Serviio Startup Error
nitro888
Post Tue Aug 14, 2012 6:41 am
Guys, can you help me with this problem?
I have installed Serviio to my laptop (Acer 4745G, Windows 7 Home premium), but when Servioo start, there's an error message as below :
Startup Error
X An error has occured during Start up:
java.lang.ClassNotFoundException: org.serviio.console.ServiioConsole
at java.net.URLClassLoader$1.run (Unknown Source)
at java.security.AccessController.doPrevileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoaderClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.Winlauncher.main(Unknown Source)
so what can i do to fix this problem?
have tried to install/uninstall Servio many times, with same problem still exist :-(
Post Tue Aug 14, 2012 12:05 pm
Re: Serviio Startup Error
try to uninstall all Java from your PC and install the latest
nitro888
Post Mon Aug 27, 2012 9:52 am
can you inform me which java version works with which serviio version?
still can't get serviio running, due to java error
Meelis
Post Mon Aug 27, 2012 11:52 am
nitro888 wrote:can you inform me which java version works with which serviio version?
www.java.com and download java for your OP system.
kappclark
Post Mon Sep 17, 2012 11:00 pm
I recently installed 1.0.1 on a server2003 machine...it did not like the V7 update7 version, so I uninstalled and downloaded the installable/offline Java 6
Bingo ! I have rin Serviio with the Version 7 on XP, but it seems 2003 likes the 6 version...results are everything, and with this wonderful software, the results are excellent..
and I won't be upgrading Java anytime soon
Return to User experiences
