List of installed plugins via API
mpemberton5
Post Sun Aug 26, 2012 9:49 pm
I'd love to be able to manage, or minimally be able to report on what plugins are currently installed. Is there any chance that you could add the ability to list the installed plugins? Something like GET /rest/plugins? The name of the plugin, the version, etc would be valuable. Not sure if it is possible to "manage" the installed plugins programmatically, but would also love to have that option as well (like PUT /rest/plugins).
Thoughts?
Post Sun Aug 26, 2012 11:22 pm
Re: List of installed plugins via API
That is doable but not the version bit, for that I'd have to change the plugin API to provide that information.
Create a bitbucket ticket.
mpemberton5
Post Sun Aug 26, 2012 11:28 pm
zip wrote:That is doable but not the version bit, for that I'd have to change the plugin API to provide that information.
Will do. Thanks!
Return to Feature requests
