DLNA BD Player - suggest
Lowlander
Post Wed Nov 17, 2010 11:07 am
Hi all,
after several months of struggling with my Sony S370, remuxing, recoding, testing, changing profiles, re-testing and swearing, I think it's time to reconsider my choice.
Does anybody own a standalone BD-Player which is capable of playing chaptered, subtitled (switchable), multi-audio (switchable) MPEG2 files from a Serviio server? I think the first three features, especially those soft subs, mean it has to be MKV.
The new player (xmas is coming up...) should have the follwoing features:
- nice on-screen menu (I had a Samsung C5500 first, and alyways expected Ronald McDonald to pop up in its flashy navigation, the Sony is very tidy here)
- don't need WLAN
- SACD compatibility would be nice, but I do own just 2 SACDs so far and can well live without them
- no annoying noise while playing discs (the Sony keeps whistling like granny's old kettle)
- DLNA playback of MKV (MPEG2 and HD codecs, multi subs, multi-audio), TS (MPEG2, multi-audio), and all the usual suspects which are DLNA-compliant by definition.
Any hints highly appreciated,
Low
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
Lowlander
Post Mon Nov 29, 2010 4:20 pm
Re: DLNA BD Player - suggest
Does anybody own a Philips BDP5100?
It's supposed to be next to perfect for local mkv playback, but I couldn't find any info on its DLNA capabilites.
Post Mon Nov 29, 2010 4:32 pm
http://www.homecine-compare.com/
1. PHILIPS BDP3100
2. SONY BDP-S370
3. SONY BDP-S470
My choice still BDP-S370 :D , ok I go out... :roll:
Post Mon Nov 29, 2010 4:34 pm
DLNA compatible BluRay player sort by popularity:
http://www.homecine-compare.com/section ... 1&sort=pop
Lowlander
Post Fri Dec 03, 2010 3:25 pm
Illico,
Thanks for the hints! I'm getting more and more used to reading French. ;-)
I think I may give the PHILIPS BDP3100 a try, although I couldn't find any screenshots of how the player's GUI looks like. There aren't too many reports on the player's DLNA capabilities around, so I'll have to try it myself.
CU,
Low
Post Fri Dec 03, 2010 3:42 pm
Cool, and then you can help to create a profile for it ;-)
Lowlander
Post Fri Dec 03, 2010 4:01 pm
For a change, I'd very much like to cut out the "cool" part of having to pamper a new device into doing what it's supposed to do in weeks of testing and changing profiles, just by buying a player that does play all my stuff right from the beginning.
Yes, I do dream of things at night, too...
Post Fri Dec 03, 2010 4:03 pm
Lowlander wrote:I think I may give the PHILIPS BDP3100
PHILIPS BDP3100 is not DLNA compatible
PHILIPS BDP5100 and SONY BDP-S370 are DLNA compatible
See comparison
http://www.homecine-compare.com/index.p ... BDP5100=on
Lowlander
Post Sat Dec 04, 2010 9:10 am
Thanks Illico,
I had considered the BDP5100 anyway, but gave the incorrect number here, sorry. I used your link to make further comparisons and found (with my now fluent French) that the 5100 doesn't natively support HD Audio formats. Sorry, Philips, hi again Sony...
Have a nice one,
Low
Return to General discussion
Users browsing this forum: Baidu [Spider] and 7 guests
