New version of Serviio... please help!
bono225
Post Sat Aug 25, 2012 1:12 am
I use Serviio 0.6.2 and am very happy. That tool is perfect for me.
How can I disable the update function?
I would not like a new version of Serviio! Please help!
Thanks :cry:
Post Sat Aug 25, 2012 8:17 am
Re: New version of Serviio... please help!
The ability to disable update notifications was added in 1.0, prior to that there isn't really anything you can do. Having said that, you don't need the console to use Serviio, only to make changes, so if you remove it from the start up folder in the start menu you can only open it when you actually need to add a new folder etc...
Do give 1.0 a try though (back up your /library folder), it's got lots of improvements such as faster file adding even if you don't want the new features.
Users browsing this forum: Baidu [Spider] and 99 guests
