled (as I was originally running)
frame= 3627 fps=5.4 q=2.0 Lsize= 262438kB time=00:02:25.04 bitrate=14822.7kbits/s
video:235674kB audio:6807kB subtitle:0 global headers:0kB muxing overhead 8.230268%
The frame rate is much lower 13 v 5.4. Both stuttering very badly on playback but its almost watchable with SSSE3 enabled.
The full details of the file I used for testing are:
Unique ID                                : 247448540047357510709008407138742213612 (0xBA28DAF4C20D95DFA4E7049EBE029BEC)
Complete name                            : FILE.mkv
Format version                           : Version 1
File size                                : 73.2 MiB
Duration                                 : 2mn 25s
Overall bit rate                         : 4 230 Kbps
Encoded date                             : UTC 2006-09-19 04:53:13
Writing application                      : mkvmerge v1.7.0 ('What Do You Take Me For') built on Apr 28 2006 17:20:19
Writing library                          : libebml v0.7.7 + libmatroska v0.8.0
Format profile                           : High@L5.1
Format settings, ReFrames                : 9 frames
Duration                                 : 2mn 25s
Bit rate                                 : 4 096 Kbps
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.178
Stream size                              : 69.0 MiB (94%)
Title                                    : Video Track
Writing library                          : x264 core 50 svn-564
Encoding settings                        : cabac=1 / ref=6 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=hex / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=1 / nr=0 / decimate=1 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=4096 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Format                                   : Vorbis
Format settings, Floor                   : 1
Codec ID                                 : A_VORBIS
Duration                                 : 2mn 25s
Bit rate                                 : 160 Kbps
Stream size                              : 2.77 MiB (4%)
Title                                    : Audio Track
Writing library                          : Lancer r1  (UTC 2006-09-03)
Post Sat Aug 25, 2012 11:17 am
Tried converting a 720p pixar short film from mpeg2video. SSSE3 took 2m8.450s and without took 2m9.596s so no noticable difference.
NX3
Post Sat Aug 25, 2012 12:02 pm
What CPU have you got ? I'm on a self built itx box with intel atom D525 (dual core 1.8ghz) but its very weak compared to any desktop cpu even single core.
I tested on another film and got 11fps (off) v 34 fps (on) !
Post Sat Aug 25, 2012 12:44 pm
The same CPU, hense the interest. Maybe it was the parameters i used. I've enabled it on my main build, so I'll see if I can notice a difference with different videos.
NX3
Post Sat Aug 25, 2012 3:52 pm
I just followed this guide , copied exactly;
This is the spec of the 2nd file I converted, lv 5.1 again
Unique ID                                : 208890228884502062489206046224010326314 (0x9D26CB70CB609229AD3D67B97436312A)
Complete name                            : filename.mkv
File size                                : 4.37 GiB
Duration                                 : 1h 59mn
Overall bit rate                         : 5 235 Kbps
Encoded date                             : UTC 2007-08-27 11:07:12
Writing application                      : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 8 frames
Duration                                 : 1h 59mn
Bit rate                                 : 4 848 Kbps
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Bits/(Pixel*Frame)                       : 0.278
Stream size                              : 3.96 GiB (91%)
Writing library                          : x264 core 56 svn-667C
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4848 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=173169,179370,b=0.15 / aq=1:0.3:15.0
Duration                                 : 1h 59mn
Bit rate                                 : 384 Kbps
Stream size                              : 328 MiB (7%)
Post Sat Sep 01, 2012 3:53 pm
Just watched a 1 hour 2.5GB video that was stuttering natively so set it to transcode to mpeg2video and it was able to (just) keep up with transcoding 720p content, something that it couldn't do 6 months ago when I last tried, so does seem to make a difference, even if it isn't huge, it's enough to bring it up a notch and support 720p transcoding.
