Zony TV
xs2inattar
Post Mon Aug 13, 2012 12:45 am
Zony TV
Indian and Pakistani live-streams from http://zonytvcom.info
Add http://zonytvcom.info as video web-resource.
ZonyTV.groovy
V1: August 12, 2012 - Initial Release
V2: August 27, 2012 - Added support for zengatv.com
(10.78 KiB) Downloaded 1331 times
xs2inattar
Post Mon Aug 13, 2012 1:40 am
Re: Zony TV
updated: channel images are being blocked so i have uploaded the channel images to another location and using that for images.
rosahas
Post Thu Aug 16, 2012 4:17 am
Re: Zony TV
Thanks..
suduko
Post Sun Aug 26, 2012 10:34 pm
Re: Zony TV
xs2inattar wrote:Indian and Pakistani live-streams from http://zonytvcom.info
the website is down.
any other similar source please.
thank you very much
xs2inattar
Post Mon Aug 27, 2012 2:27 pm
Re: Zony TV
This website is live again.
xs2inattar
Post Mon Aug 27, 2012 9:30 pm
Re: Zony TV
UPDATED: August 27, 2012 - Added support for zengatv.com
suduko
Post Tue Aug 28, 2012 12:32 am
Re: Zony TV
Hi xs2inattar
thanks a lot for adding support to wcast.
Shall I add it as http://www.wcast.tv? it seems like that link has login page in beginning....
xs2inattar
Post Tue Aug 28, 2012 2:20 am
Re: Zony TV
suduko wrote:Hi xs2inattar
I believe you are talking about desistreams plugin.
You dont need to do anything. Desistreams changed their service provider to wcast.tv, so i updated the plugin accroding to their new service provier. You dont need to do anything, all the config remains as it is.
suduko
Post Tue Aug 28, 2012 3:03 am
Re: Zony TV
thanks...yes Desi streams is working now again.
thumbs up for your efforts. many thanks
geom19
Post Fri Sep 28, 2012 2:58 pm
Re: Zony TV
Can you add http://www.turbotv.in also it has lots of indian channels
xs2inattar
Post Fri Sep 28, 2012 6:10 pm
Re: Zony TV
geom19 wrote:Can you add http://www.turbotv.in also it has lots of indian channels
Done. viewtopic.php?f=20&t=7558 ENJOY!!!
arsaboo
Post Fri Oct 26, 2012 12:55 am
Re: Zony TV
Not working for me :(
It does not even show as one of the sources on my TV. I have added it as a web resource, as suggested. Any suggestions?
suduko
Post Fri Dec 14, 2012 10:47 pm
Re: Zony TV
hi,
this is not working anymore. Very few channels appears and they also dont stream. Please can it be fixed with new source. thanks!!
Return to Available plugins
